Question about Canon PowerShot A60 Digital Camera
Merory Card Insert 64mb card... camera says NO MEMORY CARD. Retried several times with the same result. Is it a fault with the card or the camera
  • Anonymous Nov 02, 2008
    carnt see pins inside of camera
  • Canon Master
  • 4,738 Answers
Remove batteries and card. Look in the card slot for a bent pin. If you see one use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on Sep 11, 2008
Memory card hi well when my merory card is in the camera i see every picture but when inserted into laptop i dont see every picture? im missing around about 2-300 photos that are really important. also...
Maybe those shots you took were in the raw mode, If so then you have to convert them with the Nikon software that camera with the camera,to view them in your laptop, Try installing that software then view them again, Hope this helps,
Aug 22, 2013 | Nikon D60 Digital Camera
Hi - I am getting an error message when i switch on my Sony Cybershot dsc t9 saying access and then it flashes format error C13.01 - can you advise how to resolve?
It might be due to a bad contact of the placed memorycard.
1. Pull the memorycard out and in the camera several times and retry.
2. If not OK, format the card in the camera. If that does not work, format it in the computer.
3. Try another memorycard and recheck.
Sep 04, 2011 | Sony Cyber-shot DSC-T9 Digital Camera
When i insert the memory card "card error" appears
Please try this card with your PC and if there is any issues in detection after inserting into the card detection slot, then the card is faulty for sure.
If not make sure there are no foreign particles inside of the slot, make sure with a good air jet the slot is clear.
If there is no detection remove battery, keep it off for few hours/overnight and retry.
If the fault stays the fault is in the interface to the processor in the main board.
Nov 24, 2010 | Samsung i85 Digital Camera
Merory card error
That usually means that you need to format the card in the camera. This will erase the card so download any pics first using a card reader if necessary.
Mar 07, 2010 | Cameras
Same problem when i inserted my memory stick duo, format error!!! f#@$#$ck
not all memory card are functional to a certain camera. some cameras can't read memory cards that have big capacity. try to format your card through your pc and retry to insert it to your camera again if it works. If it dosn't work then it's not compatible. you have to change it.
Sep 23, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
INSERTED NEW DATEL 64MB MEMORY CARD INTO A PS2
Be very carefull with accessories for Playstations as ones that are not Sony brand can cause damage/malfunctions with your system. The only ones that should be used that are not Sony brand are ones that Sony has certified for use with their equipment.
May 30, 2009 | Datel Max Memory 64MB Memory Card
Memory stick for Sony Mavica FD92
Most older digital cameras do not work when you try to use a memory stick adapter and the newer, smaller size memory sticks. Because this memory format is so old that it is no longer sold in retail stores, your best option is to buy a memory stick online. You can find these memory sticks on eBay.
To find more eBay auctions for these memory sticks, go to the Memory Cards category on eBay. Then, on the left side select Format = Memory Stick, and Storage Capacity = 64MB and under.
In the resulting search, only look at the auctions that are actually for 64MB and under Memory Sticks - you will find a lot of mis-classified memory in the search results - items that are the wrong format (not memory sticks) or too large to work in your camera.
Dec 13, 2008 | Sony Mavica MVC-FD92 Digital Camera
Memory card error
There is no workable solution to this problem. The camera only supports 1GB :-( May be time for an upgrade and use the current camera for special purposes--like a child's first camera.
Aug 24, 2008 | Kodak EasyShare CD33 Digital Camera
Canon Camera - Memory Card error & Card locked error
Try reading the card independent of a camera i.e. on a computer or a photo kiosk to determine if the card is readable damaged
Jan 07, 2008 | Canon PowerShot A410 Digital Camera
Display says "CARD FULL"
have u format them in the pc and afterwards in the camera??? try it, if doesn´t work it´s a mainboard problem.
Dec 31, 2006 | Olympus D-460 Zoom Digital Camera
Canon PowerShot A60 Digital Camera Logo
46 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
