Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
Briggs & srtatton classic 35 mower the engine starts but runs very slowly
  • 225 Answers
SOURCE: Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Posted on Jun 21, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
  • 110 Answers
SOURCE: where can i get a manual for a briggs and stratton
You can download a manual for the engine from Briggs & Stratton's web site - you just need the numbers off the blower shroud. No manual exists for the actual mower.
Posted on Sep 22, 2009
  • 4 Answers
SOURCE: Briggs & Stratton Quattro lawn mower
computerscot is right. This engine is not designed to run slower than a few hundred RPM below maximum. The carb has a built-in fuel pump that only operates properly at relatively high speed. Your motor probably has either missing or weak throttle springs which will lower the RPM. Replace them and adjust the tension so that the speed is up. For a diagram of the carb and springs, check the Briggs & Stratton online user manual maintenence section. Look for file "briggsandstrattonMS5373-GB.pdf".
Posted on Oct 30, 2009
What is the running position for the choke lever on my Briggs Stratton 35 classic engin
on the oldie but goodie briggs engines it's easy to look right down the air intake collar while its running and see the choke plate , straight up is the run position
Aug 27, 2015 | Garden
How do I set the choke on my Briggs Stratton 35 classic engine.
Allow the mower to cool overnight.
Check the choke to see it is closed.
If not adjust it just until it is closed.
Then start the mower and warm it up. Check the choke again, it should be fully open.
If not the parts are defective and need to be replaced.
Briggs & Stratton 35 Classic. How to fit the cable to drive the tines. Help!
briggs and stratton 35 classic is the model of engine not the rotavator
May 06, 2015 | Briggs & Stratton Garden
Servicing a briggs & stratton 35 classic
Clean exterior of engine and frame. Remove and sharpen blade. Clean blade compartment, scrap off old residue and wire brush. Repaint if necessary. Replace spark plug with new. Drain oil and replace with new - DO NOT OVERFILL!!. Replace air filter with new after cleaning filter compartment.
Jun 30, 2014 | Briggs & Stratton Garden
Briggs and stratton 35 classic. Need piccy of arrangement of carb/choke links and springs as think someone has changed them and mower no work. Model 9D902. Lever which may be choke, does not stay in place...
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
Apr 25, 2011 | Briggs & Stratton Briggs Stratton...
Champion 35 Classic lawmnower with a 3.5hp briggs and stratton engine. Engine starts fine but will not run regularly.Keeps revving and then dying back and then revving again continuously.
Check the governor spring and throttle linkages, something may have come adrift. Also check the throttle shaft and body for wear and excessive clearance which could **** in excessive air, upsetting the mixture.
Apr 17, 2011 | Briggs & Stratton Garden
Briggs & stratton 35 classic mower.(mcculloch m3540p) starts rarely and only 4 a short time. Shows spark at plug fuel getting through air filter ceaned.(tried without air filter to no avail.checked...
With the air cleaner removed, see if the engine will run for even a short time when you give a couple of quick squirts of starter fluid into the carb.
If it runs with that, the orifices inside the carb are dirty and need the gunk cleaned out.
Before extended storage, always drain/use up all the gas in the tank and run the engine til the carb runs out of gas.
Sep 21, 2017 | Garden
I got a 6.0 hp Brigg & Srtatton the spark plug keeps failing I need help I just had the carb rebuilt
if the spark plug is failing due to build up and you have to keep taking it off and cleaning it then you have some oil blowing by the rings causing the spark plug to get to hot and quit working, put a new spark plug in and then start it let it run for a few minutes then shut it off check spark plug if there is oil on it then you will need to overhaul the engine its not that expensive
Oct 29, 2009 | Mtd 22" Yard Machine Push Mower
Where can i get a manual for a briggs and stratton pwr400prma 35 classic petrol rotary mower
Sep 12, 2009 | Garden
Briggs a stratton 35 lawn mower
Turn the mixture screw on the carburator slowly counter clock wise till the idel stabalizes.
Jul 01, 2009 | Champion International Champion& Small...
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
78 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
