Please describe my canon ir 4570 code 602 413 problem:
SOURCE: E-602-00002
Error E000602-0003
Posted on Feb 08, 2009
  • 153 Answers
SOURCE: can any one help me canon ir 4570 service manual.
yeah ring canon and try and get one
Posted on Apr 01, 2009
marketex
  • 371 Answers
SOURCE: canon ir 8500 error code 001-010 and E 001-003
You can start by downloading this software, a new driver dated April 7, 2009
canon driver for the ir 8500
Posted on Apr 15, 2009
guru_dev
  • 315 Answers
SOURCE: error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Posted on Jun 01, 2009
n25an
  • 622 Answers
SOURCE: image runner 4570
it might just be a power spike in which case your machine just shot an error while it protected itself...
try the following...
press additional functions
press 2 and 8 at the same time
press code error
press copier
press function
press clear
press error
press ok
press reset
if that doesn't work then call a tech... it might be very serious...
Posted on Dec 21, 2009
E0002250001 canon 4570
Disconnect and than connect the flexible cable,if not okay,replace it
Jun 27, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Jam code 205 in canon Ir 4570
Try to open up the copier where usually the paper goes through and check for any remains of bits of paper.
PS: on the screen shows which side of the printer has to be opened.
Feb 24, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Canon ir 4570
Fuser unit / fixing unit problem check whether fuser sleeve is damaged if yes change it or apply fuser oil and white grease on it for smooth rotation....
Jun 24, 2013 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Canon ir 3570/4570 reference guide
Hi
My self Rishi Dhiman
if u want to active ur optional copy tray in ir 4570/3570/2870 machine than first of all u have to enable it ,
Go to additional function/ common setting / tray desination/ here u can select tray which u want to use
If u not get the opiton of tray desination in common setting of additional function, than u have to active it from service mode
press * 28* for entering into service mode after that click on copier, now click on option >acc>out tray press here 1 and do it ok, now u have to restart u machine one time after that opition of tray desition is avilable in common setting, nd there u can set u output tray,
caution : this method is decrease the speed of machine paper output
Any Query about this u can post it again here on this website
Oct 11, 2012 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Help what is this code e000191-000
Jam Code 205 in Ir-4570 solved by replacing sensor PS-59 Arm
Oct 08, 2012 | Canon Imagerunner 4570 Copier
Canon copier 4570 error code e000007-0000
canon ir 4570 error solution for Code E000007-0000
Nov 25, 2010 | Canon ImageRUNNER 3570 Copier/Printer
41 people viewed this question
k24674
jasbo
jasbo
