Question about Intel (D34223001) CPU Heatsink Fan
Cpu fan makes loud nose - Intel (D34223001) CPU Heatsink Fan
    Problem Solver:
  • 12 Answers
Dust or dirt may be your problem take fan off and clean the cool part of it
Posted on May 19, 2012
  • 158 Answers
Try to clean it with a air pressure can, possible dust issues
Posted on Mar 23, 2011
Trane XR80 Heater/Air Conditioner, makes a loud banging nose when the fan turns on
If there is nothing hitting the fan, you may have a bearing that's worn out.
Feb 04, 2015 | Heating & Cooling
Asus x50sr fan on full constantly
That laptop have no to much space to get the air , and when the cpu get hotter , the cooler starts to go faster and than he make noise to much , watch the cooler , take off the dust , and take care of the cpu .
Oct 20, 2012 | Computers & Internet
I have a vostro 200 large tower with a g33m02 motherboard. The cpu cooling fan is very loud. (not bearing loud, but it seams to try a lot harder than it needs too for what the computer is doing.) the cpu...
Check your BIOS Settings
CPU Configuration
CPU Internal Thermal Control [Auto]
Hyper Threading Function [Enabled]
Intel(R) SpeedStep(tm) Tech [Auto]
Power>Hardware Monitor
CPU Q-Fan Control [Enable]
CPU Fan Ratio [Auto]
CPU Target Temperature [60degC] (lowest setting available)
or you can replace it with Cooler Master XDream
Sep 20, 2011 | Dell Vostro 200 Desktop Computer
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
My sony vaio VGN-CS11S is soo noisy
The fan's bearings are probably going bad, or there may be some object that was sucked in to cause the noise.
Sep 28, 2009 | Sony CPU FAN CPU Fan
Fan is loud
well if its not attached to the motherboard in any place, for example the heat sync, or the cpu, then you can remove the fan, any other place, you shouldnt replace it because the mother board sets the fan at a certain rpm, and which would sound loud with any fan. I know this because i replaced the fan on my sony computer, and on a generic motherboard, and it was quiet, but when i put it on my sony computer, it was loud, so if you want to replace your fan, i suggest liquid cooling, it is completely quiet, and keeps your cpu much cooler than a fan. Best of luck.
Jul 04, 2009 | Computers & Internet
Making virbrating nose
believe it or not, most noises that start and end and start again are sometimes very easy to fix. next time you hear it open the refrigerator doorand see if your ears can pick up the sound. usually it is two bottles in the panel of the door vibrating against each other. if not thencheck your fans especially the condenser fan next to th compressor, something may be caught in the fan blade. unplug unit if you find noise and give the coils a good cleaning while you are down there anyway. let us knowhow you did
May 01, 2009 | Refrigerators
CPU fan problem
The stock fans that comes with systems are usually fairly poor in construction and tend to fail. I would have a look at the fans and heat sinks on this website for a replacement.
I hope this helps,
Thanks for using FixYa,
Eric
Jan 20, 2009 | PNY VERTO GEFORCE 6600GT 128MB DDR3 PCIE...
Loud fan
Check that the fan is not hitting any wires in side the case.
If not you may have disoriented the fins while cleaning them. Make sure the fins are not hitting the fan body.
If the fan wasn't installed property the CPU temprature should rise fast and your computer might automatically shut down to prevent damage to the CPU. If that is the case, try reinstalling it making sure it's attached well to the CPU. And remember to add some thermal compound to help the heatsink transfer heat.
If none have solved your problem you can buy a new fan for your CPU at any computer store. Make sure it's compatable with your CPU socket type.
I have lately purchased this fan for my quad core CPU and it's 100% silent. You can run it without a fan also. It's a really huge heatsink. I recommend it.
http://www.coolermaster.com/products/product.php?act=detail&id=4509
Oct 27, 2008 | Sony VAIO PCV-RX753 PC Desktop
Fan sound is very high
Check the speed of the fan in the BIOS and set it lower, although 58-63c is alright for a CPU (P4 is rated to go up to 70c) you might want to make sure that you have good air flow in your case to make sure the CPU doesn't overheat. Usually you can find the fan control in the Advanced section of the BIOS. You'll also want to check the specs of the fan that you have installed as that will tell you how loud it's supposed to be. You might have to get another fan with lower decibels if you want it to be quieter.
Apr 06, 2007 | Gigabyte GA-8I865GME-775 Motherboard
Intel (D34223001) CPU Heatsink  Fan Logo
241 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
