Question about Zanussi 23 in. ZDi6053SX Built-in Dishwasher
Zanussi Dishwasher ZDT6053. Holding the On/Off button causes the indicator lights to work correctly, but as soon as you remove your finger from the spring loaded button, all the lights go off. Would guess that on/off button should electronically latch via the control board. Have removed mains power for 60 secs in the hope of a 'hard' reset, but no fix. Is there anything obvious to check or fix or must it be a replacement control board?
  • 1462 Answers
SOURCE: Zanussi DE540X Dishwasher
value of 26 ohms is about right. how hot does it get? max water temp is about 65 degc
Posted on Mar 24, 2007
  • 209 Answers
SOURCE: dishwasher zanussi aquapulse
this sounds lie a door interlock, in most models this is a micro switch where the handle is inside the top of the door casing, i would start there, based on the info that you have given
Posted on Sep 19, 2007
SOURCE: I brought a Zanussi ZDT6053 integrated. - Fixed in position - buttons light up but does not fill in oor start.
Dearest FixYa,
Thanks ever so much for your prompt response and am ever so grateful for standing to support anyone in problem.
Fortunately, I have solved the problem.
Basically the problem was that the water supply tube would kink when unit was pushed back into its space under the kitchen top. And it was totally difficult to see that problem from he rear of the unit.
Last effort wasto monitor every thing as the unit was showly pushed bak under the kitchen top. This time it was discovered that the water tube happened to be seen clearly from underneath the unit as 'kinked'.
When straightened, the unit simply went 'full in motion, and hey presto it worked straignt away.
Thanks for your 'standing by' to support with an army and great team of 'experts behind you.
Sincere regards
Posted on Mar 30, 2008
SOURCE: Zanussi 21 in. DCE5655 Free-standing Dishwasher
There is water in the bottom panel which has activated the float switch which overrides everything to stop the room the dishwasher is in from flooding. Remove the panel look for the leak. In my case one of the pipes had come off. There will be a lot of water in the panel so try and drain it first, tip the washer forward over some sort of container to catch the water. In my case I got very wet.
Posted on Feb 15, 2009
SOURCE: the water has not drained away in my ZDT6053, I
hi you need to open up washer and clean out the filter on the bottom shelve also try and wriggle rthe hose pipe going in at back turn off power and restart
Posted on Jan 01, 2010
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
How to reset Zanussi zdt6252 dish washer
To reset a programme in progress, open the door and press the push button of the programme under way for more then 1 second, until the corresponding indicator light goes out. The dishwasher is now reset and you can select a new programme.
Dado
Mar 03, 2015 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi zdt6053
Something wrong with Brake System of your Dishwasher. Contact Authorized Customer Service Center.
Mar 29, 2014 | Dishwashers
My Zanussi aquapulse de 6654 will not start. Only the on/off switch light lights.
Hi, I have a zanussi de6965 had the same problem the only indicator light that works is the on-off button.I had a problem some years ago with my machine would not work and showed L3 as the fault as I remember. I was advised to switch off all power isolate from the wall is best(pull the plug out of the socket) I removed the front casing held along the top and down the inside by a number of small screws. You need to leave the two bottom screws in(one each side) Wiggle free the top half of the display panel to acess the box holding the PCB board.it's very fiddly you will need a sheet of paper and a pen to make a noet of the connecting sequence of the wires ( Mark the blocks of wires with numbers... when replacing everthing this should eliminate any problems) Remove the PCB board from its casing and turn over to expose the back. At the bottom left hand side I discovered two dry joints, I needed a magnifing glass to check all the joints just incase. The faulty joints were a little discoloured blackened slightly. Solution...I cleaned, fluxed and re-soldered the joints. When re-assembled all the parts. It will help when dismantling to keep a note of the number and size of the screws and where they were removed from.
My dishwasher is now working again. hope this helps.
Sep 23, 2011 | Zanussi 24 in. DE6965 Built-in Dishwasher
Hi,i have a ZDT6053 but it will not heat the water,any sollutions
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Oct 25, 2010 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
I have a Zanussi DX6453 dishwasher. Water will
Try tipping the dishwasher back to see if any water drains out from below if there is water present then the anti-flood device is energised and stopping water coming into the unit.If it works now after resetting then there is a leak under the machine that needs investigating.You can try going into the diagnostics to read the alarms.If you hold in the first and third button from the left on programmer,whilst holding in then press the on/off button then when the lights start racing release these 2 buttons.You should now be in the diagnostics,now press the first button once and count the flashes of the end of cycle LED.If this button is pressed 2 more times it will give the previous alarms.1 flash could indicate fault on inlet water and valve.2 flashes drain circuit blocked.3 flashes anti-flood device.8 flashes faulty circuit board.Make sure after reading alarms to switch off unit then on then off to reset.Then go back into the diagnostics as before to reset alarms but this time press button 2 from left all LEDS will flash after exit as before.
Hope this helps.
May 15, 2010 | Electrolux Dishwashers
Dearest FixYa,
Sincere regards
Mar 28, 2008 | Zanussi 23 in. ZDi6053SX Built-in...
Zanussi zdt6053 will not fill with water, on any programme, it appears to try to start and makes a moise as if pumping, but there is not water to drain, and pump appears to operate if water is poured into...
Check float valve. It is probably stuck. This tells yuor machine to pump the water out and keeps the water valve from opening. Often it is something small that was placed in the dishwasher and lodges under the float telling machine that it is full of water when it is not. The float is somewhere on the bottom inside the machine typically. Make sure it moves freely.
Jan 15, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 23 in. ZDi6053SX Built-in Dishwasher Logo
123 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
