Question about HP Office Equipment & Supplies
I turn the printer on and it comes up with ink access door open however it is all closed
    Sergeant:
  • 223 Answers
Thank you for using FixYa
The answer depends on the model. For more than one HP model I found that you can press hold the "#" and "6" as you power up the printer.
For the HP2175 follor this link to bypass the access door--
http://www.ehow.com/how_6747415_close-access-door-hp-2175.html
I hope this was useful and please comment if this was helpful to you.
Posted on Mar 23, 2011
Ink door open meassage
Open cartridge access door, observe left side door switch located, manually operate it feel weather its working or not, close door & check.. not rectified, insert peace of paper in it. check...
Feb 02, 2012 | HP Photosmart C6180 All-In-One InkJet...
Error Oxc18a0001 System will not let me print says original cartridge bl., lt.bl. (just replaced), red, yl., need replaced but when checked still have lots of ink in them. & keep getting flashing...
Follow this steps..
Reminder before troubleshooting ...
Make sure that the printer is on. Make sure that you are using HP genuine ink cartridge. Be careful of cleaning the inks and touch w/ your fingers, its very sensitive!
Solution #1 Clean all the inks
  1. open the cartridge access door.
  2. take out all the inks that you have on the printer. (put them on the table upside down)
  3. get a wet clean cloth.
  4. on each cartridge you need wipe it out the electrical contacts on the ink cartridge it self.
  5. put the inks back in to the printer.
  6. close the cartridge access door
  7. turn off the printer
  8. unplug/disconnect the power cable
  9. wait for 1min.
  10. plug the power cable back in back in to the printer.
  11. turn on the printer.
  12. access the setup menu (press the wrench icon on the printer or setup button)
  13. Go to tools, then look for clean printhead
  14. align the printer.
Solution #2 Clean the printhead manually make sure that the printer is on.
  1. Open up the cartridge access door
  2. Take out all the inks that you have on the printer. (put them on the table upside down)
  3. Once you have take out the inks.
  4. Take out the printhead (printhead is the one that holding the inks)
  5. look for the printhead latch. (pull it up)
  6. Take out the printhead.
  7. Clean the electrical contacts of the printhead using a wet clean cloth again.
  8. Put the printhead and the inks back in to the printer.
  9. Close the cartridge access door.
  10. turn off the printer
  11. unplug/disconnect the power cable at the back of the printer.
  12. wait for 1min.
  13. plug the power cable back in to the printer
  14. turn on the printer.
  15. repeat cleaning and aligning the printer by going to tools under setup menu (wrench icon).
If you still having issues w/ it call HP printers support department 1-800-474-6836
Good luck! :)
Jan 31, 2011 | HP Office Equipment & Supplies
Where are the ink cartridge located on machiney m
The ink cartridges are only accessible when the printer is on. Open the access door on the right front of the unit. (flip the door down by pulling from the side of the printer). If this is a new unit or one that has been packed for transport, remove and save the green protective part. Unpack your new cartridges and turn the green knob on the yellow protective cap clockwise until you here a click. Then pull the cap straight out away from the cartridge. Use the arrow to line up the cartridge with the appropriate slot and push the cartridge into the printer. Push the cartridge forward until it clicks. (Repeat for the rest of the cartridges.) Then close the access door.
If you are replacing cartridges. Open the access door and push down to unlock and release the cartridge you need to replace. The other directions are the same.
If the cartridge carrier doesn't come to the ink access position, close the access door and make sure the printer is on. Check for an error code on the unit. (Clear any paper jams or foreign objects that are blocking the cartridge carrier from moving properly. See the URL below for troubleshooting details.)
You can get the manuals from Brother: http://www.brother-usa.com/mfc/modeldetail.aspx?PRODUCTID=mfc295cn .
I hope this helps.
Jan 12, 2011 | Brother MFC295CNAll-In-One InkJet Printer
Printer error code 3820
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Gently hold both sides of the carriage, located immediately behind the printhead, and make sure the carriage moves freely.
