Question about HP Mini 1000 Netbook
I'm using a flash drive with a program and there are no scroll arrows. Must I change the size of the screen (it's set at 600x1024) or is there another way to get the scroll arrows?
  • 114 Answers
You need to change the Screen resolution.
Posted on Mar 23, 2011
Open your drawer, you can see blue colored lever with arrow. Point that arrow to the size you want to use on your drawer. I pointed the arrow but nothing done.
If you are using the copy function from a computer, you have to set the paper size in the program. Most of those set the paper size to 8.5 by 14 inch
Feb 25, 2017 | The Office Equipment & Supplies
Tip
How to Change the Display Settings for your MP3 Player |
You can personalize your music player by changing the appearance of your background. This will also help you to read the screen while making the icons easier to see.Follow the instructions below to change the display settings on the device.
Instructions:
Things You'll Need:Owner's manual,mp3 player
1.Turn on your MP3 player and use your keypad to select "Setup." Push the center button on your keypad to highlight "Display" on the Setup menu.
2.Use the keypad to scroll though the languages on the Display Menu. Push the center button on your keypad to choose one.
3.Scroll down the menu to the "Brightness" options. Press the right arrow on your keypad to increase the screen's brightness, or press the left arrow to dim the screen.
4.Scroll down to the "Wallpaper" selection on your Display Menu. Use the arrows on your keypad to scroll through the different backgrounds for your MP3 player.
5.Change the icons on your MP3 player. Scroll down to "Appearance." Use the arrows on your keypad to scroll through the different icon choices.
Tips & Warnings:
Make your own background by downloading photos from your computer.Dim the brightness in low light situations to save battery power.
on Feb 10, 2011 | Audio Players & Recorders
How do i change from remote ttl on my nikon sb800.
Press the Menu button. Scroll to the Custom Setting Menu. Scroll to "e Bracketing/flash". Right arrow and scroll down to "e3 Flash cntrl for built-in flash" and push the center button. You now have access to the TTL, Manual, Repeating flash and Commander modes. Right arrow on CMD and a menu will appear that allows you to set up the built in flash and the external flash groups.
Aug 15, 2013 | Nikon Speedlight SB-800 TTL Flash
Entire Gimp window is too big, cannot re-size
go to control panel display and do the resizing then in the pixel settings
Feb 12, 2018 | GIMP GNU Image Manipulation Program
I have a canon MP600 printer and the language has changed and i can't read it now and do not no how to change the language back to english
1. Press the HOME button.
2. Use the Easy-Scroll Wheel or the right / left arrow to select [Settings], then press the button.
3. Use the Easy-Scroll Wheel or the right / left arrow to select [Device settings], then press the button.
4. Use the Easy-Scroll Wheel (B) or the up / down arrow to select [Reset settings], then press the button.
5. Use the Easy-Scroll wheel or the up / down arrow to select [Yes] on the confirmation screen and then press .
6. Press the button to return to the HOME menu.
Jun 22, 2011 | Computers & Internet
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
How to set the time on my GE 27958GE1 Cordless Phone
1) press FLASH/PROGRAM until SET DAY shows
2) use MESSAGES/CID or the arrow buttons to select current day
3) press FLASH/PROGRAM until set time shows
4) use touch-tone pad to enter 1st, 2nd, 3rd, & 4th digits
5) use MESSAGES/CID or the arrow buttons to scroll to AM or PM
6) press FLASH/PROGRAM again to store your selection
7) press FLASH/PROGRAMrepeated to exit
I copied this from my manual onto a sticky label & have it stuck on the bottom of my phone for future reference.
May 21, 2010 | GE 27958GE1 Cordless Phone
How do I print documents received in memory?
try by pressing function and then data registration and set/ok!It will say user settings and use the arrows up/down to scroll to printer settings,press set/ok and scroll to paper size,press set/ok and if its on a4 use the arrows to get to LTR and press set/ok!If that works then u will need to have the registration sensor at the back looked at as it is most likely not falling into position after the paper has passed it!Good Luck and remember to vote PSE!!
Apr 01, 2010 | Canon Office Equipment & Supplies
Need instructions for Ingraham model TE109
To set the timer press the right arrow key.
The timer will now be blinking 1on.
This means on time for program 1.
Press set.
The days of the week will be blinking now.
Use the arrow keys to scroll through the options, like
just one day of week, every other day ETC..
Press set when you get what you want on the days.
Now the hours will be blinking.
They start at 12:00 AM, so to go to 1:00 PM you would have to
press the arrow key 13 times.
When you get the correct hour, press set.
Now the minutes will be blinking.
Choose the minutes you want with the arrow keys and press set.
You will be back to 1on blinking.
Now press the right arrow key to go to program 1 off.
Set the off time the same way you set the on time.
After setting the off time, or any time 1off is blinking, by pressing the right arrow key you will go to 2on and so on.
You can scroll through all the programs by continuing to press the right arrow key.
Both arrow keys work i.e. you can go backwards if you went too far.
You can go to program 20 off if you press the left arrow key.
Keep pressing the left or right arrow keys to skip to the program
you want to change.
When you get to the program you want to change, press set
Mar 27, 2009 | Solar Ingraham 20 Program Electronic Timer...
My camera has never been dropped why isn't my flash working?
Hi jlapread
If your camera is giving you a `E91` error on screen it could be a faulty flash module and need replacing at a Sony Service Center. Contact your dealer for info.
But, before you do that try steps 1 and 2 below.
Here is some things you can try:
1. If it is only a setting you can select the `green` camera for auto shooting and then press the `UP arrow key until the flash sign is shown on the screen. The screen will also say `Flash On`. Take a picture to see if it works.
If not proceed to `2` below.
2. Press the `Menu` button.
First select the `Green` camera on the selection knob.
Scroll with the right arrow to the little toolbox picture.
Once in the setup menu scroll down to the toolbox picture with a 1 under neath.
Press the right arrow arrow and then scroll to the `Intialize` option.
Press the right button and select `OK`.
Press the middle button on the arrow selector.
Camera now wants to know if you are sure, select ok.
You will now have to enter the date again and setup any `Program` settings you might want on the camera.
Now take the camera into a dark room - as it is now on `Flash Auto` and test to see if the flash works.
If none of these helped you, you can take the camera to a repair agent and get it fixed. I have replaced numerous of the flash modules at approximately a quarter of the cost of the camera.
Hope this information helps you.
Good luck
Jan 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
HP Mini 1000 Netbook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
