Question about Jabra GN2000 USB Mono Ms Oc Nc Headset
My Jabra GN2000 call centre headset is working in the head phone but the caller can not hear what i am saying . It seems that the microphone has stopped working. Can you tell me how to fix it.
5 Suggested Answers
  • 5 Answers
SOURCE: Pairing problem
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Posted on Feb 01, 2008
SOURCE: unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Posted on Jan 28, 2009
voodoomox
  • 1689 Answers
SOURCE: how to pair the jabra BT125 headset with personal computer to here songs without using head phones
hi vrajasekar20, thank you for using fixya.
to pair your jabra to a PC for headset use, you have to install the jabra PC Suite first and use it as your default sound input / output device.
The PDF file below will give you a step by step instruction on how to have it installed and working.
http://www.jabra.com/sites/Jabra/GNimages/Products/Adapter/A330/A330_FAQ_EM_EN_2838.pdf
Should you need more info on this matter,please do not hesitate to let us know.
regards,
voodoo
Posted on Apr 17, 2009
jazzbassist
  • 4 Answers
SOURCE: my jabra headset won't pair with my phone--my
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Posted on Dec 16, 2009
Testimonial: "This worked perfectly! Thanks!"
Will the Jabra Style+ headset announce caller? Or is this a function of the phone itself?
A feature of the phone. The headset is what it is, just a headset carrying what the phone has. However the headset does have to ask for what the phone has. Check online for the manual of the Jabra headset you are thinking of.
There is a review here
http://mobile.pcmag.com/tablets/37778-jabra-style?origref=
Nov 04, 2015 | Jabra Radio Communications
I can hear my caller, but when I speak they cannot hear me
good day the problem that you have posted indicates that the mouth piece of your jabra bluetooth headset is deffective.
Sep 25, 2010 | Jabra BT350 Bluetooth Headset Headset
My Bluetooth headset's microphone stopped working
Same Problem Here. Restored the 8220 flipphone to factory settings. Dint work either.
Sep 24, 2009 | Jabra BT250 Consumer Headset
Unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
Oct 28, 2008 | Jabra T5330 Wireless Headset
Jabra BT620 Microphone dose not work with Soft Phone on My PC
Well, I got the same problem the days before, and after some trying, I've solved.
I'm using the Toshiba bluetooth adapter, too. You see, when you want to make a new connection with your bluetooth device, you may either use the Express Mode or the Custom Mode. Go with the Custom Mode, then, there appears the Jabra BT620. After input the 0000 code, you may select the services from 3 options. There, you can find the headset or hands-free option.
Go with that, than you may have your Jabra BT620 as a microphone!
Sep 09, 2008 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
English instruction manual
you need to charge the head-set fully and then.... disconect it from power supply. hold down the call button until a continus light appears. and then flip out the speaker tusk.... then search for the device on your phone a couple of times.... if you dont find your headset then your phone is not compatible with the head-set....
Nov 28, 2007 | Jabra BT8010 Wireless Headset
Cant hear
I have the same problem. The lights are on, it's paired, and my caller can hear me. but I cannot hear the beep from pressing buttons on the jabra, nor can I hear anything from the phone.
Oct 31, 2007 | Jabra BT500 Wireless Headset
No sound
Had the same problem with the BT250v 'connected' to my Nokia 6021. When connected to my notebook, the 250 did produce sound, so decided the Nokia was the problem. Fixed the problem by doing a full reboot of the phone like this:
Jabra: Turn off the 250
Phone: Delete the BT connection to the Jabra (in BT settings)
Phone: Switch off BT
Phone: Turned off the phone (I've even removed the battery)
Phone: Turned on the phone
Phone: Switch on BT
Jabra: Turn on the 250 for detection
Phone: Look for audio devices
Phone: Connect to Jabra
Problem fixed!
Sep 02, 2007 | Jabra BT250 Consumer Headset
Handset microphone not working? callers cannot hear me, i can hear them
Hi i also got this problem, when i went to the service centre, they told me that the whole circuit needs to be replaced along with the keyboard. It sounds costly to me.
Jan 22, 2007 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
Jabra GN2000 USB Mono Ms Oc Nc Headset Logo
350 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
