Question about Brother HL-2170W Laser Printer
My brother HL-2170W have a flashing error and drum light. When the printer starts up, its stops in the middle as if a paper is stuck but I can't find anything.
    Novelist:
  • 129 Answers
Hi There,
The Drum LED and the Error LED alternates turning on and off.
Meaning of LED Indication
Drum error:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Please click on YES if this helps,
Thanks,
Vikroks
Posted on Mar 27, 2011
Drum light flashing on brother printer hl-2170w. what needs to be fixed?
To reset the drum message:
Open the front door
Press and hold down the white button for about 4 seconds. Once all 4 LEDs are lit, release the button.
Close the front cover. Make sure that the Drum LED is now off.
Nov 05, 2010 | Brother HL-2170W Laser Printer
Paper jam in printer. Error light blinking.Can't get paper out
Turn the printer off, Open the front cover where the drum and toner are installed. Remove the drum and toner (cartridge). look inside the machine for a paper jam, also open the back cover and check there.
Apr 23, 2010 | Brother HL-2170W Laser Printer
Got a paper jammed in my brother hl-2170w
Open the front cover of Printer, remove the drum and toner with force and put aside. Remove the jammed paper slowly so it doesnt rip. If you cannot find the jammed paper check in the back cover and paper tray.
Apr 03, 2010 | Brother HL-2170W Laser Printer
Turn on my brother hl 2170w printer -led lights up tone and drum yellow error is red and nothing else-doesnt even warm up there is no paper jam nothing-printer just sits there.
Open the front door
Feb 09, 2010 | Brother HL-2170W Laser Printer
My Brother HL 2170W printer has red error light on. It was printing something over and over and I wanted to stop it so I pulled (oh, no!) the paper out and then I guess the red error light went on. I...
There is probably still part of the sheet in the fuser at the back of the machine. The fuser will need to be removed and checked for scraps of paper and/or damage to the temperature sensor and v likely a dislodged paper sensor arm.
Oct 15, 2009 | Brother HL-2170W Laser Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
The drum light comes on and printer stops
The error that you are giving me, is that the drum needs to be replaced. Replace the drum, and follow instructions in the package to reset the counter.
thank you
May 12, 2009 | Brother HL-2170W Laser Printer
Error Light on Brother HL-2170W
Do not try to depress the green lever, since you need to remove the cartridge AND its base altogether. Just grab the front middle part of the assembly, pull it out slowly and steadily. You may need to apply extra force in doing so as it does take some effort to disengage the cartridge assemly from its seated position.
After the cartridge is removed, you may find some jamed paper inside. simply remove it and the printer should work again.
You may email me at stevenjoy@gmail.com should you have further questions.
May 12, 2009 | Brother HL-2040 Laser Printer
Brother HL-2170W Laser Printer Logo
735 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
