Question about Dell Computers & Internet
How to draw carromboard and give the movements to striker and pans
  • 23 Answers
I assume you want to make a game which simulates carrom. Flash is usually the easiest to start on.
Visit the adobe site to buy flash, or if you already have the software visit these sites to get an idea of how to go about all of this:
http://www.carromshop.com/online/
http://freegames.thetechherald.com/onlinegames/1861/mini-carrom-board.html
http://www.tutorialized.com/tutorials/Flash/Games/1
http://www.dezinerfolio.com/2008/02/06/20-free-tutorials-to-create-your-own-flash-game
http://pelfusion.com/tutorials/35-flash-game-development-tutorials-fla-files/
Posted on Mar 24, 2011
The chimes on my hermle movement 150-070 sound funny. It's a bell and "clunk" sound as the strikers hit the two bells. Is there an adjustment?
You need to bend the arm on the one hammer back that is making the clunk sound. You will have to experiment a little until you get the sound you are happy with.
http://usedclockparts.com/8-clock-movement-repairs/19-how-to-change-the-sound-of-a-clock-gong
Oct 07, 2016 | Home
Will not let you fire it, even with safety off
Pull the firing pin and check it for freedom of movement and damage to the striker.
Apr 26, 2016 | Crosman Quest Air Rifle With Scope - 0.22...
How can i remove bottom draw in refrigerator if i can,t open door all the way
If you pull the fridge out into the room, that will give you more movement. It will only need 6" or so.
Apr 09, 2014 | Toshiba Satellite L455S5980 Notebook
What is the difference between cooking with a frying pan and using a wok to make stir fry.
A carbon-steel wok will give better results than a frying pan if you want to make a good stir fry. Not just from a taste point of view but also because it's much easier to flip the food around in a wok. In a frying pan it just shifts it to the other side and a key point of stir fry cooking is the movement.
Feb 18, 2013 | Home
Doors where hard to close without the weather door seals. But with them on they will not close. The body plates more but not enuff on the cab? I need HELP.
Hi!!
The doors Hinges or Striker need to be adjusted to make up for the weatherstrip thickness. To do this, loosen the hinge-to-door bolts for lateral adjustment only. Loosen the hinge-to-body bolts for both lateral and vertical adjustment.
REAR DOORS
BEFORE YOU START:
  • Determine which hinge bolts are to be loosened and back them out just enough to allow movement.
  • To move the door safely, use a padded pry bar. When the door is in the proper position, tighten the bolts to 19-25 ft. lbs. (26-35 Nm) and check the door operation. There should be no binding or interference when the door is closed and opened.
  • Door closing adjustment can also be affected by the position of the lock striker plate. Loosen the striker plate bolts and move the striker plate just enough to permit proper closing and locking of the door.
TO ADJUST ON A: F-150, F-250, Expedition and Navigator
HORIZONTAL AND VERTICAL ADJUSTMENT
  • Loosen the front door hinge to front door bolts.
  • Adjust the front door alignment.
  • Tighten the front door hinge to front door bolts to 19-25 ft. lbs. (26-35 Nm).
FRONT DOOR FORE AND AFT ADJUSTMENT Check the rear door hinge adjustment before adjusting the front door hinge.
  • Remove the front fender.
  • Loosen the front door hinge to body bolts.
  • Adjust the front door alignment to specification.
  • Tighten the front door hinge to body bolts.
  • Install the front fender.
1999-00 F-Super Duty Models
DOOR ADJUSTMENT The following procedure is for performing fore, aft, up, down and tilt adjustments.
  • Remove the door striker.
  • Loosen the bolts only enough to allow for slight door movement.
  • Carefully close and adjust the door until flush with the adjacent body panels.
  • Carefully open the door and tighten the bolts.
  • Re-install and adjust the door striker.
  • Check the door for proper operation and alignment.
STRIKER ADJUSTMENT Mark the position of the striker before loosening.
  • Loosen the striker retaining bolts.
  • Adjust the door striker and tighten the striker retaining bolts.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 09, 2010 | Ford F Cars & Trucks
Door adjustment for a 96 f350 dropped about 1/2"
Here's the solution: You might want to park it under a tree and tie a rope to the door to pull it up when loosened.
ADJUSTMENT Fig. 1: Door hinge adjustment 84920001.gif
Fig. 2: Rear door hinge adjustment, F-350 Crew Cab 84920002.gif
NOTE: Loosen the hinge-to-door bolts for lateral adjustment only. Loosen the hinge-to-body bolts for both lateral and vertical adjustment.
  1. Determine which hinge bolts are to be loosened and back them out just enough to allow movement.
  2. To move the door safely, use a padded prybar. When the door is in the proper position, tighten the bolts to 19–25 ft. lbs. (25.5–34.5 Nm) and check the door operation. There should be no binding or interference when the door is closed and opened.
  3. Door closing adjustment can also be affected by the position of the lock striker plate. Loosen the striker plate bolts and move the striker plate just enough to permit proper closing and locking of the door.
Jul 13, 2010 | 1997 Ford F350 Crew Cab
About the Panasonic DVX102B. Brand new. We seem to have a serious problem with unexpected jagged "digital outline noise" for example along the edges of moving icebergs, YES, the camera is actually...
make sure the gain button is in the L setting for low. Also, when shooting in 24p fast movements are going to give you this effect so you must slow your pan (side to side movement of the camera) to less than specified in the manual. In other words, slow pans. Also, these cameras do not like super cold weather. Sorry.
Aug 03, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
Ryobi cordless chain saw leaks oil. Runs fine. When I remove battery and store on shelf...a few days later I notice a puddle of oil. What to do?
The problem is, that it doesn't require 'movement or inertia', to draw/or pump the oil.
It syphons through, naturally.
The only solution is, to not store it with oil remaining in the reservoir.
That's it I'm afraid.
There is no way, to stop it from drawing oil through, without stopping it from working correctly.
Happy, (& safe;) chopping.
& plz don't give me the thumbs up, thanks :)
Jul 12, 2009 | Garden
The drivers side door won't close.
open the door , look at the latch on the door , as it get older and non lubricated , the latch can stick in the locked position , i,m going to draw a picture .
when the door is open it should look like the picture , i suggest your door is in the closed position and why it bounces off as you say , take a , lets say a screw driver stick it in where the little lever thats sticking up , push the door open button on the outside door handle , pry that lever forward , if successful try it , and lubricate it , hope my barbaric picture gets the point across .
Jan 05, 2009 | 1995 Jeep Grand Cherokee
Striker Sticking When Erasing. Brother ML100 Typewriter
Sounds like the gears you cleaned may be dry and sticking, spray a little WD40. or that gear on the right side is still out of time. I think there is a spring clutch in the gear train which may be bad. One secret to repairs is to perform the same actions that you want the typewriter to do by hand and watch closely. You may see something not movving, or moving slow that under power you won't see.
Aug 14, 2008 | Brother ML-100 Typewriter
Computers & Internet Logo
593 people viewed this question
Alun Cox
