Question about LG 50PG20 50 in. Plasma HDTV
How do I disable key lock - LG 50PG20 50 in. Plasma HDTV
    Sergeant:
    Champion:
  • 234 Answers
You can do this only with the factory remote by going into the menu and options menu.
Posted on Mar 23, 2011
  • emersonc1 Mar 23, 2011
    the remote is locked and no buttons work. It keeps saying key lock on
How to reset engine disability in 1996 Range Rover?
Lock doors with the key. Take out key . Insert key open and close lock 5 times then on the fifth turn open door this will reset the disable code to normal . I had this code on my P38 Range Rover and the Rover Tech assisted me with this simple way to reset the engine disable fault code . Good Luck .
Apr 23, 2014 | 1996 Land Rover Range Rover
Disable one letter keyboard
To change or disable any of the 108 keys on your keyboard we suggest using KeyTweak, a great small and free utility. This utility allows you to change how any of the keys on your keyboard work including the caps lock, shift, windows key, F1 through F12 keys, and num lock keys.
A download for this utility can be found at:http://webpages.charter.net/krumsick/
Once this program has been downloaded and installed open the program and click on the key you want to change or otherwise disable and choose the new key to be used or click disable button to disable it.
Apr 15, 2014 | Samsung Computers & Internet
Disable num lock
Deskop or Laptop seems to be a contradiction >????
The num lock (number or numeric lock) can become annoying if you tend to accidentally hit the num lock key on your laptop and turn it on or off.
Disabling the num lock completely involves editing the system registry.
Before performing such edits, always save and back up your computer information in case you make a mistake, as the system registry controls many aspects of your computer's operation.
Once you have disabled the num lock on your laptop, you must edit the system registry again to re-enable that function.
Close all windows and programs that are running on your computer.
Press the "Windows" key and the "R" key simultaneously to open the "Run" dialog box.
Type "regedit" without the quotation marks, then press "Enter."
Click the "+" symbol next to HKEY_CURRENT_USER, then select the "+" symbol next to "Control Panel."
Click on "Keyboard."
Double-click "IntitialKeyboardIndicators."
Enter "0" (the number zero) in the "Value Data" field to disable the num lock after logon, or enter "1" (the number one) to disable the num lock entirely.
Click "OK," then close the registry by clicking the "X" in the upper right corner of the registry window.
Restart your computer.
To re-enable num lock, follow the same process, but change the "Value Data" to "2."
http://www.softwarehowtos.com/article-how-to-disable-or-enable-the-num-lock-key-at-startup-1244448193.html
Oct 09, 2013 | Dell Vostro 1510 Laptop Computer PC...
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
I have a model KUDV245EWHY the key pad has a code to child unlock it..touch key pad..
I think you want to disable the childlock key. I think all you need to do is press the child lock key for 5-6 secs .That should disable the child lock.
Jun 01, 2011 | KitchenAid 34 in. KUDV24SE Built-in...
Lenovo 300 n200 disable mouse pad
Hi. I would suggest pressing the Num Lock key and see if it goes off, press and hold Function(Fn) button and hit the Num Lock key or press and hold the shift key and press the Num Lock key. Hope This Helps
Jun 08, 2010 | Lenovo 3000 N200 Notebook
When I press certain keys like P I get 6
This is yoru number lock function
look along the "F" key row for the NumLk or picture of the number 1 in a square. then hold down the Fn key on the lower left of the board. press the "F" key that corresponds to it and this will disable it.
Feb 18, 2010 | Acer NSK8458AN Keyboard
Computer locked
there are combinations of function or "hot keys" for enabling or disabling these functions. The NuLk is a combo of the functin key and the NumLk key pressed simultaneously. The scroll lock is the one keeping your mouse from working properly. I'm not familiar with your particular unit to advise which keys are necessary to disable Scroll lock, but they should be marked. Also, some notebooks have a switch to disable the mousepad...Usually indicated by a light located above the pad itself. Good luck Harvester3
Aug 18, 2007 | Averatec 3200 Notebook
LG 50PG20 50 in. Plasma HDTV Logo
262 people viewed this question
Computer Repairing
Computer Repairing
