Pls help I'm watch movie half way my monitor shut down suddenly so I restart the whole com but when I on the CPU it has a long beep sound and the monitor doesn't turn on what should I do pls help me !
  • 158 Answers
Long beep sound is an error code for post. no post means a hardware failure. unplug the desktop from the power source. while its unplugged press and hold the power button for a minute. try to boot up again. if still the same you need to reseat some parts on the inside and might need extra help to do that
Posted on Mar 23, 2011
Screen is black but cpu turns on ;(
Hi Bwicked, Based on your post description, it would seem a whole lot of problems and questions. Let's try one by one: 1. cpu was really really hot - this is expected if the unit was covered (bed sheets), however, most units have a thermal protection so it would auto shutdown if it has reached cutoff temperature; 2. opened it up, shut down - the laptop auto shutdown when you opened it up? 3. turned on, monitor flicked grey, then black (blank), cpu booted normally - any beeping sound? What were the indicators that made you assume that it booted normally? 4. Another cpu monitor, nothing showed up - did you try pressing Fn + F? key to enable/activate external monitor? 5. Did my bulb burn out? - possible. If your CPU booted normally, then there should be some semblance of your desktop on your screen except that it is dark. You can try shining a flashlight and you should be able to see portions of your desktop. If yes then you have just confirmed that you have no backlight which can either be the CCFLamp as you suspected or the inverter that powers it; 6. Do I need a whole new motherboard? maybe no but depends on the diagnosis of the problem; 7. video card? most likely no also as some video card are built into the motherboard; 8. Any idea on how much to fix - depends on what is really wrong. 9. who i can send it to to fix - depends where you are. Perhaps your best bet is to seek the services of a qualified professional who is within your immediate vicinity. Further you need to get a firm estimate since it may no be economically reasonable to have it repaired if your assumptions are proven correct. In the same token, an on-site technical person would be able to perform the necessary steps to diagnose the problem. Hope this be of some help/idea. Pls post back with information to the above questions or should you need additional information. Good luck and kind regards.
Oct 06, 2007 | Gateway CX2610 Notebook
Hi, i have a Denon PMA 735 R amplifier which shuts down when volume increases suddenly.
Sounds like you have output transistor problems. Does it have a red protection light that comes on when it shuts down? If it does it will need serviced.
Dec 06, 2011 | Audio Players & Recorders
My display unit of my ACER PC show no signal,but it is on. what can be the problem?
first shut down you computer remove the covers of the cpu then locate the memory and remove them wipe them clean with clean cloth and switch the computer on with out the memory and see if you hear any beeps if you hear beeps insert the memory and switch on the computer if still no beeps then remove the processor fan and clean the surface of the processor fan and the processor apply a thin layer heatsink solvent and clip the processor fan tighty to the socket
Jun 02, 2011 | Acer AL1716 17" LCD Monitor
I have acer aspire 4736 model laptop bought 2
You can perform a recovery on the computer.
Press Alt+F10 as soon as the computer restarts, choose Full system recovery and follow the onscreen instruction.
Note: By perfroming FSR you will loose all the datas on the computer.
Mar 12, 2010 | Acer Aspire 4730-4947 Notebook
My computer beeps but it beeps like a robotic sound..
exchange the memory in different slottt. clean the memory slotss and clean the memory with pensil eraser only the gold pinss., then insert them back in, if u can take the fan off and cpu check if its burned or anything then insert it back..
Feb 22, 2010 | Gigabyte GA-K8VM800M Motherboard
Suddenly shutdown my laptop what is a problem i
Hello my friend,usually laptops when are overheating because of the processor or graphic card they start restarting or shutting down.Was your laptop warm when shut down or you was watching video or playing a game?
Feb 06, 2010 | Compaq Computers & Internet
My Dell, recently got into a problem like it shuts down itself, only when i watch online movies. I started watching online movies eight months back but did'nt have this problem till last week. Its a Dell...
Without knowing anymore specifics, I'd guess to say that's its a heat related issue. Especially since it's summertime now and you're on a laptop. Note that when viewing online movies, especially if you choose hi-def over std-def, your laptop will use much more horsepower and thus create more heat than if you were just cruising the internet or working on an Office application. And when viewing a movie, you're doing this consistently for an extended amount of time. Eventually, your computer reaches a temp(usually specified in your computer's Bios) where it will either shutdown or restart in order to cool-off.
To verify and understand this, please perform the following steps:
1) Close any open programs, especially any internet browsers, and make sure your antivirus isn't performing a full scan.
2) Right-click on the taskbar (or hit Ctrl-Alt-Delete) and select 'Task Manager'
3) Now click on the 'Performance' tab.
4) Take note of how much 'CPU Usage' you're using. For example, I'm on a laptop, at idle, and it says 3% CPU Usage.
5) Now, open up your browser and go to where you watch online movies but don't start any videos yet.
6) Take note of the 'CPU Usage' now. Currently, I'm on Hulu and on average I'm at 8% CPU usage.
7) Now, start watching your online movie and take note of the 'CPU Usage'. For me, it jumps between 40-50% on std definition and 50-60% on hi-def.
So what's the solution if it's heat related, well for a laptop your best bet is to buy a laptop cooler (look for reviews online). I recommend any retail store or buying online from NewEgg, Amazon, or Buy.com. Also make sure any vents from the laptop aren't obstructed.
Now to keep a better eye on your laptop's temperature, I recommend the following 100% free, no spyware, no viruses, no adware programs:
(Note: after you install one of these, you may want to repeat the steps above and take note of the temps during each step)
HWMonitor
http://www.softpedia.com/get/System/System-Info/HWMonitor.shtml
Real Temp
http://www.softpedia.com/get/System/System-Info/Real-Temp.shtml
Core Temp
http://www.softpedia.com/get/Windows-Widgets/Widget-Miscellaneous/Core-Temp.shtml
CS Fire Monitor (CPU Usage tray display, etc)
http://www.softpedia.com/get/System/System-Info/CS-Fire-Monitor.shtml
Aug 10, 2009 | Dell Computers & Internet
One long beep tone---NO Display on monitor(monitor checked ok)
Definitely not your monitor. It is either a CPU or a Memory problem, is this a new build or did an existing computer suddenly start doing this?
Is that your motherboard, the Gigabyte 7VM400M ?
Jun 26, 2009 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Sudden black out/ shut off from time to time
Sounds like you have a video card issue. You will need to replace your video card in your PC..Also, you can take another monitor and hook it up to your PC to see if you get the same results
May 14, 2009 | ViewSonic VG710b 17" Flat Panel LCD...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
