Question about NEC VT465 Multimedia Projector
My projector has blue lines when it projects...it almost looks like a blue fingerpring
    Genius:
  • 1,114 Answers
I would recommend that you clean the lens.
Posted on Mar 23, 2011
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
Z3 projector.3 years old. Blue tinge in one corner of projected picture. Grainy picture on dark scenes.
There may be some problem with your picture tube else try this that looks like retrace lines. Anyway, you should try to adjust screen pot not focus pot. Make sure you are turning blue screen pot (there are 3 focus pots and 3 screen pots) and do it slowly. If you turn it too much, it will affect your grayscale
Jun 23, 2008 | Televison & Video
Green screen
If the lines you see are retrace lines, It means that the 200VDC are missing and not getting all the way to the video amplifier assemblies.
Did you touch the screen control settings by any chance before you replace the HV splitter?
Apr 14, 2008 | Proscan PS60690 60" Rear Projection...
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
My picture is distorted in the bottom left corner of the screen. I can't get the red and blue crosses to line up in the configuration menu. I am guessing the motor that adjusts the projectors is shot. Can...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 09, 2009 | Toshiba 55H70 55" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Is a good projector able to perform well along a blue ray?
Hello the answer is yes, you can use a projector/projection television without losing quality. The only issue is the projector itself. If you have a good projector, It will look great. You need to check out the resolution on the projector that you want.
Hope this helps
-Chris
May 01, 2009 | Epson Televison & Video
Samsung Projection tv Blue line across the screen curving up
This set does not have a bulb. It is a tube type projection set that sounds like it has a convergence problem. Call a qualified tv repair company.
Jun 24, 2008 | Samsung - Projection TV replacement lamp...
BLUE SCREN
check you soft ware it looks like that you gone a service mode then you change save, reset your tuning try again tuning all channells the save the data the turn it on again.
Oct 25, 2007 | Sony KP-57WS500 57" Rear Projection...
NEC VT465 Multimedia Projector Logo
176 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
