Question about Samsung 793S 17" CRT Monitor
I have question, can I have a PC display on TV through VGA cable only I mean by three (Green Signal, Red Signal and Blue Signal) PINs of VGA cable?
  • 158 Answers
If your video card supports S-Video or if it has an S-video port, you just have to plug it in on the yellow port of your tv. or there are VGA to S-Video cables around that you can get.
Posted on Mar 23, 2011
    Sergeant:
    Champion:
  • 234 Answers
Yes you can, but you will need a sync box for the computer signal to be formatted to the correct signal for a tv.
The color on my TV is all pink. I have tried a hard reset but it didn't help.
Your TV has lost a GREEN color from a basic color palette (Red-Green-Blue). It is often caused by:
- damaged LCD cable (which connects the display with a signal board inside the TV),
- damaged video signal cable (ex. SCART, HDMI, VGA),
- damaged video processor (on the signal board).
I can't give you a more accurate answer, because I don't know what is your TV mark and model and, in what situations you have the problem.
Jan 19, 2015 | Televison & Video
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
Shrinking of the display
The DB15 VGA (Video Graphics Array) connector contains however 15 pins in three rows of 5 pins each. These five pins carry the color and synchronisation signals, also a digital I2C interface for two-way communication between the video controller and monitor. The common 15-pin VGA connector found on most video cards, computer monitors, high definition televisions which support VGA connections. The following schematic diagram and table shows respectively connector and pin assignment of DB15 VGA.
Pin
Name
Function
6
7
8
9
10
11
12
13
14
15
RED
GREEN
BLUE
n/c
GND
RED_RTN
GREEN_RTN
BLUE_RTN
VDC
GND
n/c
SDA
HSYNC
VSYNC
SLC
Red Video
Green Video
Blue Video
not connected
Signal Ground
Red Ground
Green Ground
Blue Ground
5 VDC supply (fused)
Signal Ground
not connected
DDC/I2C data
Horizontal Sycn
Vertical Sycn
DDC/I2C Clock
Aug 10, 2009 | SAMTRON 55V 15" CRT Monitor
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
Want to connect game on laptop
vga uses separate rgb (red, green, blue) connections to compose a video signal, sync and resolution, whereas the video female uses an analog signal with different signal info. you need to get a tv out adapter for your pc that cames with a the display hardware. look for video cards with video out or if you have a digital tv, with hdmi or dvi out. good luck
May 20, 2009 | LG Studioworks 700S 17" CRT Monitor
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
4&5 Not connected
9&10 NC
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
I just bought a cat5 cable and to covert to vga male and famle head . But i have no clue which pins to solder together because cat5 has 8 cores , while vga has 15 pins or so can you help
I'm not exactly sure how you expect to use a Cat 5 cable for VGA video (Takes 12 wires last time I looked) but here is how the cable connectors are wired
SVGA (35-37 KHz - 800x600) 15 pin sub D:
6
1 Red (Analog) 6 Red Return 11 (ID0) GND (Color) 11. . . 1
2 Green (Analog) 7 Green Return 12 (ID1) NC (Color) . . .
3 Blue (Analog) 8 Blue Return 13 Horzontal Sync . . .
4 Not Used 9 Not used 14 Vertical Sync . . .
5 Ground 10 Ground 15 Not Used . . .
15 10 5
Jun 22, 2008 | Computers & Internet
Samsung 793S 17" CRT Monitor Logo
128 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
