Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Wtw6400swo the problem is that when it spins it shakes violently... the ul code keeps comeing on
SOURCE: kenmore washer shakes violently during spin cycle
I have a Kenmore 22990 top loading washer. it shakes violently and walks across the floor during the spin cycle. it started doing it about two weeks ago. moving clothes around inside the tub does not help much.
Posted on Dec 01, 2007
  • 92 Answers
SOURCE: Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Posted on Feb 06, 2009
huuum
  • 750 Answers
SOURCE: Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Posted on Apr 03, 2009
SOURCE: the drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Posted on Jan 04, 2010
SOURCE: ON SPIN CYCLE MY FRONT LOAD WASHER SHAKES VIOLENTLY
I have a four year old Andi front loading machine, and just in the last week it has started to move violently during the spin cycle and move across the room.
The last time, the movement was so severe that the machine was cutting itself off and then trying to spin again.
I couldn't control the machine and I just had to turn it off at the wall.
Posted on Jun 01, 2010
How do I fix a front load washer that shakes violently on the last spin cycle?
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
Sep 13, 2014 | Washing Machines
UL light keeps coming on stops spinning
The uL error code is displayed when the electronic control detects an off balance load. This can be caused by overloading, bad bearings in the tub, something between the tub and basket, or an issue with the electronics.
Feb 03, 2013 | Maytag Bravos MTW6600T Top Load Washer
Got it used and it shakes at spin at hi speed an ul come on
This can be due to excess load on the drum. remove the clothes and check once again. check the level of the machine, Also check the filling and draining water level to confirm if there was a overfill.
Jan 18, 2013 | Whirlpool WTW6200S Top Load Washer
I'm getting a "UL" (Unbalanced Load) code all the time, it is level and always happens with 11 minutes left in the cycle. What is the problem? Is the tub bearings out? Why is grease leaking?
This definitely sounds like a new bearing is required. It is not unusual to see grease leaking of the bearing has been damaged or is worn out. If it is banging, making loud noises or shaking the machine violently then the bearing is usually the problem
Sep 07, 2012 | Whirlpool Washing Machines
My washer goes into spin cycle byitself and when washing,if u r in spin cycle it sets for 14 mins thats good 4 mins into spin all knob lights start flashing and the screen says uL
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
Jan 23, 2011 | Washing Machines
The time display section indicated a code UL instead of the time left on the washing cycle. What does this code mean
keep getting a ul code and machine barrel knocks back and forth in the washer on spin cycle until the ul comes up. Cannot get it to quit. What is the problem?
Thanks
Aug 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
116 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
