Question about Yamaha Audio Players & Recorders
I have a M-50 Yamaha power amplifier that when I turn it on nothing happens. I opened it up and checked the fuses on the boards. None of them was blown. I checked the power going to the Transformer and the way I checked it was White to Brown(read 0 volts) and White to gray (read 0 volts).This unit has a GA6418 Transformer. If it is possible you can give me the proper voltage on the primary side (White, Brown and gray) and the secondary (Purple,Gray,Blue,Orange,White,Black and Red).I also Need to know how the LC 72760-1 and the LC 72760-2 boards control the Transformer because I think the problem is in the boards.Is there any way I can get the prints of the two boards so I can Trouble Shoot it better? I know this is a old unit (1982) but I would like to get it back working. If I need a component, do I order parts thru you?
  • 4 Answers
SOURCE: Yamaha RX-V995 no power no audio [dead]
sounds like a short in the cpu of the unit
Posted on Mar 07, 2008
SOURCE: yamaha m60 power amp
Posted on Mar 21, 2008
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
  • 1512 Answers
SOURCE: Yamaha P-4500
Hi radek
If it is a toroidal,they have a nasty habit of going shorted turns on the primary. Is it blowing fuses? Let me know
ex In'gill ;)
Posted on Sep 12, 2008
  • 4234 Answers
SOURCE: Bose SA-3 Amp / Blown Fuse
The problem is not the transformer. You now have shorted output transistors at the very least. By corssing the wires you presented a zero(0) ohm impedence load to the output section. It quickly went into overload. Before the fuses had a chance to open up, the outputs fried. This unit will require new output transistors and perhaps the previous driver circuit will require parts as well. Figure on $20-$50 in parts plus hte local labor rate for the repair.
Posted on Oct 01, 2008
I have a 1000 watt app Autobahn A4002T its chrome colored and about a month ago i was listen to my music and i turned my car off and then when i got back into my car turn the radio on the amp wouldnt turn...
Your post isn't clear on whether the entire system is dead, or just the radio. I'm assuming the amplifier itself is not working. Verify that you have power on both ends of the fuse with a 12 Volt tester or voltmeter. A fuse may look good, but a small break isn't necessarily visible. It's also possible given the amount of power you're running that a fusible link upstream from the fuse is blown. A blown fuse generally indicates a problem with the amplifier; don't waste money replacing it until you've repaired the amplifier.
If you have power there, check the wiring to the stereo. Perhaps a connection failed, or if the wiring is smaller than 8 Gauge, it burned out (this would most likely happen at a connection).
If the wiring looks good, the most common failure in high-power audio amplifiers is a shorted output transistor; this usually blows an internal fuse if not the external fuse. To check for this, you would have to open the stereo, identify the devices that drive the speakers, and use and ohmmeter to check the resistance between the transistor output to the speaker (usually the emitter terminal) and the power connection to the transistor (usually the collector). If it reads near zero, the transistor and its complement (the other transistor to the same speaker) should be replaced. (Some stereos have both transistors inside a power amplifier module; the entire module is replaced.)
If the audio output stages look good, check the inverter power transistors for shorts between the drain and source terminals.
Alternatively, you may be able to find an replacement amplifier on eBay; one of my search results showed an Audiobahn A4002T listed at $50 at the time of this writing.
Nov 22, 2017 | AMP Car Audio & Video
Yamaha no power
you need to check the power supply input of your amplifier using a multimeter set your tester into a dc voltage reading.then measure the power input you must have a DC voltage supply the cover check the fuse an open fuse will turn the unit to no power.there are causes of blown fuse a shorted power transistor at the circuit will blown the fuse you need to replace faulty transistors before putting up a new fuse...check also the diode at the power supply section ,faulty diode could lead to the same problem..
Sep 30, 2011 | Yamaha P-2500 Amplifier
Vizio VP50 No sound. I've had the tv for about four years, the sound went out shortly after I purchased it. I have up until now alway's played all sound through surround. Curious if there is an...
It might be,
Audio is usually on a separate power source from the rest of the TV and what I'd do if I were you would be checking the power output on the power board for the amplifier.
It may be something as simple as a blown fuse (and nothing else!) or, more likely, bad capacitor or (again more likely since you said it happened soon after you bought it) blown fuse because of a shorted component somewhere in the amplifier.
Jun 25, 2011 | Vizio VP50 10A 50 in. Plasma TV
Black screen no video no audio suddenly now
This set is a 50" plasma. first check the AC power fuse on the filter board then: if it is bad: check the power supply by marking and, removing all the cables; (so you can put them back in the correct spot) except the filter board to power supply cable; that connects to the Power supply board. Then: replace the blown AC fuse and, re-power: If the power supply blows the fuse: again, the power supply is bad and, must be replaced or, repaired. If the fuse does not blow: turn off the set then: on again, reconnecting and, disconnecting each board cable in turn, untill the fuse blows again this cable leads to the bad board; replace or, repair the board that blows the AC fuse every time the bad board is connected, irregardless of which other cable to the power supply may be connected also; or, not.
Jun 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
Yamaha AX-500 amplifier won't turn on!
Check fuses in back. If not fuses the power supply is dead. Buy a new one. They do weae OUT EVENTUALLy
Mar 09, 2010 | Audio Players & Recorders
Phonic k-12 powered mixer Nothing happens when I press the power
Most new stuff has the fuse/fuses mounted in clips on the power supply board.
If yours is anything like the one a picked up for one of my bands, you can take the bottom plate off and see everything inside.
Look for where the AC cord goes after the power switch.
There should be a circuit board with a fuse or 2 mounted on it
Jul 01, 2009 | Audio Players & Recorders
Power can not turn on for Yamaha RX-V520
If you can desolder the audio amplifier IC to check the device turn on,If the device turn on with the audio amplifier IC desoldered you need to change him.
Jun 12, 2009 | Yamaha HTR-5650 Receiver
Yamaha P-4500
Hi radek
ex In'gill ;)
Sep 12, 2008 | Yamaha P4500 Power Amplifier 2-Channel
85 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
