Question about Dishwashers
I have an LG dishwasher. Model LDF7811BB. It is giving me an F3 error code.
  • Greg Smith Mar 23, 2011
    the pump was clear. still having the same problem
  • Greg Smith Mar 26, 2011
    Thanks
    President:
  • 1,140 Answers
Are you sure it's F3? As far as I know, F3 is not an error code listed for this model or any other LG dishwasher. However if it's FE (looks similar), it's an overfill fault which may require the water inlet valve/solenoid to be replaced. If the error code displays shortly after starting a wash cycle when it's filling with water, I suspect the code is FE.
Please can you check the error code and get back to me. If it's definitely F3, you'll probably have to ask someone else as I've never seen this error code and I wouldn't know where to start.
Thanks,
BElectric
Posted on Mar 23, 2011
  • 10,865 Answers
Hello bien.... your pump impeller is probably jammed with broken glass or some other hard debris. To fix it remove the grille cover at the back of your DW and clean out the debris. The impeller is a fan like pump so with your fingers make sure it moves in a circle freely then reassemble the grille and, it should work fine. Joe
Thanks for choosing Fixya!
3 Suggested Answers
kdrake84
  • 262 Answers
SOURCE: I have an LG dishwasher. Model LDF7811BB. It is
here are the fault codes I have come up with for your dishwasher.
Please double check what you are reading.
In he maen time I will double check mine and let's see what we come up with ok?
LG Dishwasher Fault Codes 1E Water Inlet Not reaching proper water level within 10minutes.Check water inlet valve resistance 950- 1300ohms. Check water inlet for clogs. Replace Air Braker DE Drain Error Check drain for clogs. Check drain motor for resistance 20- 40 ohms. Replace drain motor E1 Leak Check for leaks if none found replace impeller of washing motor FE inlet valve Clean and / or replace L- E Motor working abnormally Motor working abnormally Check motor connections. Check resistance of thermistor 11-14 ohms at 77 degrees Replace PCB
Posted on Feb 15, 2011
GodBlessU
  • 3513 Answers
Hi
Check properly if you have seen E5 error code or something else,Giving bellow are the lists of LG dishwasher error codes and their solutions.
LE error code = Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor. Press and hold the "Start/Pause" button on the front panel for five seconds. Plug the LG dishwasher back in. Run a cycle. The LE code will clear.
IE= The "IE" error code indicates a problem with the water inlet. The water supply valves are not turned on fully or the inlet hoses are kinked, clogged or frozen. Remove kinks in the hoses and remove clogs with a straightened coat hanger. If this does not resolve the problem, contact a service technician.
OE= A drainage problem causes "OE" to be displayed on the digital display panel. The drain hose is likely kinked, clogged or frozen. Inspect the hose and remove kinks. Unclog the hose, if needed. Replace the hose if the problem is not resolved. If the dishwasher still does not drain, contact a service technician to inspect the dishwasher and determine the problem.
FE and E1= "FE" is displayed if the dishwasher is supplied an excessive amount of water. The "E1" error code means the dishwasher has developed a leak. Turn off the water supply valves and contact a service technician to repair the dishwasher.
HE= The heater circuit has failed if "HE" is displayed. Discontinue use and contact a service technician. The dishwasher requires servicing.
TE= "TE" means the thermistor has failed or the temperature of the water entering the dishwasher is over 194 degrees Fahrenheit. Turn the temperature down on the hot water heater in the home. If the error code reappears, replace the thermistor.
PF=The dishwasher displays "PF" to indicate there has been a power failure. This is not an error code. The dishwasher automatically restarts 10 seconds after the code displays.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 04, 2011
Code f1 f3 f6
virtual machine - VNC send Ctrl+Alt+F1-F6 to server - Unix ...
unix.stackexchange.com/.../vnc-send-ctrlaltf1-f6-to-serv...
Stack ExchangeMar 15, 2012 - Hence I can switch to the TTY's if my CTRL + ALT + F1 - F6 ... As I understand it, you want to send CTRL-ALT-F3 to the remote .... What numeric keycodes do I need to send for the magic sysrq functionality in a VNC session?
error code f1 dishwasher model gldt696tss 00 KVM Switches
www.fixya.com > ... > error code f1 dishwasher model gldt696tss 00
KVM Switches error code f1 dishwasher model gldt696tss 00 questions and ... 6F 23 20 F1 01 = F2 46 B1 59 04 61 77 71 Telewest 00 = 75 4A 66 04 CF 7F 55 F3 ... ...96 F6 1F C4 01 = 6D EA BE 97 6A AA DA 71 NTL 54 01] 07/10/09 00 = F0 ...
kleenmaid f6 code KVM Switches Questions & Answers - Fixya
www.fixya.com > Forum > Tags > kleenmaid f6 code
KVM Switches kleenmaid f6 code questions and answers. ... 01 = C6 64 1D EF 47 5A 0E EF tellywest 00= B7 DE 73 DE 2F A4 F3 BO 01= FA 4B 82 4C ... ...in bradford area plz 5a 01 83 5D 12 B8 96 F6 1F C4 6D EA 8E 97 6A AA DA 71 Hope ..
Jan 27, 2016 | Computers & Internet
Samsung dishwasher dms500trw. what does error code f3 mean. i just replaced the hose after e2 code now 2 weeks later i have f3 code?
Samsung DMS500TRW - ProductReview.com.au
www.productreview.com.au > ... > Dishwashers > Freestanding > Samsung
Rating: 2.4 - ‎49 votes
2.4 out of 5 stars for Samsung DMS500TRW in Freestanding Dishwashers (page 2). ... The machine gives an E2 error and will not pump water out. I have to manually cup it out. ... F3 Error. 1 out of 5, reviewed on Sep 30, 2013. Purchased dishwasher in Jan 2012. First broke ... F3 what dose this code mean? Dell asked on ...
Nov 26, 2015 | Dishwashers
My Samsung Dishwasher gives me a error code F3 can you help me
F3 indicates a heating fault.
Unless you are a qualified repair engineer I'd get a professional to look at it. Water and electricity and "do it yourself electricians" don't mix.
Apr 10, 2015 | Samsung Dishwashers
I have a ldf7811bb lg dishwasher it was leaking and has water left in side. whats wrong?
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Mar 17, 2011 | LG Dishwashers
Our whirlpool dishwasher ADP 7408 is displaying a F3 fault and wont work. What is the problem?
F3 error fault code
The heating cycle is not working. The error is indicated after several electronic checks are done over a 25 minute period. Therefore if the heater heats too slowly or the heater is open circuit or indeed the electronic control PCB is defective, each of these will indicate F3. The twist is, if the NTC is fluctuating in its reading it also can indicate F3 and not F1.
Nov 14, 2010 | Whirlpool 33 in. ADP6830 Free-Standing...
I HAVE THE SAMSUNG DISHWASHER dms300trs AND IT SHOWS F3 ERROR ???
Have the same problem with brand new, unused DMS500TR dishwasher. Rang Samsung, they said F3 is a water leak error.
Aug 19, 2010 | Dishwashers
I have a whirlpool sixth sense dishwasher and
F3 error fault code
Aug 25, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
109 people viewed this question
Top Dishwashers Experts
