Question about Solis Master 5000 Espresso Machine
There is a excessive amount of water collecting in the drip pan, and I need to empty the pan every other day. Before it was once every two weeks or so. I have taken the "unit" apart to clean the screens. I know the O-ring is ok, and could not be leaking from there, since the water is mostly clear (with a small amount of coffee residue). I had this machine for years and use it every day. Any advise is appreciated. With best regards Hans Glauser
  • 1,089 Answers
Hi
Excess water going into the drip tray is usually an indication of the grind being to coarse. If your pucks are not solid but just fall apart this is the case. When the grinder is grinding, turn the big knob in the bean hopper down 2 numbers smaller and see if this changed. If you have a second knob in the bean hopper change the to the plus side, but not all the way to the plus. Do this first before you change the grind setting. Excess air between the grind allows more water in the brew unit and when it is done it goes into the drip tray.
Posted on May 08, 2011
I HAVE A MAYTAG AUTOMATIC ELECTRONIC DEFROST CONTROL REFRIGATOR MODEL MSD2272VEB00. EVERY FEW DAYS WATER LEAKED FROM UNDER THE REFRIGERATOR ONTO THE FLOOR FROM WHAT APPEARS TO BE AT THE FRONT RIGHT SIDE...
Mostly the drip-pan can't be accessed from the front.
The drip-pan isn't.
It is in fact an evaporator. It collects the considerable amount of water from the auto defrost function and holds it until the heat from the motor and compressor can evaporate it. The water is transferred from the inside by a drain tube.
A blocked drain tube is not unusual and is generally fairly simple to clear. Often it is a stray vegetable that causes the trouble and sometimes it is a buildup of ice. If the water cannot escape a wet floor is usually the result.
Our fridge recently suffered from the same trouble. I used a plastic covered wire coat hanger to clear the drain of ice - very carefully...
Apr 27, 2017 | Refrigerators
Tip
Refrigerator not cooling-freezer section icing up
Refrigerator not cooling, ice forming on back of side-by-side freezer:
Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to expose iced-over coils. Use a fan to speed up defrosting. Put a towel or a plastic drip pan in the bottom of the freezer to collect melting water (rather than letting the water collect and maybe overflowing in the drip pan underneath the refrigerator).
After defrosting, by temporarily replacing the freezer back panel and turning on the unit, the refrigerator may operate OK for about 3 weeks before the next excessive ice build up.
Possible problem- a burned out Defrost Heater.
To check: After defrosting, turn off power to or unplug the refrigerator.
Unscrew the Defrost Heater bracket (2 screws). When loose, unplug the two wires connected to the unit. Have the unit checked, or use an ohm-meter to check continuity. If unit measures "open", high resistance, replace the Defrost Heater and bracket. If the heating element shows continuity (or low resistance) the heater is probably OK and you have another problem. Now you may need to contact a repair man.
on Jul 06, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Collected water in evaporator pan does not
you obviously live in a high humidity area.(or you are putting warm/uncovered food inside) but the answer is yes,or you could collect the water to use on you indoor plants.........better than tap water...
Jul 08, 2010 | Frigidaire FRT18KB2CW Top Freezer...
Water drips down from Freezer. The water is coming
Since you said the water supply is shut off, the likely culprit is a clogged drain tube that connects the defrost tray to the water collection pan for evaporation at the bottom of the fridge.
The source of the clog is usually either mold growth or more likely, ice build up. Regardless of which, if you access the defrost heater in the freezer section, you can thaw ice that has collected in the tray and if needed, use a turkey baster to direct a hot stream of water at the point the hose attaches to the tray and treat the hose for mold, below.
Once cleared of ice, mix a small amount (5 or 6 oz) of water and 1/2 to 1 ounce of bleach and direct down the tube to kill any mold / growth. Be careful not to use to much or overflow, as clean up will be difficult due to the bleach mixture.
The next thing to do (if icing up) is to determine why. A careful check of the defrost circuit should be done. Otherwise, you'll be doing this over - and it may start to affect the temperatures in the frozen and fresh food sections of the fridge.
I hope this helps!
Nov 05, 2009 | Air Purifiers
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
Water dripping from top of fridge then freezing under crisper's
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Drain pan underneath fridge is filling on a daily basis
The system is designed to evaporate that water using the warmth of the compressor.. is your compressor warm ? (the drip tray sits on top of it) I see that model has an Ic e maker... to check that the ice maker refill is not running on too long, switch off the ice maker, by lifting the wire arm that checks the level of the ice in the storage bucket.. leave it turned off for a day or two.. empty the drain pan, and check it again after 24 hours.. but if the ice is already full, the water problem may APPEAR to be resolved already, but will return when the level drops and the ice production begins again.
If it is just condensate, then the drain pan should be able to contain the amount it produces, but 3-days straight, would indicate to me, that is not that... if your water pressure is good, it may be that the ice tray filler solenoid is being held open a fraction too long (maybe a second or so) and as the fridge is new, it will be making lots of ice to fill the container up,... so lots of small overfills.. mounting up to a full drain pan. Under normal use,.. other than parties and festive nights, when you use a lot, the water should evaporate faster than it is produced, but it shouldn't be happening at all.. if it is that, then turn the tap at the back of the fridge to where the cold water dispenser slows down slightly.. that should be enough to prevent it continuing.. IF that's the problem.
Apr 24, 2017 | Frigidaire FSC23F7D Side by Side...
Water dripping outside the collector
I think that there is a 90 degree bend in the outlet on the bottom right front side of the collection tray that gets pluged with dirt, line etc. You can see this when you remove the collection container from the unit. I used a small piece of wire to clean out the hole and now the water goes into the tank and not onto the floor.
Aug 24, 2008 | LG LHD45EL Dehumidifier
Water leaking from refrigerator
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If you just want to clean it you may can access it from the rear behind the cardboard backing. If it's overflowing your water filter may be stopped up or you may have had an excessive amount of frost one time.
Jul 09, 2008 | Roper RS25AEXLQ Side by Side Refrigerator
Solis Master 5000 Espresso Machine Logo
214 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
