Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
At our agency we have Motorola HT 1000. I am looking for a product that will drain the battery completely, so it lasts longer.
    Master:
  • Motorola Master
  • 541 Answers
We have sold these chargers for over 10 years to users. They only work on NiCad and NiMh batteries, no lithium. They take the battery down to a certain voltage, then recharge. They also have a conditioning feature where they will do this 3x automatically. It has a capacity readout. Terrific chargers.
Posted on Jan 14, 2015
  • 27 Answers
You do not want to drain the battery completely because doing so runs the risk of making the battery useless and non-fixable. What you need is a unit called a "conditioning charger" which will run the battery down to a low point and then recharge it. A radio service shop is probably the best place to find such a charger.
Posted on May 01, 2011
How to change battery on Motorola syn3104b t215
its is sealed in so time for a new one
Note:
Your battery is designed to last the life of your
product. It should only be removed by a recycling facility.
Any attempt to remove or replace your battery will
damage your speakerphone.
https://motorola-global-portal.custhelp.com/ci/fattach/get/593176/1361465240/redirect/1/session/L2F2LzEvdGltZS8xNTIwOTAxMzM4L3NpZC9mVWp3JTdFdk1CZnN6VlFkJTdFNlN1T1ZmJTdFTTd2WGlhUkp5bEVldVBYOE5NUE9rclByMnFNbUNoQlJUQyU3RUtNRkxkN1Q2TGVhTGd2MkxtazBaZUxqSVQxWEVVY25QeVptOUNEcUdDX0tFbHJpb1lRTlNUdmRmaDJldGNQQSUyMSUyMQ==/filename/T215_US-EN_GSG_68000202254A.pdf
a few complaints
Amazon.com: Customer Questions & Answers
https://www.amazon.com/ask/questions/Tx2SQNI5CX99CHI?_encoding=UTF8...
no it doesn't. The manual says that the battery is designed to last the life of the product and any attempt to remove or replace the battery would damage the speakerphone. Only issue for me is that it seems mine is no longer holding the charge... In all fairness though... it has lasted me more than 3 years, so as far a... see ...
Amazon.com: Questions and Answers: Motorola T215 Bluetooth In-Car ...
https://www.amazon.com/forum/Fx31EOZQSFUNUMC/ref=ask_dp_dpmw_ql_hza no it doesn't. The manual says that the battery is designed to last the life of the product and any attempt to remove or replace the battery would damage the speakerphone. Only issue for me is that it seems mine is no longer holding the charge... In all fairness though... it has lasted me more than 3 years, so as far as ...
How To Jump a Car Battery: Motorola T215 Bluetooth In-Car ...
howtojumpacarbattery.blogspot.com/2014/06/motorola-t215-bluetooth-in-car.html Jun 17, 2014 - Motorola T215 Bluetooth In-Car Speakerphone Sun Visor kit (Bulk Packaging). Motorola T215 Bluetooth In-Car Speakerphone Sun Visor kit This is a great product. It was easy to set up and the clarity is great; as good as the in car one that came with my Prius. The only downside is that there is no way to ...
motorola t215 battery replacement Google Search
Mar 12, 2018 | Motorola Cell Phones
Monster Power HT UPS 1000
sbonner:
Probably the battery of UPS. you can contact the manufacturer for the replacement of battery. Also please check the manual if you can replace it yourself.
It could be the power built in power supply, but I would check the battery first.
Regards.
Dec 25, 2007 | Monster Power PowerCenter HT 1000...
Need a user manual for ht 1000
For this concern that you're looking for the user manual for this device , you can go to this link then download the user manual save a copy of the manual to your computer or print it out for future use.
http://www.repeater-builder.com/motorola/jedi/ht1000-specs.pdf
Jan 06, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
I have a motorola Ht 1000 i need to no how to program it with the keypad only...
The HT1000 is not keypad programmable. The HT1000 is dealer programmable using a radio interface box (RIB), cable, the appropriate Motorola propietary software. A sister radio named the JT1000 can be made keypad programmable with an accessory called a programming key.
Best regards.
Nov 29, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT 1000 programming cable
Sorry to let you down, but the cable will only function with the appropriate Motorola software (and possibly a radio interface box (RIB) if the cable type you have requires one.) Software is only available to dealers. If you are needing reprogramming, it is generally available for between $25-$40 US.
Nov 17, 2008 | Motorola For MT2000 HT1000 HT6000 GP900...
HT 1000 Set Scan mode
First, your radio must have one of the side buttons programmed to be scan on/off. You will need to experiment while one or more of the channels is active and press the side button to see if it puts you in scan mode.
If it is, most likely a short press turns on scan, and a long press would be nuisance channel delete. This feature will temporarily eliminate a channel out of your scan list for the time your have your radio turned on. Once you shut the unit off and turn it back on, it would return to the original setting.
The only way to have a button programmed for scan/nuisance channel delete, is to us Motorola propritary software available to dealers and certain businesses and governement agencies. If you are needing to turn on scan or change a scan list, you would need to have the radio reprogrammed. This typically will cost between $25 and $40 at more dealerships.
Oct 03, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Transmitting
read the radio on the computer and see if the TX is enabled.
Also the PA could be faulty
May 02, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Frequency determination
The number you are looking for should start out with a "H"
Example H01UCC6DB3AN, The 4th character "U", in this case denotes 806-870mhz range.
Post back with you model #
Podge
Apr 09, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Anyone have a User Manual for a HT1000?
This "switches" functions are asigned by the programmer, and depends on the systems requirments or the user habilities check with your radio programmer for any feature that you can have on your radio.
Nov 21, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
111 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
