Question about HP Office Equipment & Supplies
My hp printer 209a gives me a printhead error problem. already tried cleaning, resetting printer, unplugginng, etc. still getting error
  • 2692 Answers
SOURCE: My HP officejet 9110 all in one say REPLACE YELLOW PRINTHEAD
Here is the link for the program for cleaning the printheads on your model printer:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=376170&prodTypeId=18972&prodSeriesId=376170&objectID=c00068412#A1
Posted on Feb 16, 2009
SOURCE: HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Posted on May 01, 2009
ingenito
  • 11 Answers
SOURCE: How do I clean the HP designjet 110plus printhead
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
Posted on Jun 20, 2009
  • 23 Answers
SOURCE: How do you clean HP 6940 printhead?
Remove the ink cartridge and gently clean the printer head (shiny silver wafer) with hot water, glass cleaner, or isopropyl alcohol and a cotton swab. Run the HP head cleaner with the software that was supplied with your printer afterward. Visit HP.com if you need the software or your user manual.
Posted on Sep 29, 2009
SOURCE: HP C7180 how do i do a cold reset for this printer?
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
NOTE: E_M_R_E_7@HOTMAİL.COM
Posted on Jan 25, 2010
HP Photosmart B210a error message
Simple. Remove the ink and printhead. You can remove printhead by pulling gray latch up and sliding printhead up and out. Clean printhead gunk off using warm running water. Remove any ink gunk on the right side of printer if you see any. Turn printer off and on. See if problem went away. If it did, try putting the cleaned printhead inside printer again. If problem comes back, seems like the issue is with a bad printhead. Below are video instructions on cleaning head manually. The printheads are not same. B210 printhead is not the same with HP 6500, but instructions are same.
Jun 07, 2017 | HP DeskJet F4280 All In One Printer InkJet
HP Photosmart C6280 - Where is the printhead???
ALWAYS USE HP CARTS....HP IS REAL FINNIKY ABOUT AFTER MARKET CARTS...
Dec 05, 2012 | HP Photosmart C6280 Printer
Hp 6500a plus printhead won't print
As you said that you have already cleaned the print heads it could be the contacts inside the printer has gone bad. Its suggested by HP that if you get any error regarding the print head you should contact them and they will replace the printer. Please do so. Thanks.
Dec 19, 2011 | HP Officejet 6500 Wireless All-in-One...
HP PRINTER C6280 problem says ink system failure error 0xc18a0001
Reset the printer:
With the product turned on , disconnect the power cord from the rear of the product.
Wait at least 15 seconds.
Reconnect the power cord to the rear of the product
Remove, clean, and reinstall the printhead
remove ink cartridges
Figure 22: Lift the latch handlec01481823.jpg
Lift the printhead straight up to remove it.
Figure 24: Three areas to cleanc01481825.gif 1 - Plastic ramp on the side of the ink nozzles
  1. Figure 29: Clean the electrical contacts inside the productc01676244.gif
  2. Dry the area with a clean, dry, lint-free cloth.
Reinstall the Printheads and the cartridges
Reset the product
It should work otherwise try to replace the Printhead and instead change the entire printer its time to change it
Feb 26, 2011 | HP C6280 All-in-One Printer
I had my ink cartridge refilled, and now the
just clean the printhead contacts
if you see no result
you must change the cartridge
Apr 02, 2010 | HP DeskJet F4280 All In One Printer InkJet
The following printhead ha a problem: magenta/cyan[m/c]. we have changed the ink cartradige and are still get the same error
depending on which model printer you have it could be an issue with the printer itself.
try cleaning the copper contacts on the printhead itself, do not touch the nozzle as you may accidently clog the printhead.
clean the copper contacts in the carriage as well..... distilled water is best but bottled water works too.
if this fails to clear out the error message try resetting the printer
other wise it maybe an issue with the printer itself and call the manufacturer
Mar 27, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Help with my k5400
It's possible you have one of the following problems:
  • Printhead is faulty
  • The printhead has expired (HP printheads have an expiry date which is written into the chip)
    In both of these cases contact HP support to request a warranty replacement (but try the ideas below first obviously :))
  • The printhead hasn't been inserted properly
  • The chip contacts are dirty or soiled in some way
    For these last two, try removing the printhead, cleaning the chip carefully with a cotton bud and then replacing carefully.
It's also entirely possible that you've been sold a lemon in which case you need to call the store you bought the printer from and get them to troubleshoot the issue with you and/or replace it/refund your money.
Hope that helps.
Jun 11, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
Mar 26, 2009 | HP Photosmart C7280 Printer
Oct 18, 2008 | HP OfficeJet D135 All-In-One InkJet...
Error: The type of Printhead is incorrect, Install the correct printhead.
Ok i know this is kinda old, but i found a solution.
First to those people to state I found a solution from hp, cannon etc etc and not give out the direct link, or instructions, then whats the point fing posting????
This error happens when you install an oem cartridge onto your system. Or havent used it in a while, so the machine is somehow misfigured.
This solution is for canon mp800, simply switch off printer. HOLD stop/reset and press and HOLD on/off button. release stop/reset. Now press stop.reset twice. then release on/off button, press stop/reset 4 times, wait 20 seconds, press on/off button twice.
switch machine back on and the printer should find the cartridges.
This method maybe the same for your mp*** if not google RESET CANON PRINTER MP*** and you'll find the correct buttons to press.
here's a printer on reseting a bunch of canon printers http://tricks-collections.com/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp610-mp800-mp820-mp810-mp830-mp960-mp970/
good luck.. and FU canon for adding you scamming chips into cartridges.
Mar 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
114 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
