Question about Cisco Computers & Internet
Hello, I have a problem to configure a HWIC-4B-S/T card for voice purpose. My router is a 2811 with the following ports Cisco 2811 (revision 53.51) with 509952K/14336K bytes of memory. Processor board ID FTX1509A0SF 2 FastEthernet interfaces 4 ISDN Basic Rate interfaces 1 ATM interface 1 Virtual Private Network (VPN) Module DRAM configuration is 64 bits wide with parity enabled. 191K bytes of non-volatile configuration memory. 126976K bytes of ATA CompactFlash (Read/Write) #sh diag Slot 0: C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports PVDM Slot 0: 32-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card WIC Slot 0: 4-port BRI S/T - 3086 WAN daughter card Is it possible to configure the ports of the WIC as voice-ports? I am trying to do it but no results. Regards,
5 Suggested Answers
dante777
  • 623 Answers
SOURCE: I would like to configure port fowarding on the CISCO 857 Router
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Oct 24, 2009
SOURCE: ZyXEL IES-1000 with AAM1212 ADSL 12 port module step-by-step guid
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
Posted on Nov 19, 2010
  • 17 Answers
SOURCE: cisco 3640 with a VWIC-2MFT-E1 network
You most likely don't have the correct IOS on your 3640 router. Other possibilities include bad VIC card or non-compatible VIC card.
Posted on Jan 11, 2011
  • 11 Answers
SOURCE: Cisco router 3845 cannot recognize
Hi, what IOS are you running, Cisco recommends IP Base 12.4(20)T
Posted on Jun 01, 2011
Not able to use two cisco 4-port clear channel T1/E1 HWIC
Drivers not installed correctly. Go to Cisco for current drivers and do a full installation.
Sep 12, 2013 | Cisco 4-Port Clear Channel T1/E1 HWIC
Cisco 3640 with a VWIC-2MFT-E1 network
May 05, 2010 | Sys Refurbished NM-8A Router (nm-8a s/t)
I would like to configure port fowarding on the Cisco 857 router using the http interface rather than via any coding. Is it possible and what do I need to do? In my scenario, the router must be configured...
cisco(config)#
in you case:
and
Oct 24, 2009 | Cisco 857 Router (CISCO857K9)
Cisco 1841 router
You can ID the cards by seeing if the card has "V2" on the metal plate. I believe an 1800 chasis requires a V2 card.
Feb 04, 2009 | Cisco (1841) Router (cisco1841)
E1 or T1 to pabx to router to softphone
Yes, configure second Cisco E1 port to simulate you telcom (network side) and connect it to PB, and first Cisco E1 to your telecom provider.
On Cisco router configure voice ports, and number manupilation, so you can catch any call and redirect it anywhere (Voip, Telco, PBX).
I tryed that with Ericcson, and it didn't work until connections where like these
telco <-> Cisco VoIP gateway (E1x2) <-> PBX
PBX's are not very flexible, Cisco is.
Jan 27, 2009 | Smart Modular 128MB SDRAM Module for Cisco...
Point to Point T1 Using Cisco 2800 Routers?
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Dec 03, 2007 | Cisco (WS-X3011) Router
Computers & Internet Logo
265 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
