Question about Plumbing
For a 98 dodge neon do u have to drop gas tank and the pumps in tank?
  • 2,510 Answers
The fuel pump is in the tank and that has to be dropped to access the pump. Evidently it is not a difficult job, just make sure that the tank is just about empty - it is amazing how much fuel goes into a tank.
Posted on Mar 23, 2011
Video of how to replace fuel pump on 1998 Dodge neon
I do not have a video but I am sure you can find one on YouTube. Fuel pump is dropped into the fuel take from above. You will have to drain the tank and unbolt the straps holding the tank up. Drop it down and the pump is pretty easy to get out and replace. The work is in getting the gas tank off.
Jul 17, 2014 | 1998 Dodge Neon
I'm pretty sure my fuel filter is bad on my 1998 dodge neon was just wondering where in the car it is located. Thank you
Fuel filter is located inside the gas tank and it cannot be replaced in alone. You have to replace the fuel pump as an whole
Nov 28, 2010 | 1999 Dodge Ram
In 1989 dodge neon where is the feul pump located
dodge neons have the fuel pumps in the gas tank. you must pull the tank down to replace fuel pump
Sep 09, 2010 | 1998 Dodge Neon
I need to drain the gas tank on my 2002 dodge
Hopefully your not attempting to replace a fuel pump in this vehicle or the tank its self?
There is no drain plug you have to purchase a fuel extractor pump. They are manual or electric. You put pump hose in tank threw fill up and start pumping the fuel out into its container.
CAUTION; WEAR EYE AND BREATHING PROTECTION. KEEP FIRE EXTINGUISHER'S HANDY.
Apr 26, 2010 | 2002 Dodge Neon
How difficult to replace fuel filter/pump on 98 neon
Not too much. You will have to drop the fuel tank down, there will be two metal straps holding it, find the ends of the straps where it attaches to the car and there will be two bolts to loosen to drop it, and dissconnect the wires and hoses from the top of the tank, then remove the bolts that hold the sending unit/fuel pump in. It would be best to drain as much of the fuel out as you can before starting. Good luck, dont forget to rate.
Jan 19, 2010 | 1998 Dodge Neon
2002 Dodge Neon Fuel Pump Replacement
It most definatly is in the tank. and the tank will have to be dropped. Unless you have a lift, it will be a pain in the ****. Especially if there is a full tank of gas.
Dec 21, 2009 | 2002 Dodge Neon
My fuel pump fuse keeps popping and we just changed the fuel pumpand it still pops it what could that be {98 dodge neon)
Check your power wire to the pump. It must have a bare spot somewhere, and is grounding out. Probably on top of the gas tank.
May 27, 2009 | 1998 Dodge Neon
Fuel filter on 98 neon
i doubt you will have to change the fuel pump it should be located under the car between the tank and engine possibly more less toward the tank.
Jun 21, 2008 | 1998 Dodge Neon
Neon wont start
It could be the fuel pump.The only way to know is to test it with a fuel pressure guage. You can buy them at most auto parts stores. What you are describing it fairly typical of a bad pump.(runs fine until you shut it of then won't start). The car can not be push started without the pump running. The pump is not really hard to change, but the fuel tank has to be dropped to do it. the pump is inside of the gas tank. Hope this helped.
Jun 15, 2008 | 1998 Dodge Neon
Plumbing Logo
41 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
