Question about Zanussi Refrigerators
I need an instuction book for my fridge freezer which is a year old.Model ZR8634FW Type C8FF340 925033608-00
5 Suggested Answers
SOURCE: Ge side by side - high low humming noise from freezer section
I have a hotpoint HSS25GFPJWW fridg. The coil that opens the flapper door for the ice was bad so i replaced it . Now when i push the leaver in to get ice the fridge shut's down like ther is a large power drain. This was doing this before i replaced the coil but the flapper door was not opening then now it opens. It evens shut's the compressor off.
Posted on Apr 22, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
woodchuck789
  • 4070 Answers
SOURCE: HOT POINT FRIDGE - FREEZER DRIPS WATER
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Posted on Jul 12, 2010
  • 3 Answers
SOURCE: I have a samsung fridge
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Posted on May 21, 2011
Promblem with an industrial overlocker. need information
DC x 1 should be your needle type.
Try this company for your manual:
Juki MO-2500 Parts - MO-2500: Sewing Parts Online www.sewingpartsonline.com/...ewing-machine-parts.aspx
An Online Juki Parts Superstore, We also supply MO-2500 manuals, presser feet and accessories. Fast, free shipping over $75.
Jul 02, 2017 | Juki MO-623 Mechanical Sewing Machine
Whirlpool quit working - can hear short buzzing and fan
you might want to try a 3in1 starter kit for the compressor,you can get it from your local appliance parts store,it has instuctions on it,it is easy to do-mike
Feb 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have lost my instuctions for this Bosch
Problem solved went to Currys and looked at the instruction book in there!!!!!!!
Jan 09, 2010 | Bosch KGU32124 Bottom Freezer Refrigerator
Ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Jul 19, 2009 | Daewoo Refrigerators
Fridge heller model fdh21has motor running but does not get cold
i have just purchased a float with a kitchen in it the fridge is a heller bar fridge not sure on model and for the 2nd use it is running but not getting cold or icing up the freezer what do i do to fix it it wouldnt be 10 weeks old
Mar 27, 2009 | Refrigerators
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
I have a fridge freezer bosch kgn39v00g3.The fredge compartiment doesn't cool as it should.The freezer works fine and it doesn't have ice build up at the back.What is the problem?
Peace Friend,
ngafm At your service!
Ready?
If the freezer is cold and not the fridge, you need to make sure the freezer is not filled to the top and covering the cold air vents and passages usually found in the rear or bottom rear of the freezer!
If they are blocked or covered with packages the unit will not be able to transfer cold air to and from the fridge!
Yes, they share the air in most refrigerators!
What type fridge,model and age?
If not only a trained tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 04, 2008 | Heating & Cooling
How many cubic feet (what size) is my fridge?
Need the cubic feet on our 16 year old Amana BX22A2W.
Jun 23, 2008 | Magic Chef CTF2125 Top Freezer...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper frdige section is fine but freezer not. I have emptied, kept door shut, turned dial up but no...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper fridge section is fine but freezer not. I have emptied, kept door shut, turned dial up but no success.
Any suggestions on what the problem might be?
Wouldn't expect problems on a SMEG just 2 years old.
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 14, 2008 | Refrigerators
Fridge problem
I don't know about the hot points for sure, but all the maytags (I used to work for maytag) have a damper valve in the air tunnel that feeds cold air to the refrigerator. If the damper went bad, it would block cold air flow into the refrigerator. (assuming this model has a damper)
Feb 16, 2008 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Refrigerators Logo
42 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Jason Harris
Jason Harris
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
