Colour has become predominantly green & red is almost non existant
  • Allan Dale Dela Cruz
    Allan Dale Dela Cruz Mar 23, 2011
    is it a plasma or lcd? how old?
  • voodoo_69 Mar 23, 2011
    crt 2003 panasonic tx36pd30
  • 158 Answers
Most likely you have a problem with your picture tube, they have to charge it up so you may need a service technician for those kinds of problem. you may have to replace something in there
Posted on Mar 23, 2011
Samsung crt tv
Check all the solder terminals at its video output card, for loose soldering. Re-solder all the suspected solder terminals. Check all the solder terminals to the CRT base socket too. The fault is called; sigle color predominant screen. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Jan 23, 2014 | Televison & Video
Tip
SONY TRINITRON ONE COLOUR PREDOMINANT SCREEN
Sony Trinitron sets are of CRT [Caothde Ray Tube] types. The common fault seen in these type of TVs are any one colour predominant on screen wih sound OK. Either red, blue or green colour with some thin horizontal lines at about an inch apart will be seen on the entire screen. This is totally a display card problem, which can be seen pluged onto the picutre tube neck. There are three electron guns for every picture tube, which emits red, blue, and green beams, which in turn illuminates the phosphor on the screen to get that colour. If no emission from all guns, results in a blank screen, ie black screen without any disply at all. The three colour beams together produces proper coloured picture what we see on screen. These three gun's terminals are brought out by pins of the picture tube outside to which video signals are given in appropriate proportion to produce a TV picture. Normally, all these three pins are biased with a voltage of about 170 to160VDC+ve. Take one colour gun, as an example and and let me describe the problem.
Let it be a green gun. These guns are called cathodes of the picture tube. If it gets a voltage with respect to its grid, it will emit electrons according to the voltage applied to it. This is a negative process, that is, as the voltage at this pin drops, its emisson incresses and vice versa. If the emission increase, the colour with respect to that gun also will increase and gets predominant at the screen. So when we see a green predominant screen, there will be less voltage at the green cathode with resepect to the other two. If red colour is predominant, the voltage at red cathode will be less than the other two. If blue colour is predominat, the voltage at the blue cathode will be less than the other two.
We must find out the reason for this fault first. Assume that your Tv has a red predominant screen with some thin lines across it, at about one inch apart of the entire screen, it is clear that the the red cathode voltage is very lower than the other two. the main reason for this fault, normally seen in most of the Sony Trinitron, are loose soldering points either to the picture tube base socket or the resistor connected between the red drive transistor's collector point. Resoldering the most of these points on the base card by applying a little more solder will rectify this probelm. Other possibility is shorted video output transistor of that cathode. A direct short [collector to emitter] of these transistors will drop volatge to very low at that respective cathode of the picture tube, and that colour will be pridominant along with lines. Replacing the transistor will solve the problem. In some cases, the resistor connected to that transistor may have blown out. If so, it should alo be replaced. Whatever the case may be, voltage at the respective cathode that emits colour will be very low with respect to the other two. Find out the reason and rectify it. You can compare the voltages of the other two cathodes with respect to the faulty colur cathode. Cathode pins will be marked on the base card, and can be identified. It is best to pull out the base card from the picture tube neck and place it somewhere a safe place without shorting it with other parts of the TV. You can measure the voltages of these points very easly, without fearing the damge to the picture tube. After all are found Ok, replug the base card and switch on the TV. The set will be alright. In rare cases, chroma IC also can be a reason for this fault. if it is faulty, after a short period after switch on the TV, the IC will overheat and shutdown the entire system.
on Mar 21, 2011 | Televison & Video
Why are green horizontal lines are appearing, too much yellow colour and green light blinking red?
These horizontal lines are vertical flyback lines and would indicate
one or more of the tubes cathode drive circuits are defective.
As the picture is predominantly yellow this would indicate excessive drive to red and green guns. Check the red and green video output stages especialy any clamping diodes.regards from Vintie
Sep 19, 2013 | Sony FD Trinitron WEGA KV-21CL10 21" TV
My mistubishi WS-65713 73 inch tv's colours are off. There is mostly blue and green and some colours are non existent like red and yellow. What is the problem?
Sounds like a convergence problem which is common in these sets
This model uses two of the stk394-250 convergence output devices or chips.
Both would have to be replaced.
Mar 12, 2012 | Mitsubishi WS-65813 65" Rear Projection...
I have a TRV-35G and the colour is predominately green which I cannot correct across the whole screen with the joystick control. Where the colours of the picture have been corrected (across 2/3 of the...
Try turning colour correction OFF. (button in up position). See what affect the iris control has. This control will changed the color of the slide from deep red at nearly closed to washed-out blue and white. at full open. I adjust the controls for each slide. The color temperature of the 8549 lamp varies with the brightness. lower level warmer, higher cooler.
Dec 02, 2009 | Elmo Projectors TRV-35H Slide Projector
Xbox 360 screen is predominantly yellow. Blue shows up, but red and green are non-existent. Also it freezes on Merc 2 when I try to go online. Any ideas?
This seems to be the next ROD issue. The video cards/chips on the XBOX360 seem to having the same issues as the CPU. In the ROD issue, the CPU heat sink is coming lose due to warping or other issues. The same thing is happening for the video. When it comes loose, you will lose some of your colors and/or all video. For me, mine turned green then later nothing. But I had sound still. The XBOX repair places should be able to fix it or there is a kit you can get online.
Nov 02, 2009 | Microsoft Xbox 360 Arcade
Colours are blurred and very red
Yes, the cooling fluid in the blue and green picture tube assemblies has become contaminated. Thats why the red is predominating. The contaminated growth cannot grow in red light and that is why the red is not affected. The only solution is to have the blue and green tubes pulled and disassembled and cleaned and new fluid installed. This is not a simple job. Most reputable shops charge around $300 to $500 for this repair.
Jul 10, 2009 | Philips 6P4830W 48" Rear Projection...
Colours on TV Panasonic TX-32PL10 5/6 years old
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Feb 11, 2008 | Televison & Video
Colour
it sound like you haveing troble with your red crt...could be crt socket circuit board or actually crt.
Dec 01, 2007 | Akai PT4298HD Rear Projection Television
My HP PhotoSmart 7762
I have a hp printer photosmart 7762, during traveling my power cable and tried every way I could to buy a secnd hand including buying another similar printer which I failed. Please help me. **** nazymharris@ukgateway.net
Oct 28, 2007 | HP PhotoSmart 7760 InkJet Printer
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
