Question about HP PSC 1510 All-In-One InkJet Printer
Will not print envelopes it stops on feed - HP PSC 1510 All-In-One InkJet Printer
  • 93 Answers
The envelope is maybe too thick for the feed to pick it up.
Posted on Mar 23, 2011
Will not print envelopes. also is looking for more than one envelope
hi, each and every envelope has a code to identify it. So you printer knows what the size and format of the envelope is. you must select the code in envelope section from your application which you are printing your address for the envelope from eg; MS-Word. You should do this because not only dimentions of the envelope is telling the printer where to print but the weight of the envelope so it can allow for the thicker paper coz at some corners of the envelope it is 3x the thickness. feed it from the rear of the printer (manual feed) so it has its straightest path and does not have to curl around the rollers. make sure you feed it into the correct path there should be a line as a guide to where to feed it in so it can configure itself to where to print on the envelope.. i hope that helps you.. cheers!
Jun 19, 2014 | Canon Pixma MX452
Trying to print on a #10 envelope from iMac 27 with Os 10.5.1 using iWork. Printer will not load paper
I am on an iMac using OSX 10.5.8 and printing on an Epson R1800. With iWork, word processing module I set up the envelope to print and under the File menu, select page setup and choose #10 Envelope with Portrait orientation. I feed the envelope into the printer in the normal horizontal, top first, print surface up. In the File menu I select Print and hit Return. Most of the time this works. Sometimes the envelope feeds through without printing, and occasionally the envelope won't feed but the printer goes through the printing cycle. The R1800 is not the ideal envelope printer. It is made to print photos on photographic paper. I use an old fashioned typewriter to address envelopes.
Jul 11, 2010 | Epson Stylus Photo R1800 InkJet Printer
I would like to feed and print an 6" x 9" envelope
Print 4" x 6" photo images in normal mode in about 60 seconds; up to 17 ppm ... 3/4 Envelope. 9 Envelope. A4. A5. B5 Envelope. C5 Envelope. DL Envelope. 6 3/4 ...lexmark.com/lexmark/product/home/15/...?tabId=1
Dec 04, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
I am unable to print an address on an envelope.... it comes out blank
It sounds like to paper setting is wrong. In the configuration you can set if the envelope in on the right side, left side or center of the paper feed. If it is set one way and you feed the envelope the other way the printer will print but on the wrong end of the feed area so nothing will be on the envelope. Try this, print an address label as you would on the envelope but just use a full sheet of paper. If it prints where you can see it, then feed the envelope on that side, or change the feed settings in your software to print on the other side. Office and most other programs have this setting. In MS word the orientation setting is on the envelope and label screen on the right side of the pop up box.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 03, 2009 | HP LaserJet 1020 Printer
Envelopes jam in my hp 6940; paper sheets feed fine
I have had varying success with envelopes. Can you feed in the other way round? Sometimes different envelopes perform better. The peel N seal can be very difficult
Apr 10, 2009 | HP Deskjet 6940 InkJet Printer
Printing envelopes 4" x 91/2"
when you print envelopes you will have to select the paper size in the print options. There should be a pull down menu with every paper size and envelope size. Select the appropriate one, and be sure the envelopes are placed the right way when you feed them in. Most home printers work best when you manually feed the envelopes in. Its a tricky process, and you may have a few jams.
Feb 10, 2009 | HP DeskJet 9800 InkJet Printer
Envelopes keep jamming
hello! try cleaning the paper feed roller where you feed the envelope in with denatured alcahol good luck
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Envelope printing
With the address highlighted go to Tools, Envelopes, Custom
Enter the custom envelope size
Pick #4 feed method
click OK
Set the feed tray to hold the envelope along the right side.
Insert the envelope with the flap up - push it all the way in.
Print it
Dec 18, 2008 | HP DeskJet 6122 InkJet Printer
I have a hp 2849 all in one printer. When I print envelopes they print blank.
When you print an envelope, let the printer print on a regular sheet of paper to see if it's printing in an area not in line with the envelope.
This example is from Open Office. Microsoft is pretty much the same. What this is showing is the position of the envelop feeder so you know which one to select so that it can print correctly. The software must be set up correctly. The arrows show the path of the paper feed.
To find this in Office, click on TOOLS, LETTERS AND MAILINGS, ENVELOPES AND LABELS.
Click on the envelope in the FEED box.
This window will show the feed position of the envelope using an 8x11 as a point of reference.
Aug 04, 2008 | Office Equipment & Supplies
Envelope printing
did you go to the menu in the printer and set it in yhe paper options to envelope? You MUST also set it in the PC.
Go to
1- file
2-Print
3-right click on your printer
4-Properties
5-Device settings
6- set tray 1  to envelope
Oct 12, 2007 | HP Color LaserJet 2600n Printer
HP PSC 1510 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
