Question about Toro 52" 27hp Z Master Zero Turn Lawn Mower
60" toro z 500 series
  • 148 Answers
SOURCE: Need Parts/Service Manual for Toro HMR1600 mower.
Go to www.managemyhome.com and put in your model # for the manual (You can download to your computer). Also try www.searspartsdirect.com and put in you model # and you should be able to see all the parts for your mower.
Posted on May 19, 2009
  • 15 Answers
SOURCE: I replaced ignition coil on a Tecumseh Toro 20018
It is a short in the kill switch, or the wire running to the kill switch. check insulation on the wire running to the kill switch and check the routing of the wire to insure that it is not being rubbed by moving parts, or the insulation melted by hot engine parts such as the exhaust system. Finally check that the kill switch itself is functioning properly with a test light or OHM Meter.
Posted on Aug 12, 2010
  • 5370 Answers
SOURCE: I have a Toro SS4235
There are two possibilities for this shut down in gear. 1) The fuel issue. In fuel issue it can be fuel liner dirty or carb not letting fuel to flow the carb is dirty and needs cleaning.--------- 2) The safety switches are shorting. ---------- As you made it clear that fuel and carb is not the issue and problem is related to safety switches.then you are absolutely right.The switches gets short or its connections gets loose and cause the problem of shut down in gears.-------- There are various safety switches that could shut it down when the blade is engaged.
Usually on the seat, clutch pedal, transmission selector and blade control.
If one of the switches is malfunctioning or improperly adjusted, it could cause the engine to shut off when the blades are engaged or the transmission is put in gear.First get the seat switch checked,m in most cases this switch is the issue.Jump additional wire to switch connection , by bypassing the switch and check.If it starts and runs in gear, the switch is short, if not then other switches are top be checked, same way, by jumping wires and by-passing the switch.
There should be a clutch brake switch that would be activated when you push the clutch brake in. Otherwise you could have loose connections at any of the switches or corrosion or bad ground. There could be a neutral switch on the transmission it will look like a small ball bearing that your shift slides over. This switch is in the system too and should be checked. -------------------
This possibilities are to be checked.This will help.Thanks.Helpmech.
Posted on Jun 09, 2011
SOURCE: My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Posted on Aug 06, 2012
Testimonial: "Thank You very much for your support on this matter. "
hallett18
  • 11 Answers
SOURCE: Jerky movement
there are 2 drive belts that control the transmission. 1 is a variable speed drivebelt going from the engine back to the trans. it is the long one. the shorter belt drives the trans. off of the other variable speed belt. both belts are located under the mower and are not fun to get to. I would bet that one of these belts are slipping and grabbing, giving you the jerky ride. visually inspect for cracks or peeling, then check tensioning system for the belt to make sure they have the correct tension. less likely would be in the geardriven trans. it might act that way if some teeth of the gears inside are worn or broke. one other thing to check if all else looks good.... the variable belt drive pulley expands and contracts to change speed of the transmission input. I have seen these pulleys fail to operate correctly and this could also cause the ride to ****. hope some suggestions here help. R
Posted on Aug 23, 2012
My 2011 toro ss5000 moves very slow forward and reverse. It starts right up and pto works fin it just goes very slow in forward and reverse. Any help would be appreciated.
Sounds like you have air in the hydraulic system that needs to be purged from the fluid to alleviate the cavitation.
Mar 21, 2017 | Toro Garden
Toro Timecutter MX5050 74770 won't move forward or reverse.
find a breakdown of the parts diagram. that may help.
Sep 25, 2016 | Toro Garden
Finally decided to follow the manual's recommendation and changed the transmission fluid (SAE 10-W-30) while doing an end of season overhaul. Engine runs fine, but no forward or reverse. Over the last...
Did you loose forward and reverse right after fluid change or was it gradual? Sounds like you have air in the system. I would jack up back end and leave fluid fill cap off overnight. Maybe lay a light rag over it to keep debris out, but with the cap off and back end jacked up it should help air bubbles find there way out. Then, replace cap, leave jacked up and try bleeding by forward and reverse. Hope this helps.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Oct 19, 2013 | Garden
I have a 50in. toro time cutter zero turn and it wont work on the right side in forward or reverse?
Your release valve is open on the pump on that side. Or that pump or wheel motor is no good.
