Question about Samsung Bn59-01041a Remote Control
TV says I am not getting a signal Were is the "
    Scholar:
  • 85 Answers
It is sometimes called the source or ext button on some remote controls and sometimes you have to go through a menu system to tell the tv what sort of input you want to use, Is the remote control definitely working? To check this, If you have a mobile phone with a camera on it put the phone on video mode as if you are gona record something and point the remote control at the phone whilst pressing a button and you should the remote control light flicker, Its invisible to the human eye as its infra red light, I would need more info to help you out but I'm taking it all your leads/cables are in the right places? I hope this helps you out if not just ask,
Posted on Sep 19, 2011
I only get a blue screen with "No signal" on it. it doesn't stay on it shuts off automatically.
Power on your TV and press the INPUT button on the side of the TV repeatedly and rapidly until you can change it to a different input, such as AV.
If this does not work. Try this: With the TV off, press and hold the input button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. Let me know if either of these work.
Mar 01, 2013 | Vizio GV42L 42 in. LCD Television
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
"NO SIGNAL "is displayed on a blue screen
You have selected an input on the display that is not getting any signal that the display can recognize. Press the source button either on the set or on the remote until you get a signal.
Aug 09, 2012 | Element Electronics FLX-1910 19 in. LCD...
WE ARE TRYING TO GET TELEVISON RECEPTIOB BUT WE GET "NO SIGNAL INPUT COMPONENT 5 AND THEN IT POWERS OFF". WE HAVE A PIONEER PDP 425 MX. I HAVE TRIED TO USE ONLY INPUT 4 BUT TV WILL NOT STAY ON...
The reason your tv is powering down is that it is not receiving an input signal on the channel (input). basically you don't have anything plugged in and turned so the tv doesn't see a signal on component 5 so it shuts the tv off. turn on your TV and hit the input button until you get to the input that you are have a device installed on. just make sure the device you are trying to see on the tv is turned on prior to turning on your tv.
If you do not have an and device plugged in (cable or other input device), plug something in to an input and turn the device on so a signal is being sent to the tv and then turn on your tv and change the channel to that input.
if you are locked on input 5, install and turn on a device to that input so the TV registers it as an active input.
Jul 02, 2011 | Televison & Video
Message reads "no signal check
select the right input in your TV set, depending on what kind of device you want to use or connect to access the device.hope will help you.
May 03, 2011 | Televison & Video
Remote doesn"t work. Only have
check that all of your cables are plugged in correctly and that the input is set to to correct cables on the remote there is a button that should say input press that a menu will appear and then you can scroll through your input options keep trying until one works
there is also usually a button on the tv that does the same thing
Mar 06, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Model ds31520. I've had it for years working like this: no antenna, no cable, just DVD (connected to non-S input ports) watching movies. Somehow I hit a button sequence on the remote and now only this: ...
Sorters -
Re-connect to me on the chat and we'll get this sorted. I'm really sorry - I got disconnected and the system would not allow me to reconnect to you. I have some ideas but chat would be easiest. If you don't want to chat, post a message here and I'll message back with some things to try.
BElectric.
Jan 22, 2011 | Sanyo DS31520 31" TV
Hello My, just bought Sony KDL 46 NX 700 shows on the screen " No signal. Check the external input or select another input using the input button". My TV cable is connected and TV it replaced...
I have one of these. It is probably set up for some other program like the HDMI or Input 1 through 5.
You can press your INPUT button, then scroll to the TV function, which should show up on the top.
Jan 09, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
My TV signal source is a cable/satellite digital box. The setup screen correctly takes me as far as "Select correct input source for set top box." At this point - instead of leaving the...
I would suggest using dedicated input button on remote, not the menu on the tv. If you can skip setup screen that would be best. I have just looked at the manual for that tv, it tells you all you need to know, depending upon which input you used for your box. As I stated use the direct input button on the remote if you have it.
Oct 12, 2017 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Samsung Bn59-01041a Remote Control Logo
91 people viewed this question
Jerry Greenberg
Jerry Greenberg
