The right side of earpiece experienced total malfunction as no sound could be hear when any song is played.how do i fix this problem?and what cause this problem?
  • 158 Answers
It might need re-solding of the contacts, since it has small parts I suggest you get them repaired by an experience technician
Posted on Mar 23, 2011
Nokia E5 the only way i can make an outgoing call is to remove and replace battery. Otherwise I cant hear ring of outgoing call and when the other person picks up, they can hear me but i still cant hear...
HiCan you play songs ? If you can play songs then your earpiece is damage or short circuit and at the same time even if you play songs there is no sound then the problem comes from the Sound IC or its related components.So, if you can listen music just change the earpiece(the smaller speaker which is facing front side).Good luck
Feb 20, 2012 | Nokia Cell Phones
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
Jan 01, 2018 | Nokia N73 Music Edition Smartphone
I own nokia x2-01 , when ever i am calling i could not hear the ring of the other mobile . But on the other side we the other person is picking up the cal he can hear my voice but i am not able to hear his...
Hi your problem to your cellphone is Ear piece if you not hear the ringtone and voice to your talking. you need to repair a hardware and replace the earpiece.thanks :)
Jul 31, 2011 | Nokia 5310 Cellular Phone
When i make a call they can hear me but i cant hear them...and when my phones rings or i when i try to play a song no sound is coming out
The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Jun 29, 2010 | Motorola Mobility CLIQ Cell Phone
Describe your how to repair spekerProblem
It's good that you want to learn, but I am afraid if you are not yet done any training course. It's not easy, only troubleshooting is tough.
There are two speakers, Ringer and the Speaker, if you can't hear songs, ringtones, etc.. it's the problem with the ringer and if you can't hear keypad tones and call (without activating the Loudspeaker), the the problem is with the speaker which is fitted in the front portion of the phone where your ear place during when making/receiving calls. Replacing the speaker which with the faulty will fix the problem.
If both aren't working, you need to check the Earpiece (headset) whether it's working or not. If it's working, then there must be circuit short or continuity problem inside the board which is needed to be service by experienced technicians.
In case, Earpiece is also not working, then it's most likely with the Sound IC, you can replace it but no one can guarantee whether it would be successful or not.
Hope this helps.
Good luck.
Thanks for using FixYa.
Jun 29, 2010 | Nokia N73 Cellular Phone
Sounds from turntable
There will be some feedback from the turntable, and this is totally normal. Ive actually heard the music from the needle itself, and is nothing to worry about
Dec 28, 2009 | RCA ION-ITTUSB05 Turntable
Nokia 6500i
There are a couple of causes:- 1, Faulty Earpiece speaker, change the earpiece... 2, Faulty Ribbon/Flex, it connects the phones main PCB to the screen, the top keypad the front camera and the earpiece, a kink or tear in this can cause any of those to malfunction. Change the ribbon/flex 3, If its only happening when a certain person calls you, the problem could be at their end and they're microphone might be faulty on their handset... 4, Less common but there are IC's that control the sound on the 6500 these could be faulty or have dry solder, these can be either reflowed or replaced.
Jun 13, 2009 | Nokia 6500 Slide Cellular Phone
No sound whatsoever on LG KG800 Chocolate Phone
easiest way to solve this problem. go to call settings and TTY mode. and switch it to TTY + talk ... if that doesnt work then fiddle around with the other TTY settings untill it does. this disables the earpiece
Dec 09, 2008 | LG KG800 Cellular Phone
How can i hear the sound while playing the multi media player?
Press and hold the scroll wheel. You'll see earpiece volume on your screen, scroll up to increase the earpiece volume to 100%
Apr 24, 2008 | Motorola Mobility Moto Q
No sound at all
have the microphone replaced and the earpiece as well.
Nov 24, 2007 | Motorola Mobility SLVR L7 Cellular Phone
16 people viewed this question
 Grubhead
Grubhead