Sep 25, 2013 | Garden
Time cutter hydro does not move but i can hear it whine
Did you check the could have air in the system, did you check the hydro oil level? In my experience with toro hydro systems is when i change the oil air gets in the system. At low rpm move control handles forward and reverse several times until air works itself out. if this doesn't work more than likely there could be internal pump problems.
Sep 02, 2013 | Toro Riding Lawn Mower. TimeCutter SS4235...
Slow speed on one side.
Check to be sure there is not a lot of grass and debris packed in spaces that prevent proper movement of the control arms.
If the control arms have free range of motion then you will need to check your fluid level and purge the pumps.
To purge the pumps jack the unit up and place on jack stands so that the drive wheels are off the ground. Release the transmissions so that they are in freewheel. Start the unit, release the brake and work the control levers slowly to full forward then full reverse 6 times. Shut the motor off, lock the transmissions back into drive. Start the unit and work the control levers back and forth 6 times again. Take down off the jacks and check fluid level. If there were any air pockets in the pumps this procedure would have purged the air out.
Oct 01, 2012 | Toro Garden
Location of fuse to control side mirrors on 2009 97x
Fuse panel in end of fascia
No. Amp. Function
1 15 Steering wheel lock
2 5 Steering column unit; ignition switch
3 10 Hands-free; cabin CD changer; SID
4 10 Main instrument unit; manual climate control;
automatic climate control (ACC)
5 7.5 Control module in front doors; Park Brake Shift Lock
(automatic transmission)
6 7.5 Brake light switch
7 20 Fascia fuse panel; fuel filler door
8 30 Control module in passenger front door
9 10 Fascia fuse panel
10 30 Trailer socket; electrical socket in storage compartment
between seats
11 15 Data link connection (diagnostics)
12 15 Interior lighting incl. glove compartment
13 30 Accessories
14 20 Radio, sound system I; control panel,
Infotainment System
15 30 Control module in driver's door
16 - -
17 - -
18 7.5 Manual climate control; fan
19 - -
20 7.5 Headlight levelling switch
21 7.5 Hands-free; brake light switch; manual climate
control; clutch pedal switch
22 30 Cigarette lighter
23 40 Cabin fan
24 7.5 Airbag control module
25 - -
26 5 Yaw sensor (cars with ESP)
27 - -
Trunk fuse panel, left-hand side
No. Amp. Function
1-5 MAXI -
6 30 Control module in left rear door
7 30 Control module in right rear door
8 20 Trailer
9 - -
10 30 Left-hand brake light; rear right turn signal; right tail
light; right reversing light; high-mounted brake light;
trailer lights
11 - -
12 - -
13 - -
14 - -
15 15 Seat heating, left seat
16 15 Seat heating, right seat
17 7.5 Autodimming rearview mirror; rain sensor; tire
pressure monitoring
18 15 Sunroof
19 7.5 Telematics (OnStar)
20 7.5 DVD player (navigation system)
21 7.5 Saab Parking Assistance (SPA); control module in
rear doors
22 30 Amplifier, sound system III
23 - -
24 10 Movement sensor; CD changer in trunk (accessory)
25 30 Electrically adjustable driver's seat with memory
26 30 Right-hand stop light; rear left turn signal; left tail
light; rear fog light; left reversing light; license plate
lighting; trunk lighting; trailer lights
27 - -
28 - -
29 - -
Fuse panel in front of battery
No. Amp. Function
1 60
MAXI
Secondary air injection pump (certain models)
2 20 Fuel pump; preheated oxygen sensors (lambda
probe)
3 10 A/C compressor
4 30 Main relay
Relays
1 Secondary air injection pump
2 A/C-compressor
3 Preheated oxygen sensors (lambda probe)
4 Main relay, engine (ECM/EVAP/injectors)
Sep 13, 2012 | 2006 Saab 9-7X
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Car starts then quits. have to wait about 20 mintues
I have the same problem with my bimmer.To find out if the fuel pump problem take fuel pump out and get something kinda nock on the pump put it back in and start the car. It will run but not 1 or 2 days it will die again. You know that mean.Replace the pump.
Aug 03, 2009 | 2000 Mitsubishi Eclipse
Toro 52" 27hp Z Master Zero Turn Lawn Mower Logo
214 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
