Question about Peg Perego John Deere Gator HPX Ride on Toy
Need to dissassemble my sons gator to put in a new gear drive ---how do i get to the gear drive is threre a disassembly guide or diagram for this
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Remove the center caps of the rear wheels then use a 13mm wrench on each side and loosen the bolts for the rear wheels, when loose remove the wheels and axle, then remove the red pin on the fron of the bed, then the two black pins on the rear of the bed, then lift the bed off, then lift the green plastic panel off this will expose the motors then, disconnect the wires from the motor and remove the two screws that hold the gearbox in place then take the gearbox and motor assembly out then remove the two screws that hold the motor to the gear box
Posted on Jun 12, 2012
2 Suggested Answers
  • 156 Answers
SOURCE: John Deer Gator only drives in low gear.
Sometimes the levers go bad in the shifter, but I would first check the shifter to make sure the switches are engaging. You should also check the wiring on the motors in the rear. Sometimes they come loose and if they are not making a good contact the gator will not go in proper speeds.
You can get great help at http://www.shopjandl.com/mepu0002.html.
They have a toll free number and are very helpfull because the repair them as well.
Posted on Apr 08, 2009
I have an SDS bit that will not release from my Hilti...any idea how to get it out?
by disassemble the chuck parts to get the ball out and all blocking parts , when the drive guiding the bilt lock is worn it will be happens again in a short time or you have used a wrong chisel ? the where safety glasses after the dissassembling and place the chisel with tool complete on it in a big bench vice and make the dissassembled bitholder hot carefully with a burner and beat the machine from the chisel only if all blocking parts are disassembled or totally removed replace the
chuck parts but also the entire shaft guide if it is simply worn out by wrong chisel not.
Jun 25, 2015 | Drills
My sons gator lost reverse, but still had forward 2 gears, then stopped working all together. I fully charged battery and still nothing. It will honk the horn, but wont move forward
horn runs off of a seperate power supply, check the battery nad charger with a multimeter and make sure that its putting out at least 12 volts
Jun 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
!st gear won't work
I would replace the shifter assembly. It seems to be a better upgrade with the switches built into the shifter itself. It also has the wiring with it.
As long as the battery seems to work and the motors are going in one of the speeds, then there is not much to the vehicle.
It is a specific Peg Perego Switch assembly.
Hope this helps
Apr 18, 2009 | Peg Perego John Deere Gator HPX Ride on...
Mar 28, 2009 | Peg Perego John Deere Gator HPX Ride on...
My son's gator will not go in reverse anymore.....When we first got it it did but as soon as we removed the screw for 2nd gear, it stopped....why
The problem is with the red forward/reverse switch. The two speed switch only works once the red forward contacts are engaged. I had the same problem several years ago. Replace the red switch and you are good to go.
Jan 08, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
126 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
