Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whats up ihave a whirlpool ultimate care 2 while its filling it states to drain right away could it be thepresure with please help its almost new?
  • littlehouse1 Aug 03, 2008
    I have a whirlpool washer super capacity, when the washer drains, water backup into the drain and it overflows. The washer hold 17 gals of water.
  • Whirlpool Master
  • 5,568 Answers
If the pump and the fill cycles are running at the same time, then the programmer has to be at fault.
If it is that new, it's time to holler at Whirlpool for warranty repair.
I'm sure that there is a toll-free number in the paperwork it came with.
You don't want to pay for one of these out of your own pocket. As crappy as they are built, they cost a bunch to buy.
If you can't find a number for them at home, go here:
http://inter800.com/
Posted on Aug 03, 2008
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool Ultimate care ii will not fill when a load is started, the water flows in and directly out into the drain pipe. What is the problem?
Hello, Thank You for using FixYa. I will be helping you today.It has to be a drain line issue. Is the drain line loop up as high as the top of the machine it should. The drain line can be too far into the drain pipe causing a siphon. Try raising the hose or pulling it out of the drain some.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care 2, empties whilst filling. It dosent seem to be a leak but as though a valve is not working
You may have a condition known as siphoning. This is caused by the drain hose not being high enough off the floor, or not having a proper air gap in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Mar 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
MY WHIRLPOOL LSQ8200PQ4 FILLS WASHES AND DRAINS
From what you state i would think that the brushes in the motor need replacement, as when worn the first thing that stops working is the spin cycle, The motor goes very weak, they tend to last between 3 an 5 years depending on how many washes your m/c has done, they will be of low cost and worth trying as it is an easy 30min fix for a handyperson...
Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WATER FILLS AND DRAINS BUT DOES NOT AGITATAE OR SPIN
motor coupler is goingto be the issue, easy enough to replace, you can find a video on you tube, search "whirlpool motor coupling"
Jan 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Yes if its filling slow do to a blockage in a screened hose it will .If it never stops filling and doesnt over flow than its syphoning the water and you need to elevate thr drain hose higher than the water level and it will kick into wash. Please rate This !!
Jul 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II Plus Washer Model: LSQ9264HZ0
if you hear the motor running while it is supposed to be agitating or spinning then it is most likely the direct drive coupling between the motor and transmission.43f18ab.jpg9bd1c44.jpg if you already checked this and think it is a different problem then let me know, i will help you figure it out.  Mike
Jul 15, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal De
