Question about Jandy Laars Lt 400,000 Btu Heater
Jandy Laars LT 400,000 Pool/Spa heater. Blows fusible link. What could be the cause?
  • chuck281 Mar 23, 2011
    This is a natural gas heater, not electric.
    Genius:
  • 1,400 Answers
Hello
You need to check the amperage draw of the motor,The only possibility is a shorted winding in the motor, or a bad motor.
Also check for correct voltage to the motor after the fusible links.Make sure the links are the correct size also.
Voltage and FLA or full load amps should be marked on the motor.You need to be within 5 to 10 percent of that number.
Posted on Mar 24, 2011
    Guru:
  • 1,833 Answers
There is a problem in the heating element. The element is short circuit. Please check the heating element. See if water or any conducting thing is shorting the element. This will solve the problem
Posted on Mar 23, 2011
2 Suggested Answers
  • 2468 Answers
SOURCE: Jandy LAARS LT pool heater blows out the fusible
check for a heater that is leaking current to the water jacket and this would be a ground and if enough current leaks to ground it will open this link you can check this by undoing the heater,then if its ok then you know its the heater or by checking with an ohmmeter
Jandy Lars LT fans doe not turn on and error flashes hi limit
check safety circuit and see if high limits are corroded also see if fusible links are tripped
Nov 27, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
How do u remove hi limit switch from a Jandy LX 400N-L heater model#LX400N-L
high limits are located at header where pipes go in underneath
if those are ok check fusible link maybe 2 one at bottom one at top under top cover
Aug 15, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Hi exhaust temp reset for laars LX heater
check gas pressure then replace hi temp fusible link down at bottom
Apr 20, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy LAARS LT pool heater blows out the fusible link. What could be the cause?
Mar 23, 2011 | Jandy Laars Lt 400,000 Btu Heater
Laars LT - "red" light
means calling for heat if heater doesn't come on check safety circuits
Feb 12, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Is it possible to replace the jandy air flow switch
yes you can buy all the parts for the heater here:
http://www.parts4heating.com/Pool-Heaters-Teledyne-Laars-LX-LT-s/435.htm
Specifically this is the part for a heater built after 2003
http://www.parts4heating.com/SearchResults.asp?Extensive_Search=Y&Search=R0302000
Feb 23, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Hi Lim SW fault when trying to heat pool.It is a Laars lx 400,000
heater over heated check gas pressure then replace high limits also make sure chemicals in balance
Jun 06, 2009 | Jandy Laars Lt 400,000 Btu Heater
Jandy Laars Lt 400,000 Btu Heater Logo
151 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
