Question about Cameras
LCD Monitor suddenly does not work. No other apparent problems, and cycling the power or display button does not change the Monitor status.
  • the_dillards Aug 03, 2008
    Gryfox,
    Thank you for responding. The camera is the PowerShot G3, and I've had no previous problems with it or hints that the monitor might fail. The LCD monitor does not display settings nor does is show previously taken pics when I switch to that mode. It is simply blank all the time. Do you have any ideas?
    The Dillards
  • the_dillards Aug 04, 2008
    Gryfox,
    This sounds pretty plausible - we've had no problems but we certainly move the LCD monitor back and forth so I imagine this could be the problem.
    I will find a local shop and see if I can get a reasonable deal. Although this seems borderline expensive given todays low prices of digital cameras - the G3 is still a very nice camera and I'm not quite ready to give it up.
    Any ideas of good shops in Metro Detroit?
    Thanks, the Dillards
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
Which camera is this and does it display the settings or a previously taken pic ?
Posted on Aug 03, 2008
  • Gary Miller
    Gary Miller Aug 03, 2008
    If there is NOTHING displayed on the screen in the camera mode or play mode, there's probably a wire broken in the hinged wiring harness to the LCD. It's not something the user can repair, is caused by repetitive movement of the LCD. It's about a $110 job in our shop. Please leave feedback if this helps.
  • Gary Miller
    Gary Miller Aug 04, 2008
    Sorry, I don't.....but I know a good one in Asheville NC called Crystal Camera Repair ; ) Good Luck !
Asus vh202-t cycles through display modes randomly and not responsive WHY?
sounds like the button is stuck. I would 'hammer' the mode selector button; attempting to free it of debris...
Apr 07, 2012 | ASUS VH202T Monitor
IBM L190 LCD - the LED beside the power button corner cycles green for 1 second, off for 1 second as soon as it is plugged in. The unit won't power up, the LED just cycles green/off whenever it is plugged...
It's clear the problem is the display, but you can still try these 1. unplug and replug while the both is on 2. turn on, off couple of times 3. keep the LCD on for about one hour these are anyway temporary fixes :(
Jan 30, 2011 | IBM ThinkVision L190 19" LCD Monitor
Sudden failure - working fine then next time switched on no apparent power (no indicator light on), no display
You could have a power supply problem in the LCD monitor.
First check the power lead, make sure it is firmly inserted into the mains socket and into the monitor.
Try inserting it into a different main socket that is operating, to see if the power indicator LED lights up.
If you have determined it is the LCD monitor is faulty, then it requires repairing.
Jan 25, 2011 | Acer AL1717 17" LCD Monitor
Benq E2200HD No Cable Connected!
mnk1001, Possible Failure of internal "switch-mode-power-supply"/ "CCFL inverter supply" of E2200HD. Will need to investigate to see if SMPS is in emergency shutdown mode. Please post back if you find out root cause of failure. 12fixlouie
Apr 08, 2010 | BenQ E2200HD Monitor
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
Display problem in my LG 15'' monitors
1. cheak the filament path diode,capacitor.
2. there is dry points in power section.
3. replaced 3842 IC supply capacitor 47/100v.
4. LOT sarounds. if in case near to lot one resistor burnt (12k ohm ) change the lot & capacitors,resistor
Nov 22, 2008 | LG Studioworks 563N 15" CRT Monitor
Help! Any assistance or advice would be very much appreciated. I have a Sharp LL T19D1-B LCD Minitor purchased a little over 3 years ago. I had a mac plugged into one analogue input of monitor, screen...
This is the power supply inside the monitor itself. It is board that has three capacitors and they are blown out. It is a very inexpensive fix, if you are good with a soldering iron, if not let mw know and I will direct you to a company that can take care of this, for usually $30.00
Sep 26, 2008 | Sharp Computers & Internet
Flashing yellow light on Dell Monitor - what does it mean?
It means the display is in power save mode. This status occurs when the display is on but not receiving any signal.
Aug 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
Monitor won't turn on
The inverter power supply logic board has probably goe out. You can get it here or have it fixed.
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
Mar 30, 2008 | Dell E176FP 17" LCD Monitor
Cameras Logo
193 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
