Question about Craftsman 3 gal. Air Compressor, 1 hp, Tank
Will pump up to #40 and thats it but it keeps running and wont shut off. it gets so hot you can smell it
I have the same compressor and had the same problem at 40 psi.
If your air compressor builds pressure to a point, and then won't go any higher, check your gaskets. If you take the compressor apart, be prepared to replace the gaskets as they are brittle after use and most likely will tear.
Check the gasket that divides the chambers by the air intake. Make sure that there is no part of the divider gasket missing. Even a small gap can cause pressure to cease building. This is what happened to mine. It is the top gasket as you take the top off where the copper tube comes out. You can buy replacement gaskets for most brands, or you can buy a sheet of gasket material at an auto parts store for under $10 and cut your own. Try to keep the old gaskets in tact as much as possible to use them as a template.
Posted on Apr 17, 2011
    Sergeant:
  • 259 Answers
It could be faulty rings on the compressor. The reed valves may not be operating properly have to be cleaned. You could have a slite leak like a bad head gasket or leaky line. You can check that with a soap water solution around the head and fittings. If you have a leak you would see bubbles.
Posted on Mar 23, 2011
My pump and filter work great for aa hour or more then the pump keeps running, but isn't pumping water through filter. We shut off the power and turn it back on and it works great for a while.
make sure filter grids where cleaned with TSP tri sodium phosphate to degrease them then recharge system filters are locked or try on recirculate if ok then clean filters if not pump seals getting hot and pump not working correctly
May 19, 2014 | Hayward EC-40 DE Pool Filter with pump
1997 plymouth grand voyager runs normally but shuts off when it reaches operating temperature, won't start until it cools down. There is a smell of burned rubber, but can't find anything hot or that can...
First thing i would try is to carry a can of WD-40 or quick start with me and when it quits and won't start, remove air intake hose at throttle body opening, open throttle enough to give a good spray inside throttle body, release throttle, then try to start it . If it starts and runs momentarily, you have a fuel delivery problem. If not you have an ignition problem. Then you can start troubleshooting from there.
Or you can carry something to test for spark. I just find this way easier. Don't know when/if fuel pump has ever been replaced, but not uncommon for them to work when cool and quit pumping when they get warmed up, even though they sound like they are still working. That's where a fuel pressure test would also confirm, keeping in mind pressure may read good when first started but will drop later when warmed up and engine quits.
Apr 09, 2011 | 1997 Plymouth Grand Voyager
My hot tub pump is getting loud. And if placed on high I can smell a burning smell, so obviously not being used. I've left it on to keep it heating and the plumber is scheduled for this week. However...
It sounds like the bearings have gone bad in the jet pump. A shaft seal leak will sometimes let water get into the bearings and the motor will get louder and louder. Running it on high can intensify the noise and heat created by bad bearings. Eventually, the bearings will seize and the motor will try to turn and since it can't, it will get really hot. The motor has built in high limits to keep from burning up completely but it will smell like it's burning. I would replace the pump motor and seal, should take care of the problem. The OH may have been caused by the pump not moving enough water to run the heater and tripped the heaters high temp sensor. I hope this helps.
Oct 13, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Won't shut off machine turns off after a few seconds
You may have a burnt motor. This is usually caused by a clog in the pump. Sometimes small items such as socks find its way to the pump. It could also be the timer itself. If there is a burning smell when that happend it is probably the motor.
Jun 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
1992 ford f150 Truck shut down at 60mph and now fuel pumps wont
Where does the fuel come from that leaks out when running? If you have dual fuel tanks and one tank is overflowing you will need to check the fuel tank switch in the dash. Ford had a problem with these that caused the fuel pump from one tank to pump fuel to the other tank and cause it to overflow. If this is the case the tank switch is probably defective.
They can get very hot and melt the wires into the back of the switch. Check the switch first.
Feb 17, 2009 | 1990 Ford F150
Samsung washing machine smell
Keeping the lid shut is one of the worst things you can do for a washer. Obviously, the company you spoke to does not know what they are talking about. It is strongly recommended that you leave the lid OPEN when not in use in order to ventilate the wash tub and allow it to dry. There is always a small amount of residual water in the drain pump and lines, however, that will not evaporate. With the lid shut this residual water can sour and cause odors.
Consumers that do not normally use a HOT water cycle, do not use bleach, or run the washer infrequently can also experience odor problems with mildew and odor. It is recommended that you run at least one HOT cycle per week, or run a cycle with bleach when washing whites to keep bacteria and odors to a minimum. I hope this advice helps you. Let me know if you require further assistance.
Oct 25, 2008 | Washing Machines
1995 Dodge Neon
the daytime runnling light module is in the dash under cigarette lighter i got my module for 10 bucks at a junk yard
Aug 15, 2008 | 1998 Dodge Neon
1995 Dodge Neon
you have an electrical short somewhere....id get it to a dealer or other expert and have it fised beofre it burns something up
Jul 25, 2008 | 2005 Dodge Neon
Craftsman 3 gal. Air Compressor, 1 hp, Tank Logo
699 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
