Question about KitchenAid Ovens
I have a Kitchenaid superba convection/gas oven model KGR1607hblg (?) I had soup overflow from the top burner and now the burners will not ignite. When turned on they will spark but nothing catches.
    Sergeant:
    Champion:
  • 218 Answers
Make sure that all the soup was cleaned out of the little holes in the burner that the gas comes out of. You can use a toothpick or some other small object like that to try to clean them out
Posted on Mar 23, 2011
  • pacd445 Mar 23, 2011
    Thanks! I did that but the problem seems to be on the entire stove top none of the burners will ignite and the soup only spilled over on the one burner.
Pad on oven does not work cant start oven
PDF]ELECTRIC RANGE USER INSTRUCTIONS - KitchenAid
https://www.kitchenaid.com/.../Use%20and%20Care_EN.pdf
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Stove-Oven/...---/Oven-won-t-t...
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Dec 01, 2015 | Ovens
Kitchenaid superba oven
It is very possible that moisture from the cleaning has caused the ignition switches to make enough resistance to cause the burners to spark. It usually goes away after the stove has dried out. If it continues after a day or so one or more of the ignitor switches may need replacing.
Nov 20, 2013 | Ovens
KitchenAid gas convection oven model # kgst307hbl4 won't turn off
seems like the safety switch not work. be careful
Mar 27, 2017 | Ovens
Kitchenaid superba electric oven (includes convection feature) and the entire digital panel suddenly stopped working after 6 years of perfect service. The stove top burners (acrylic top) appear to be...
It sounds as if the electronic clock/timer has failed and needs replacing. If you don't use the timer and don't need the clock it can be bypassed so that the oven will still work. A repair person should be able to do this fairly easily.
Feb 13, 2011 | KitchenAid Ovens
I have a two ear old Kitchenaid gas range (KGRS807). It all at once stopped lighting the oven. The top burners still work fine. When you do anything in the oven (Bake , Broil, Convection) the electric...
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
Apr 16, 2010 | KitchenAid Architect Series KEMC308KSS...
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Gas oven does not light
    I called the service where the item was purchased.
    You were no help at all
    Dec 03, 2009 | KitchenAid Ovens
    Oven/Broiler Igniters for KitchenAid range KGST307
    Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
    I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
    Dec 09, 2008 | Ovens
    Ovens Logo
    177 people viewed this question
    Top KitchenAid Ovens Experts
    ashburton
    jdthefixer
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
