Question about Electrical Supplies
What causes an avr to flucuate? - Electrical Supplies
    Sergeant:
  • 259 Answers
Could be bad connections or engine not running steady or too low of engine speed.
Posted on Mar 23, 2011
My fuel gauge hand flucuates on my 2001 gmc yukon, how do I fix this?
Usually with fuel gauge problems its the float in the tank that causes the problem.
Aug 02, 2017 | GMC Cars & Trucks
While driving, the speedmometer flucuates. What
usually the inner cable has dried out, if you can get to the gearbox end (the other is well burried under the dash) and run some oil down it, with use it will work up the cable and be cured.
Mar 18, 2010 | 1996 Honda Accord
My 99 alero's rpm gauge is flucuating now what is the problem?
YOUR ENGINE IS DOING A THING LIKE ERRATIC IDLING.THE POSSIBLE CAUSE CAN BE MANY THINGS LIKE LOOSE BOLTS ON THROTTLE BODY OR INTAKE.LEAKING VACUUM HOSES.DIRTY FUEL INJECTORS.BAD PLUGS AND WIRES.ALSO DIRTY THROTTLE PLATE WITH CARBON BUILD UP ON THE THROTTLE BODY. CAUSE ROUGH OR ERRATIC IDLING.
Oct 13, 2009 | 1999 Oldsmobile Alero
AVR board is burnt out
AVR burn out is the most popular problem with electricity supplyment....
replace the AVR...if it burnt out shortly after words..then u have a problem with the rpm of the engine...if not..then its just a AVR burnout..
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Sep 27, 2009 | Coleman Powermate Powermate 5000W...
Engine rpm changes wihen fan switch turn on
replace the control unit for the heat, sounds like it is causing a cross feed.
Oct 12, 2008 | 2004 Chevrolet TrailBlazer
Failing smog computor says cataletyc not ready it has a knew converter
Check the oil level, to much can ruin catalytic converter. Check O2 sensors with scanner, make sure they are work accurately. Check air box while car running, apply aceteline gas with no flame, recheck scanner for O2 sensors flucuatation. Compare all sensors for flucuation of 1mv to 9mv. If sensors flucuate they are good, if no flucuation sensors need to be changed. recommend to change cat with bad sensors. Before changing cat check for bad pressure.
Sep 03, 2008 | 2002 Pontiac Grand Prix
Flucuating temps/constant running
yes its very important to have clean coils at the back it will run better
Jul 13, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
