Question about Aurora Electronics Office Equipment & Supplies
I need a gear for an Aurora AS1532x is it worth it to replace?\r\nWhere can i locate one? Thanks Dave
  • 42 Answers
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. Don't open your shredder if under warranty because it will void your warranty with Aurora if you do. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Posted on Jul 25, 2011
I need instructions on how to replace the motor on the passenger side power window on a 2001 oldsmobile aurora
Go to the parts store and purchase the Haynes shop manual for your Olds. Gives step by step with pictures .Costs about $20 or so but well worth it.
Jun 11, 2010 | 2001 Oldsmobile Aurora
Olds aurora wont shift outof 2nd gear think it might be a netrual safty ifso were is it located
You will need to get the computer scanned for this concern. The "neutral switch" has been replaced with a Multi lever positioning switch. When the shifter has been moved to a selected gear, the computer turns on different solenoids to make that gear work, along with a manual lever in the trans valve body. I feel you will find a couple P07-- codes, as to what may be wrong inside your transmission. It may be a simple repair, as possibly a vehicle speed sensor, but the codes will help get you a flow chart as to the problem.
Jan 18, 2010 | 1995 Oldsmobile Aurora
Gear indicator light bulb needs to be replaced. Not illuminated at night making it hard to see what gear the car is in.
I did this on the newer (GEN2) Aurora. Start by removing the dash cover plate (around the radio and heater controls). This exposes screws that need to be removed in order to remove the console cover plate. Then remove the bulb. It is really small. I couldn't find an exact replacement, but found one at Autozone that worked.
Nov 25, 2009 | 1995 Oldsmobile Aurora
RE; Durabrand Paper Shredder. Model Number WM6X. The motor works in reverse mode only, but the blades don't turn, Help
You have broken gears. Call customer service at 800-327-8508 and they will send you 2 gears for $10 including postage. I got mine in less than a week. Easy install.
Nov 05, 2009 | Office Equipment & Supplies
I need to replace the turn signal flasher on the Olds Aurora 1999
Behind LH Side of Instrument Panel, Under Steering Column Brace, pn# 10041073 ....looks like this:
Mar 24, 2009 | 1999 Oldsmobile Aurora
Leaking injector...
Hello Dave
You only need to replace one but if you are going through all the trouble it might be worth doing all of then if it's cheap. It'll also be worth cleaning them.
Hope this helps.
Mar 17, 2009 | 1989 Toyota Land Cruiser
Where can I get parts for a CH-DVD 300 player??
hi dave.has it split?i have had some success in replacing this cog from a scrap cd player,as these cogs are all near enough the same item so if you have a scrap cd kicking around,its worth a go,as i dont think the part you need is commercially available on its own....
Dec 03, 2008 | Cyberhome CH-DVD 300 DVD Player
Parts: What is its name? or how do I find it?
hello Pdwillie,
you said,
I located the following comment in your forum:
The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teeth and is making the noise.
Can you tell what the gear is officially titled and where I can find it. I also cannot locate a manual for this model do you have any suggestions?
Thanks,
Paula
Sounds like you need to replace the transmission!
How old is the washer?
admiral is a low end washer and may not be worth investing good money into bad!
The trans goes, so dose the washer ! To the scrape yard.
the new ones will pay for them selves in a few years in water and energy savings.
Never heard of anyone replacing parts in the trans. We replace the trans or advise the customer to replace the washer if its older than 5 years!The trans should last for at least 10 years!
Aug 09, 2008 | Admiral AAV7000A
Aurora paper shredder AS1200X Parts
blendervill,
If I am unsuccessful in locating the replacement gear for my AS1200X, I will joyfully sell you my unit-for parts.
Regards, MOTORRR
Feb 19, 2008 | Office Equipment & Supplies
150 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
