Question about Mi T M Mitm 3500 Psi Hotcold Portable Gas Pressure Washer
I'm in Afghanistan with a MI-T-M GH-3504-OEGH. We lost pressure from the pump. One: I'm looking for a manual for this Pressure Washer. TWO: Seal kit to fix the problem. I know they need to be high pressure seals or O-rings so I don't want to do a quick fix leaving us to rebuilding the pump again
Power washer not spraying hard
Hi Mike
You could have one are two problems with the pressure washer.
1...pump for pressure washer worn and needs washer/seal replacement.
2...Need to adjust the pressure discharge relief valve to the needed pressure.
Please take time to rate me
Bud
Mar 28, 2013 | FAIP Powerwasher Universal Pressure Washer...
I am working in afghanistan and need the manuals for the DPD3000IC how can I download them?
Well Downloading may be a problem but since I don't know the network configuration you have I will link to the publication you need. Please rate me if this is helpful.
joe
Here is your manual
Feb 16, 2011 | Dewalt DPD3000IC 3000 PSI 28 GPM Gas...
Annovi reverberi triplex preesure washer pump
Usually when a pressure washer is pulsating, either one or more pistions are not pumping. Quite often one of the check vavles for a cylider has broken and will not seal, which means you'v just lost one cylinder, and now you're running on two (etc) If a pressure washer is allowed to idle too long, re-circulating the water, it will get hot, and then melt the plastic container on the check valves. Go to : www. pressure-washer-parts.com You can order parts, and manuals.
Jul 15, 2010 | Annovi Reverberi 4000psi 4gpm Pressure...
What oil do i use in the pump? The oil is milky and needs changing.
Well you can use direct recommended from Ace Hardware see link.
http://www.acehardware.com/product/index.jsp?productId=1340266
They recommend 250 hours, but i'd change more often, like you said when it's milky. If it begins to get water in the oil sooner, that indicates your piston to crankcase seal is beginning to leak.
Jun 21, 2010 | Mi T M WP-3000-4MHB Pressure Washer
Pump Lubrication
I believe the standard for pressure washer pumps is 30 weight non- detergent pump oil. Do not use motor oil. Also don't forget to winterize the pump if you live in the snow belt. Use RV antifreeze.
Jun 24, 2010 | Mi T M WP-2700-4MHB Pressure Washer
Pressure washer lost pressure in the middle of a job
The pressure valve has stuck in the high pressure position. This prevents anymore inflow and hence no further water will be pumped.
Rebuild the valve... There are O Rings to replace and clean the bore with croocus cloth. Lube the O rings with plumber's grease... good as new! 15 minute job. Get EXACT sized O rings for the unit.
May 16, 2010 | Honda Pressure Washer PSI 3000
Mi-t-m 4003 pressure washer has no pressure
You did not let it freeze did you?
If so, pump is probably bad. Other than that, check for obstruction in intake screen, make sure water is flowing through unit before pulling trigger. On gas models, water must flow before starting engine, otherwise pumps seals will go bad, because water keeps the lubed/cooled.
Sep 15, 2009 | Garden
Mi TM 2700 pressure washer has no pressure.
With the water on, to the washer and the unit running. Does the water come out at the same rate before the trigger as at does after the trigger (run test with spray nozzle removed). Its not impossible for unloader valve to be bad but it usually is a dependable component. Make sure the unit has the air purged from it properly before start-up, make sure there are no obstructions before the trigger, then the nozzle. The unloader valve just puts the pump into by-pass until the trigger is depressed.
Apr 10, 2009 | Mi T M WP-2700-4MHB Pressure Washer
Mi T M Mitm 3500 Psi Hotcold Portable Gas Pressure Washer Logo
73 people viewed this question
Top Mi T M Garden Experts
JOHN LAPIER
Are you a Mi T M Garden Expert? Answer questions, earn points and help others
