Question about Kenmore 400 6942 Dryer
My kenmore 400 electric dryer was working fine. i bought about a month ago. Up until last night. when it would turn it make a short grinding noise then a big THUNK. And i noticed the room was hotter than usual. so i check the vent. sure enough it was blocked. so i unblocked it to see if that would solve my problem. it didnt. could that be the reason that it started making that noise?
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 15, 2011
I have a kenmore electric dryer that wont start..model 110.64642400
the thermal fuse blew for a reason and by bypassing it you most likely damaged the dryer even if it did work temporarily.
Nov 03, 2012 | Cars & Trucks
My GE electric dreyer, DHDSR46EGWW, is making squeaking noise and a grinding noise. My husband took is apart last night and put back together. When he started it the noises came back and he said it...
It could be the rear bearing or if not it have your honey take it apart again and inspect the rear rollers, if they turn freely then inspect the front bearing assy it is on the the door and if it looks worn down then it is allowing excessive pressure on the rest of the unit .
Apr 01, 2011 | General Electric DHDSR46EGWW Dryer
My dryer has been fine until last night when it started making a loud rumbling noise as its running. Any ideas about it?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 28, 2011 | Dryers
I used the dryer last night worked fine when i turned it on this morning it makes a very loud grinding noise seems to still turn and heat was afraid to leave it on more than a second what could it b
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 25, 2011 | Dryers
The dryer is making a thump/thud noise as the drum turns. The dryer works fine but the noise sounds like something hitting everytime the drum goes around. Could this be the belt going out?
heatman101
Asker
Jan 02, 2011 | Kenmore 83142 Electric Dryer
Kenmore Oasis drum began screeching when i started the dryer this a.m. - no problem last night. Can i fix it?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 01, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Whirlpool Estate Dryer not working
Sounds like the motor has seized. Try manually turning the drum with your hands. Is it hard to turn? If it is then the motor has seized up. If not, the windings in the motor may have shorted. Hopefully this answers your questions
Apr 08, 2009 | Whirlpool Dryers
Kenmore electric dryer won't start
it is possible that your belt is broken open the door manually turn the drum by hand if it turns frely then the belt is broken if not it could be your door switch that has failes but normally for this problem its a broken belt
Mar 15, 2009 | Dryers
Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
Jan 19, 2009 | Kenmore 63942 Dryer
Kenmore 400 6942 Dryer Logo
70 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
