Question about Vacuums
I can't figure out how to remove the top of my wet/dry vac so I can empty the dirt inside
    Sergeant:
  • 259 Answers
Usually there are 3 or 4 tabs that have to be unclipped from the other half of the vacume and then you can lift the top off to empty the bottom and clean the filter.
Posted on Mar 23, 2011
I am using a wet dry vac and it is picking up water great but is spraying quite a bit of water out of the top part of the tank. The tank is no where near full, maybe 10%.
I have seen where so do not know that certain pieces of vac and be taken apart. Open and unscrew to look inside to see whats loose causing that problem.
May 22, 2014 | Dirt Devil Vacuums
WHAT MUST i DO TO SUCTION WATER? I DID THIS ONCE AND IT ATE AWAY THE FILTER. DO I NEED TO REMOVE THE FILTER WHEN I SUCTION WATER?
remove filter! please empty the unit as mixing dust/dirt with water can start to hack on the motor as the filter is removed during wet pick up where at the beginning you have dust flying around inside recovery tank. make sure to rinse and dry recovery tank before rreplacing filter.
Sep 28, 2010 | Craftsman 17777 Wet/Dry Vacuum
Hi there I have a Shop.Vac QS800 57519-63 its about 6 years old. I don't have manual for it & want to know how I can use it in the wet mode Thanks for your help. Jasper
To use a shop vac to **** up water you just need to remove the filter element inside. open it up just as if you were going to empty out the dirt and on the top center you will see a filter. unscrew the retaining nut on the bottom and remove filter. After unit is dry and you are done using it in the wet mode replace the filter and put the retaining nut back on.
Aug 09, 2009 | Vacuums
Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Dirt keeps coming out the back of the vac. I have a D:ayton 1D457D wet/dry vac. I have aring that says to use on dry applications only. Where does that ring go?
the ring goes over the filter insid the vac where the filter is.take the filter out and cleanit real good then put it back on.now the ring goes over the filter and get pushed all the way to the top and pressed on to hold the filter in place
Apr 23, 2009 | Vacuums
WATER FLOW
ok . i may have read you post wrong but i think you want the vacuum to empty itself ? i never heard of any vacuum emptying itself ......... the water or dirt goes into the canaster . when full remove the top and dump the bin . some than a drain plug you take out when your over a floor drain or outside ........ if this answer helped please rate 3 or 4 this high rateing will keep me in the paid answer department thanks you ..........if i misunderstood your post i am sorry , just leave a comment i will get it and try to help
Apr 03, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Jul 16, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Shop-vac i lost book
open the top of the vacuum. remove ONLY the filter element. There should be a ball about a two inch diameter inside the cage. It's purpose is to shut off the vacuum flow when water reaches a high in the canister.
Aug 29, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
