Question about Refrigerators
Water sitting in bottom of refridgerator and won't drain
  • 10,421 Answers
Hi, Your drain line is clog up. Please clean it then.
Regards
Posted on Mar 23, 2011
Amana refrigerator A4TXNWFWWO1 >top freezer, bottom fridge it's only 10 months old refrigerator won't get colder than 55 degrees freezer is working
There is something plugging the drain line in the freezer which carries water from the defrost cycle to your evap drain tray in the bottom of your fridge. The water has built up and froze plugging the flow of air from freezer to fridge.... find the line and unplug it and let fridge sit and thaw overnight and then some more.
Jul 19, 2011 | Amana A4TXNWFWW Top Freezer Refrigerator
Won't drain. Water sits in bottom during all cycles. Water back up to sink.
Run your garbage disposal and sink water for a few minutes in case there is anything clogging the drain. Also look under your sink in case the drain hose is kinked. That hose might also be clogged but is a difficult job - maybe pro help is needed if you are not comfortable doing it yourself. Last option is that the pump is bad and must be replaced
Jul 08, 2011 | Dishwashers
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
Kenmore Refridgerator leaking water into refridgerator compartment from freezer compartment
You most likely have a clogged drain. When you freezers goes into defrost every 8 to 10 hours. The frost that is melted during the defrost drains from the freezer either down through the fridge or out the back and down. Either way it drains into a pan under the fridge. This tube is either clogged or the drain it's self inside the freezer is. Most of the time I find peas stopping the water from draining from the freezer. When the water can't drain it leaks through the bottom of the freezer into the fresh food section of the fridge. You will need to fix this because it will cause other problems. The water that cant drain from the freezer refreezes and will end up destroying the foam in the bottom of the freezer. Water will also leak onto the controls located in the part between the freezer and fresh food section ruining you controls.
Please rate this solution
Sep 01, 2009 | Kenmore Refrigerators
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
REFRIDGERATOR LEAKING WATER ON THE FLOOR
HI. This may be a drain pan issue.
The drain pan should be removed and cleaned at least once a year. The drain pan is located at the bottom of the refrigerator behind the front grill. Remove the grill, which snaps into place. Grasp the drain pan while pulling slightly upward and forward.
Clean the pan with warm soapy water or warm water and baking soda.
If the pan rattles when it is replaced, it is too close to the compressor. Simply reposition the tray.
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve. The hoses may be loose here.
Jun 30, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water in refridgerator interior
sounds to me that your drain line in the back of the refrigerator is clogged up. Take a wire and around 2 gallons of hot water and clear it real good.
Mar 20, 2009 | Camco Battery Fridge Refridgerator Alarm...
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Is there a water resivior/catch under the TFR22PR refridgerator?
towards the bottom inside the fridge, you will find a gulley with a drain in the middle. this drain is blocked. push something flexible down the drain till water flows away freely
Oct 20, 2008 | Refrigerators
GE refridgerator
If the unit has an ice maker or water dispensor, etc. there's always a chance a connection is loose or a valve is leaking by. If no other water is hooked up to the refer, then the defrost cycle water that should drain down to the bottom underneath pan is what is likely. You may have to take the inside rear panels off to see if the drain line is plugged up, that would allow water from the defrosting of the coils to drip inside the fridge vice outside like it should.
Jan 02, 2007 | GE GTS12BBPLCC Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
