Question about Garmin nuvi 205 GPS Receiver
Hi, I have a Nuvi 255 (205 series) gps, three years old. Last week the screen went blank, came back grey with 'crosshairs' and a black dot in the middle indicating 'press here'. I did so and the dot moved to each corner of the screen advising to 'press here' (the black dot). The gps then indicated it was re calibrating. When the map came back I had lost all my data and the map had lost all it's detailed mapping and only showed major highways. Further if I attempted to navigate to a location using the 'Where to" it indicated 'No data available'. When the gps is turned on I get a screen which says "No detailed maps found that support routing. The Nuvi cannot be used without them". I downloaded a plug in from garmin and attempted to download a map update which took several hours and seemed to be downloading but in the end no mapping was actually downloaded onto the gps. Thanks Graham
  • Garmin Master
  • 3,289 Answers
Graham - what your describing sounds like you somehow managed to erase the street level maps and POIs in your Nuvi.
If you connect the GPS to the computer with your USB cable, you should at the contents of the Nuvi directories and find a file called GMAPPROM.IMG or GMAPSUPP.IMG. These are the street level map files. Generally, these are found in the root directory of the Nuvi - or if yours has / and you use a memory card slot for maps - find it in the /GARMIN directory. GMAPPROM.IMG is the name of the first map set and GMAPSUPP.IMG is the name of the supplementary or second map set (if you purchased & installed one). You will likely have only one of these files - and may be named either. The size of this file depends on the area and age of the map. Current maps of the entire US run over 1 GB in size. If you do not have any maps named GMAPPROM or GMAPSUPP, you will not see any street level maps.
Something happened to delete the maps. Garmin will probably NOT provide free replacement maps for you, unless under warranty. If the devices is trashing maps and other files, you probably want to replace the unit under warranty or not. Garmin will, upon return of your old Nuvi - replace it with a factory refurbished unit with the latest maps installed, for $79. You can take advantage of this service by following this link to Garmin Service.
I hope this helps and good luck! Please rate my reply. Thank you.
Posted on Mar 23, 2011
Screen went blank and when we restarted it the screen comes up as if you're restarting from the beginning when you touch the onscreen icons the screen is locked. How do I unlock it?
its a common occurance on this unit. send it back. it blows fuses, screen maps goes blank with only square dots and no streets. the refurbished units also have these problems.
Sep 20, 2010 | Garmin nuvi 255W GPS Receiver
The Garmin Nuvi 1300 was working gret. It was a Chrismas gift. It just stopped working it will not come on at all the screen is blank black. No signal will not turn on at all. Did not drop it or and other...
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 11, 2010 | Garmin nuvi 1300 Car GPS Receiver
The Garmin Nuvi 1300 was working gret. it was a Chrismas gift. It just stopped working, it will not come on at all the screen is blank, black. No signal will not turn on at all. Did not drop it or and...
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Mar 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
Nuvi 1300 squeal
I hope that helps.
Jan 06, 2010 | Garmin nuvi 1300 Car GPS Receiver
My Nuvi 200 screen went black. I've tried turning
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Oct 28, 2009 | Garmin nuvi 200W GPS Receiver
Please HELP! For the last week, my nuvi is
I had the same problem. I called customer support 1-800-800-1020
and they were able to go into my nui by linking to my computer. It was pretty amazing to watch! Hope this helps!
Sep 21, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 750 frozen on prss dot screen
maybe a factory reset - but connect to computer and try to back up your stuff since it will erase it all.
Oct 20, 2017 | Garmin nuvi 750 GPS Receiver
Buttons on screen jump around
Ok I have a few questions. When you mean it jumps around do you mean:
1. When you press a 3, the 3 button becomes a 7 graphically or
2. When you press a 3, the 7 button is highlighted and chosen.
The first thing I would do is try to recalibrate your touchscreen by pressing the wrench symbol, then the display icon and select calibrate screen. Press the series of dots as you are asked to do and see if that clears up your problem.
If that doesn't work, then I would do a reflash/ugrade of the firmware. Perhaps the firmware is corrupted. This can be done by dowloading Garmin's webupdater at www.garmin.com and connecting your Nuvi to your PC and letting the program reflash your firmware.
The last solution is to replace the touchscreen. Are you sure the screen is not cracked anywhere? A cracked screen will certainly cause a touchscreen to either not work or activate another button when pressed.
- Jim
SHARCNET-USA
If that doesn't
Dec 09, 2008 | Garmin Nuvi 660 GPS Receiver
Full charge lasts just under 3 hours
The battery life is advertised as THREE to 7 hours. Try reducing the backlight time. You're within factory specifications.
Apr 25, 2008 | Garmin Nuvi 660 GPS Receiver
My ? Nuvi 710 GPS froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it...
My ? Nuvi 710 GPSicon1.png froze. I restarted it , now all I can get is a blank screen with a black dot in the bottom left corner and a message saying press dot. Holding the off switch over to the left makes it restart but still goes back to the same screen Is there any way I can fix this?
Apr 22, 2008 | Garmin GPS
Garmin nuvi 205 GPS Receiver Logo
445 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
