Question about HTC Desire Cell Phone
Dont know how to open the battery cover to remove plastic on battery so i can switch on my phone
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 157 Answers
There are two back panels on the HTC Desire HD as it has an aluminum unibody. To remove the back panel that conceals the battery, please turn the phone face down on the palm of your hand with the phone turned off and the USB port facing towards you. On the right side of the handset pull the notch upwards on the panel. The battery should slide off to the right.
Posted on Mar 23, 2011
Keypad 5130c
i expect that some of the digit in that particular cellphone is not working. if you want to clean your key pad then you need to open it. removed the battery cover, the battery, back cover, untill you see the 6 screws that holds the front cover. Removing the screw will automatically remove the front cover and will show you the key pad. if you want to check the digit which is not working then you fix the battery and holding it firmly press the power On button. assuming that you already know what digit is not working then you can proceed by removing the plastic cover of the keypad and by using pencil eraser you can clean it.. from 0 - 9....
Sep 22, 2013 | Nokia 5130 Cellular Phone
Remove battery from2002 lincoln continteal
open the hood look down to the right thje battery is right there. put an old towel over the fender ,so as not to scrachj the paint. there is a plastic cover overe the battery . remove the battery termials with 5/16" inch wrench negative side frist then positive side . bend wires off to the side , so they dont tuch the battery terminels. use the 5/16" wrench to loosen the battery hold down bolt .remove plastic cover and battery hold down bolt . now you can lift thr batterey out.
Nov 10, 2012 | 2002 Lincoln Continental
Batteries dead on my Sentry E163026 safe dont know what to do
A1 locksmith advised me to To install batteries, remove cover between knob and keypad.Unlock door with the override key provided in the plastic bag attached to the owner's manual, and open the door using the knob. Remove battery cover located on the inside back of the door by sliding to the right. Insert the four batteries as indicated. Replace the battery cover.
Jul 23, 2012 | Sentry Fireproof Safe
How to open the boot of a Volvo s80 with a flat battery
Actually if you look right above your license plate there is a plastic cover covering a key hole on your trunk. Look right up buy license plate lights remove the plastic cover and you can manually use a key to open the trunk.
It's a black cover right next to the switch you press to open the trunk. I have an S80 trust me it's there nobody knows about it.
Jan 17, 2012 | Volvo S80 Cars & Trucks
I opened the package and dont know how to turn it on!
mcdevito75 Here, It must be a Quartz watch, look for a very small piece of plastic just under the stem, remove that piece of plastic, push the stem down and your watch should start. OR!! look on the back cover of your watch, carefully, if you see a plastic tab comming out of the back cover, remove by pulling carefully on that plastic tab, this plastic tab is keeping the battery from grounding, thus saveing battery power but also not letting your watch run. Simply reove this tab by carefully pulling on it.
Jun 17, 2011 | Watches
I need to know how to change out a turn signal switch on a 2001 kia sportage ex
DISCONNECT NEGATIVE BATTERY CABLE BEFORE STARTING. REMOVE THE PLASTIC COVERING FROM AROUND THE TURN SIGNAL SWITCH. LOOKING AT A NEW SWITCH WILL BE HELPFUL, TO SEE HOW TO REMOVE THE SWITCH.
Jan 27, 2011 | 2001 Kia Sportage
Phone is dead, battery fully charged. Need instructions on how to disassemble the phone to look for obvious problems.
From the back of the phone, remove 1 screw @ the top/center. Take the battery cover off, remove the battery. Remove 4 screws. With a medium size blade
screwdriver, gently pry the case apart at the battery charger hole. Just pry the plastic, not the connector case. Then with a very thin precision blade screwdriver, work your way around both sides of the case. Note: there is a connector that goes to the display portion of the phone. Once the case is open, gently pry the connector of the main circuit board. There will be a keyboard cover, 2 side button plastic pieces, 2 side button circuit boards, the top plastic cover, and the bottom main circuit board.
Good Luck
Russ
Jul 13, 2009 | LG VX5400 Cellular Phone
N73 in water
hi
there are some locks in the cover. try to remove the cover with your nail. dont put in the battery untill you are sure that your phone is free of water and moisture contents.
Sep 01, 2008 | Nokia N73 Cellular Phone
I dont know how to insert my sim card
Hey,
* Open ur cell phone cover(back)
* Remove battery.
* Insert sim in a jack(symbol 'll be given aside it, along with direction of sim).
* Put ur battery n cover back..
* Swith on ur phone..
Aug 22, 2008 | Cell Phones
I cant take photos
ok.under the lens cover there is a small switch which may lose it's place.
to find it remove the batterry cover , remove the two screws on the body of lens cover,then remove the rear cover (plastic and metal-one body) and you''ll find the tiny switch.Put it in a right place to work when lens cover open.
Nov 13, 2007 | Sony Ericsson K750i Cellular Phone
HTC Desire Cell Phone Logo
95 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
