Question about Brother Sewing Machines
I have a VX1120 and I cannot get the "reverse" lever to pop back up. The machine will now only sew in reverse.
  • 12 Answers
SOURCE: Kenmore 385 sewing machine gets stuck in reverse
Make sure that your machine is set to sew forward. The reverse button on your machine should have a spring loaded return. If the spring is in place, and doesn't appear stretched, try a drop (just a drop) of sewing machine oil. Please use sewing machine oil. Not WD-40, or any other household oil. If the machine hasn't been serviced in a while, or used alot recently, they knob may need to be "reminded" that its supposed to go in and out. :) After applying the oil, push the knob in and pop it back out like you have been. If nothing else is wrong, it should loosen up and move freely.
Posted on Dec 04, 2007
bilabon
  • 46 Answers
SOURCE: Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Posted on Jul 29, 2008
landsend
  • 1066 Answers
SOURCE: Brother sewing machine vx1120 Ithink won't pick up bobbin thread
have you tried other thread and a different bobbin?  The tension screw on the bobin case could be too tight.
Posted on Mar 11, 2009
SOURCE: Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Posted on May 02, 2009
SOURCE: I cannot get my newhome sewing machine to go into reverse!
There is a lever/switch on the right side of the jead of the machine. It is the very botton one...that controls the reverse stitch.
Posted on May 29, 2009
I have a Brother vx1120 sewing machine. is there a way to adjust the actual shuttle hook? It seems like it doesnt go back far enough to grab bobbin thread.
If a brand new needle doesn't resolve the problem, then the machine has been knocked out of time. Search for "sewing machine timing" or take it for service.
May 27, 2018 | Brother Sewing Machines
Machine will only sew in reverse
You wrote,
"Machine will only sew in reverse - Sewing Machines" A: I'm just a tinkerer, hobbyist, who did run across this same problem before. I can give a general non-model specific remedy based on my limited experience with mechanical sewing machines that get locked into sewing backwards, that is "they only want to sew in Reverse":
1. Verify what is the normal direction of the fly wheel in forward sewing for your machine. Most sewing machines, including Singers, always sew with the top of the flywheel moving toward the operator, regardless if sewing forward or backwards; but older friction-wheel White Rotary (RF) sewing machines, have the flywheel running in the opposite direction (top of Hand-Wheel turning away from the operator when sewing.
2. If it has Reverse Lever/Switch; check that it is in the correct position; if still only sews in reverse, change positions of the Direction Control lever (or Button, etc.), and see if it changes direction to correct the problem.
3. If this does not help, then jiggle the Reverse Lever and follow the linkage inside the machine and see if there is anything broken, loose or out of adjustment. Some machines have reverse control linkage elbows in the top part of machine, and by poor design are prone to accidentally pop backwards, causing sewing in the opposite direction of the position of the Reverse Lever/Button (Backwards when you want to sew Forward). On occasion, a Kenmore 158.1787180 got locked into the backwards sewing mode (the dog-gone' est thing), but by following and analyzing the linkage, I found where it was going wrong, and popped the indecisive linkage elbow back the way it was supposed to be and fixed it. [ I had more detailed notes, on this fix, but when I read them, without the machine in front of me, made no sense to me today so I can't share that till I revisit the conundrum again.]
4. If all else fails, you may be able to hold or clamp the Reverse Lever/Button in the Reverse position, so it sews Forward (I've done this before too (as a short-term fix) until I figured out how to adjust it back the way it was supposed to be.
5. If this post helped you, don't be afraid to indicate so, so Fixya will know. If it was useless, "ouch", but I'd like to know that too, so I'll be more selective on what I really know more about. I try to help, though this is probably a trade secret that anyone who knows is discrete about who they share the information with.
Sincerely
-- Amender. (2016 FEB 24)
Feb 06, 2016 | Sewing Machines
How do relase the Reverse Lever for Singer 756 when using the flex stitch mode
This man is your best source for getting your machine back on track.
http://www.tandtrepair.com/700TS.html
Mar 04, 2015 | Singer Sewing Machines
My sewing machine will only sew in reverse
The stitch length lever on some machines will back stitch when the lever is in the uppermost position. Bring the lever down to an appropriate stitch length and your machine should stitch forward.
Oct 11, 2014 | Singer 3116 Simple
Yamata FY5318 reverse lever sticking
Have you really examined the machine? I had a machine binding on me once and found that the take up lever had been bent and it was binding on the upstroke.
Usually binding is a bent or very gummed up part or bits of thread causing issues. Get out your magnifying glass and some tweezers... time to pick clean and oil.
Sep 05, 2012 | Yamata Fy5318 Mechanical Sewing Machine
My "new" elna type 722010 only sews in reverse.
What is the stitch length lever set to (4 in the diagram below)? these models have a lever that slides from positive to negative (ie) reverse, so you need to set it to the positive area, between 2 and 3 above zero. If you move it below zero then it sews that stitch length backwards.
If this machine is new to you, you might want to join the yahoo group called "Elna Heirlooms" there is lots of helpful members who share info on these old machines there.
Jul 15, 2011 | Elna Sewing Machines
Looking for the reverse button on a necchi bu nova
There is no reverse button, it is a lever.The stitch length lever also reverses the feed dogs - when down, it runs forward - at zero, it does not feed at all and when moved up, it reverses the machine. Set your stitch length by loosening the thumbscrew on the vertically moving lever and sliding the plate into position while moving the lever up to the desired mark. Tighten the screw and move the lever down to sew - to reverse just move the lever up until it hits the stop to sew the same stitch length in reverse.
Jan 12, 2011 | Necchi 4575 Mechanical Sewing Machine
Feb 27, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Reverse lever
lever must be locked in. if possible, you must open it and try to look for something blocking it. maybe a faulty spring or something.
Nov 24, 2007 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
158 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
