Question about Pool & Spa
Haliburton canadian spa hot tub heating well but blowing cold air
  • 310 Answers
Since the blower simply takes air from inside the spa cabinet and blows it into the spa, the only solution is to get a heated blower, or insulate the interior of your spa cabinet better.
Posted on Mar 23, 2011
Spa bulges in one area what cause this and can it be fixed
Is this a Fiberglass or Acrylic Spa?
Or are you referring to a portable toy spa that is inflatable?
If the former, your shell surface is delaminating, from the rigid FiberGlass that was sprayed onto the acrylic or fiberglass shell to ridgidize it. What usually happens is "Air" is not completely removed during that spray process and over time, the acrylic will bubble due to the heat in the spa as the air expands. That Acrylic is barely paper thin when stretched out into the mold you sit in. An 8x8 sheet of acrylic is only 1/4" thick, then it is heated and placed over a tub "Mold" and then Vacuumed into what is your tubs shape that you enter into. You can imagine how thin it gets. When it goes through the ridgidizing process, All of the Air needs to be removed, sometimes it is not, and over the years it becomes evident that it wasn't.
What can you do? Well, besides that it is not very pleasing to look at, there is no problem or danger of any leaks, not yet anyway? You can break the bubbles out and find a supplier that sells acrylic repair kits in the color of your spa. You can google with the proper search terms & eventually find a kit. Maybe something like the link below shows...
Large Granite Spa Hot Tub Acrylic Repair Kit
If the latter, Sorry I don't know....
Good Luck
Apr 14, 2015 | Pool & Spa
Hot Tub Reaching Temperature but will not maintain
Bad thermostat is sticking.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 14, 2012 | Pool & Spa
How do you winterize a hot tub? QCA Jewel Model SUV M7
this is taken right from a jewel series QCA hot tub manual.....Winterizing
In very cold weather you may not want to venture outside to use your spa. In this case, you may move it to a heated area, or leave it as is until the weather warms. If you do leave the spa unused for a long period of time in severely cold weather, you should winterize the spa to avoid accidental freezing due to a power or equipment failure.. Follow these easy steps: Turn power to the spa OFF. Drain the spa. Use a wet vac to **** or blow out the air injectors, water jets and water suction fittings. Add 1-3 gallons of RV antifreeze, depending on the size of the spa, to all the air injectors, water jets, suction drains, and filter. Caution: Any lines not receiving adequate antifreeze are subject to freeze damage!
Dec 29, 2011 | Qca Spas Jewel Series Topaz Plus Hot Tub
I just installed my new X400 Dreamaker Spa. I filled it with water (although cold) and it has been warming up for approx. 18 hours and is only at 80 degrees? Is this normal? How long should it take to...
This is normal with the dream maker spa. The dream maker spas are poorly insulated, and only run 120 volts with a very small heater.
When the unit is first filled, the hot tub will not heat full time either. Most new hot tubs will have freeze protection below 50 degrees F. They will recirculate automatically using the friction and the pumps heat to warm the water above 50 degrees, and then the heating unit will kick on. These hot tubs do not heat while the jets are on high either, so once you are in it using the jets on high, the temperature will start to fall.
Now that you are up to 80 degrees, it should heat up fairly quick however.
Nov 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
My jets on my topaz II won't shut off
maybe your filtration cycle is set to high.
check with your instruction manual on how to bring filtration cycle up and if showing FIL 8 or Fil C then this is the reason.
Is the spa up to temp? if not then spa is running all the time to try and heat.....
if not then may have a circuit board error or top side controller
Adam Miller
Service Manager, Canadian Spa Company, UK
Aug 12, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
My hot tub heater will only work sometimes
is it on ECON or SLEEP? will only heat in filtration cycles.
check water levels and that all jets are open.
Adam Miller,
Aug 12, 2010 | Sta Rite Pool & Spa
Canadian spa haliburton hot tub.not warming up.were is the heater element and can it be checked.thanks
Do you live in an area that is prone to limescale build up. Is the pump pushing the water around as the element will not heat if there is no water flow around the tub. I had a similar problem and it was resolved by carefully taking the pump apart and giving it a good clean ( removing the limescale build up that was stopping it from pumping properly ).
Apr 10, 2010 | Pool & Spa
No heat jaguar 88 xj6 fan wont turn on cool air out the defrost vent
I have the similar problem with both my Jaguars, one is a 1988 Jaguar XJS, the other is a 1987 Jaguar XJ6, both blow COLD air out some vents while it blows warm air for heat. I heard it had something to do with the cold air blowing as a dehumidifier, I don't know if this is true, but it is really annoying to have both cold and warm air blowing when I need heat in these cold Canadian winters. If you find out please drop this website a note and let us know how you solved it. thanks.
Nov 12, 2009 | 1988 Jaguar XJ6
Hello! the pump on our qca majestic hot tub
If you live in cold weather and are not using it much lower your thermostat. If the freeze control kicks on (at about 38-40degrees) it will constantly try to heat the spa to where you have the heat set when the air temp is low. Hope this helps.
Oct 28, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Pool & Spa Logo
248 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
