Question about Lexmark C544dn Laser Printer
We are seeing dark smudges on the paper. We do not have a manual and I need to know how to take the roller out and clean it.
    Genius:
  • 1,087 Answers
  1. Print the Print Quality Pages (Config Menu>Prt Quality Pgs).
  2. Verify if the defect shows up on one color or all colors.
  3. If one color, replace Developer of corresponding color and PCU
You can also try the following:
  1. Verify if media is supported and proper paper settings are set.
  2. Try to print with the paper type setting change to heavy on the printer. (Menu > Paper Menu > Size-Type > Tray1 > Type > Heavy Paper > Check button)
  3. If persist, go to Diagnosis Menu and change the fuser temp. setting to high on printer. (Diagnostics Menu > EP Setup > Fuser Temp > High > Check button)
If you need further assistance, please contact Lexmark Technical Support Center
Posted on Jul 15, 2011
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
PRINTER IS PRINTING OUT PAGES WITH DARK SMUDGES FROM ROLLER. DELL LASER PRINTER 1700.
toner spill on the paper path. this occurs mainly due to 0verfilled toner cartridges ( refills) use damp cloth or metho damped cloth to clean the rollers in the paper path.
Please rate my help++++Thanks for using FIXYA
May 20, 2010 | Dell 1700n Laser Printer
I got smudges when i print ,how can i clean this
It looks like you've managed to get some ink on the rollers. 3 Possible solutions:-
1) Check your printer maintenance menu, there may be a roller cleaning option.
2) Print a document which has printable data on almost all lines, but with empty cartridges. You'd be using a piece of paper more or less as a mop.
3) Final alternative, it getting right into your printer and cleaning it by hand. Printer ink is water soluble so damp cloths/cotton buds should be man enough for the job. The parts you need to concentrate on are the rollers and the small sponge wells underneath where the print cartridges rest.
Apr 13, 2010 | Computers & Internet
We have a Ricoh Aficio CL3500N. We are getting a
Never clean or touch the Transfer Roller (spongey rooler) unless your using a dry cloth or vaccum as last measure.
Usually the transfer roller sits on a drum/pcu specific to that color. If you can tell which color is sitting on to of the roller replace that drum/pcu.
Jul 15, 2009 | Ricoh Aficio CL3500N Laser Printer
Gestetner 2722z copier, new drum, new transfer belt, smudges yet
The image is not transferring properly..........
remove and clean all corona wires (thin wires that create the latent image) use a q tip and dip in rubbing alcoholhot
Also make sure the fuser rollers are hot(insert or trick safety switches to determine if the fuser lamps are lighting usually upper and lower
Also check the imaging lamp to be sure it does not have any dark burn marks on it and clean the mirrors and the glass under the coy area
Dec 30, 2008 | Gestetner Office Equipment & Supplies
HP LaserJet wont pick up paper
Try cleaning the feed roller. It may have debris on it, making it slip. Use alcohol on a lint free cloth. Often you'll see on the paper where the roller slipped on the paper. There may be a dark smudge where the roller slipped. Check it out.
Dec 29, 2008 | HP LaserJet 1200 Printer
Printer has two smudges in same place every time
The reason you see a smudge in the exact same place everytime is due to ink being on the roller. Solution: using good light, use isoprel alchol on a cotton swab to clean the roller. Ink on the roller is also an indication that your head cleaner pad (look really good on the right hand side <inside> for the pad) is dirty. If you've not done so in the past, just flip it over and like magic you have a clean pad...just dirty on the other side.
Dec 17, 2008 | Dell 924 All-in-One InkJet Printer
The hp psc 1600 is getting dark shadowing when we print items we then brighten up the page but it reverts back to dark shadowing again.
clean the rollers with the help of maintanance option in the printer properties. if not solved check the ink service station unit inside the machine is full with waste ink , clean the waste ink pads and refix it. clean all smudged inks from the paper pickup rollers
May 25, 2008 | HP Office Equipment & Supplies
Lexmark C544dn Laser Printer Logo
165 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
