Question about Jandy Lite 2 Natural Gas Pilot Light Heater
FL 7 is showing on computer screen. What does this mean?
  • 310 Answers
Either the pump is not pumping enough water through the heater to activate the pressure switch, or the pressure switch or its wiring has failed.
Replace pressure switch .
Posted on Mar 23, 2011
How to stop lap top screen from rolling
Do you mean flickering of screen? That means screen will fli ker or shake just le tat from the power on when something is showing in the screen screen wil start to flicker....If that is ur oroblem..then it might be a problem of lcd cable, FL Inverter, ram or LCD itself...if u are a tech then u can do a re assebling of the laptop and if u r not take tat to a laptop repair centre. .cheers...Jerine Kunjachan
Oct 03, 2014 | HP Computers & Internet
What does fL code mean on the wtw6400sw3 washing machine
In your case, when your washer shows LF it means: washer is taking to Long to Fill. And fL would not mean full or overload, because then it would say oL (OverLoad).
I advise you call and ask the company.
U.S.A.:1-800-253-1301.
Canada:1-800-807-6777.
Oct 04, 2012 | Washing Machines
My acer laptop monitor does not come on but all am getting is a white screen. I hook up the crode for the big monitor to my acer laptop and i can only see on the big monitor......
If you are getting a white screen that means your FL inverter is bad. This is what powers the LCD and displays. I do not believe Acer offers only the FL Inverter to be replaced. I believe you will have to purchase another screen to get it to work. You will have to compare the cost of a new screen vs. the cost of a new laptop. I would suggest taking it to a local show to have testing done on it. It also could be something as simple as a loose cable connecting the screen to the laptop motherboard. Again, I would take it in somewhere where professionals can take a look at it, unless you are comfortable with opening up laptops. Good news... The laptop itself is still good, as you are getting display on an external monitor.
Jun 02, 2011 | Computers & Internet
My neptune washer stop working. has power but doesnt cycle. shows a FL code. cycle i mean as spin to start washing
FL means that the door isn't locked properly. Make sure that its locked tightly and restart the cycle
Feb 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
What does FL flashing on the screen means?
FL means Full (or Full Load). The camera has no more storage space to keep your pictures, so doesn't allow you to take them.
Inexpensive cameras like this do not have the option to add extra storage, so you are limited by what the manufacturer installs.
Along with the camera, you should have got a disk and cable in the kit. What you need to do is download the pictures onto your computer, then delete them from the camera memory (usually menu options on installed software).
At that point, your camera should be fit to take another set of pictures.
Mar 02, 2010 | Cobra DC150 Digital Camera
On the gage cluster what does F1 or FI mean
The Fl lamp lights up when the computer finds a malfunction in the programmed Fuel Injection. There are 33 different codes. The offending code is denoted by how many times the Fl light blinks.
Nine of the 33 codes do not show symptoms since the engine still runs okay. If the Fl light just stays on then the engine will not run because the computer will not let it run, (except in two cases).
"MIL" translates as "Malfunction Indicator Lamp ".
This is what the service manual says:
" The PGM-Fl MIL denotes the failure codes ( the number of blinks from 0 to 33 ). When the indicator lights for 1.3 seconds it is equivalent to 10 blinks. For example, a 1.3 second illumination and two blinks ( 0.5 second X 2 ) of the indicator equals 12 blinks. Follow code 12 on page 5-26.
When more than one failure occurs, the MIL shows the blinks in order of the lowest number to the highest number. For example, if the indicator blinks once, then two times, two failures have occurred. Follow codes 1 and 2 on page 5-12."
BOTTOM LINE > A blinking light that can't be understood, combined with instructions that can't be understood make the entire Honda "malfunction alert system" totally worthless and a pain in the neck to the owner. Why can't someone in Japan write a computer program that would render something like " Code 23 error " instead of a blinking light that means nothing because it is not user friendly.
You asked what the FI light means. It means you are forced to take your bike in for service at a Honda shop and pay big bucks to the dealer for something you could have done yourself for $12.00. This is a built-in money maker for Honda dealers.
Please rate this answer. Thanks.
May 16, 2009 | 2001 Honda CBR 929 RR Fireblade
F1fault appearing on dash
The Fl lamp lights up when the computer finds a malfunction in the programmed fuel injection. There are 33 different codes. The offending code is denoted by how many times the Fl light blinks.
Have a drink of Saki and think about THAT for awhile. Then get back to me with the code ( 0 to 33 ) and I can tell you what the code means.
Please rate this answer as four diamonds.
With four diamonds and some Saki I can now rest for awhile.
Apr 06, 2009 | 2000 Honda CBR 600 F(4)Y
FL showing on screen
It means the answering machine is full.
Jan 03, 2009 | Uniden TRU9480 Cordless Phone
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
137 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