  4. If the carriage does not move freely, contact us.
  5. Remove the printhead and ink cartridges.
  6. Reinstall the printhead and ink cartridges, making sure each clicks into place.
  7. Connect the power adapter to the printer.
  8. Turn the printer on, if necessary.
  9. Close the printer access door.
aFor more help visit cbrtechsolutions
Dec 05, 2010 | Kodak ESP 5 Printer
Printer says there is a paper jam and there is no paper in there.
first thing you need to do is will do the overriding the error
1. open the pritner access door fo the printer
2. if the printhead or ink cartirdges already in center remove the ink cartridges and the printhead
3. If the printhead already removed close printer access door., Turn Off the pritner then after 10sex turn It own.
4. Now your pritner should detect no printhead installed not paper Jam., If you still recieved paper jam error without the pritnhead installed you need to have a printer replacement call kodak toll free number 1 800 421 6699 ext 05
5. Now if the message is pritnhead not installed., reseat the printhead and the ink cartordges then close the pritner access door., If your ecived same message paper jam., You need to replace the printhead you may also call kodak 1 800 421 6699, and have your free printhead replacement.
Most of the time overriding the error message solve the problem
Nov 17, 2009 | Kodak ESP 5 Printer
I have a kodak 5500 aio printer. I replaced the
Try the following:
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Blinking orange light on hp 932c
Solution
  1. Check to ensure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom.
Solution two:
  1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
  2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
  3. Turn the printer on.
Solution three:
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Turn the printer off, then on again.
4. Replace the ink cartridges.
5. Close the top access door.
Solution Four:
Issue
The 2-Sided Printing Module is installed incorrectly, not at all, or the back access door is unlocked or open.
Solution
1. Turn the knob on the rear access door of the printer counter-clockwise, and remove the door.
2. Insert the module into the back of the printer.
3. If the lights remain on, remove the 2-Sided Printing Module by pressing in the buttons on the ends of the unit.
4. Re-install the 2-Sided Printing Module by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
Jun 17, 2009 | HP DeskJet 932c InkJet Printer
HP C7280 Printer not priting wirelessly.
Solution Replace the indicated ink cartridge(s), or press OK on the control panel to continue. HP recommends the use of genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help produce great results, time after time.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage due to the use of non-HP ink will not be covered under warranty. Follow these steps to replace the depleted HP ink cartridge(s). Step one: Replace the indicated cartridge(s)
  1. Make sure the HP All-in-One is turned on.
    NOTE: The Attention light blinks when the product is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the door locks into place. Figure 1: Opening the access door c01079714.jpg
  3. Squeeze the bottom of the latch below the ink cartridge to replace, and then lift the latch.
    • To replace the black ink cartridge, lift the latch on the far left.
    • To replace one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    Figure 2: Lifting the latch c01079715.jpg 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
  4. Pull the ink cartridge towards you out of its slot to remove it. Figure 3: Removing the ink cartridge c01079716.jpg
  5. Remove the new ink cartridge from its packaging.
  6. Holding the new ink cartridge by the handle, push the ink cartridge into the empty slot. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage. Figure 4: Inserting the new cartridge c01079717.jpg
  8. Close the access door. Figure 5: Closing the access door c01079719.jpg
Step two: Align the new ink cartridge(s)
  1. Make sure paper is loaded in the input tray, and then press the OK button. The HP All-in-One prints the alignment page, aligns the printhead, and initializes the ink cartridges. This takes approximately 5 minutes. CAUTION: Do not disconnect or turn off the HP All-in-One during this time. You may hear the HP All-in-One making noises.
  2. Check the display for status, and then press the OK button. Recycle or discard the alignment page.
Cause The original HP ink in the indicated ink cartridge(s) has been depleted.
May 24, 2009 | HP Photosmart C7280 Laser Printer
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
mukhtar21 shaikh
mukhtar21 shaikh
