Question about RCA R52WH76 Television
Pic messesd up
I have the same problem. can i fix it my self?
  • 11 more comments
  • thoomas Aug 03, 2008
    it looks like i need 3d glasses to watch tv and the con is gone from settings.so i cant ajust colors. i checked the 3 red fuses in back but saw nothing wrong with them.took caps off and fuses seem all intact.
    it looks like i need 3d glasses to watch tv. also the con is gone from the settings menu. i checked 3 red fuses in back and they seem ok. took off caps and wire is intact.
  • thoomas Aug 04, 2008
    is there a fuse on the convergence power supply board i can check? i found 3 red fuses on a different board but they are ok. the only things i see close to a fuse on the power supply are blue and i dont want to pull on them too hard and make things worse.
    that fuse seems to be ok so no i assum i need a new power supply. i looked at the link you posted and it was very helpful but i can not find my con chip. i have 3 heat sinks with chips. both of them have chips with 3 wires going into the board and the other 4. i do not see one with 16 prongs like the one on the link.how do i know if it needs a new con chip witch is one board or a power supply witch is another board? just a gamble?i have seen where alot of people say its the chip.should i try to replace that board first? sorry to be so needy....im poor and i bought this tv for 350.00 and would like to fix myself if i can.
    i have number one.
    should i try to replace that first and if that doesnt work try the other board with the convergence chips on it?
    i thought of tring this first http://cmpalmer.blogspot.com/2006/11/fix...
    can you show me where my convergence chips are. my heat sinks have chips but not like the ones in that link. i would like to try to replace them first (sinse it is cheeper) and see if that fixes the problem.if no fix i will replace power board and go from there.i read alot of people say the chips are going out on this model.
    is the fl231 located on the power supply? and if i just replace the power supply should this fix all. thank you for all your help.
  • thoomas Aug 05, 2008
    what is the flyback?
  • thoomas Aug 20, 2008
    when i click on the link the part i need is gone? can you help? my son in the navy is going to buy it for me.
    when i click on th link i cant find the power supply board any more. can you help. my son in the navy said he would buy it but i have to send him the link.
  • kombi67 Oct 23, 2008
    replaced the fuse but about a day later it blew again.
  • Eds2551 Oct 30, 2008
    Cant able to locate FL231 My chassis number ctc 195 MOdel # p56923bl
  • RCA Master
  • 8,617 Answers
I am not sure what your question is. Can you respond to this same post and indicate the nature of what your problem is? I will try to help you out.
Posted on Aug 03, 2008
  • 6 more comments
  • Sonny Berry
    Sonny Berry Aug 03, 2008
    When that happens on the ITC222 chassis which is what your model is. Its due to the convergence power supply going bad and it takes out fuse FL231 and then the convergence option will disappear from the menu. You will need to replace the convergence power supply board and the one fuse FL231. The following link has both Items with free shipping within the US. they are listed under the RCA parts category. You need the D52W20 convergence power supply and the FL231 is there as well.
    Heres the link
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    Sonny Berry Aug 04, 2008
    FL231 near the flyback There are none on the Convergence power supply board. FL231 is the one linked to the convergence power supply and makes the convergence option drop from the menu
  • Sonny Berry
    I am posting a pic of the two type convergence power supply boards for the ITC222 chassis. Which one do you have. Heres #1
  • Sonny Berry
    And heres number 2. Let me know which one you have in your set.
  • Sonny Berry
    Ok thats the D52W20 convergence power supply that is listed under the RCA parts at the link I posted.
  • Sonny Berry
    Your model doesnt use the Convergence ICs. There are an entire series of small transistors. However that is not what your set needs when the option has dropped from the menu. Its the convergence power supply and FL231 which need replacement. Fuse FL231 has to be removed from circuit to test or you will get a false positive reading from the surrounding circuit.
  • Sonny Berry
    Sonny Berry Aug 05, 2008
    No fuse FL231 is located next to the flyback on the deflection board there are three brown rectangle fuses all in a row FL231 is the center fuse.
  • Sonny Berry
    Sonny Berry Aug 20, 2008
    I just contacted them the D52W20 was a remanufactured board that was sold all they have available now are the ITC222 convergence power supply which is the same its just that these are the new boards , they have sold out of the remanufactured ones as they are a high demand circuit board.
I don't know my password and not sure if my e-mailed address is correct
hi this is jannet and am expert to solve your issues kindly call us to this numaber +1(518)348-9393
Oct 06, 2017 | Computers & Internet
Blogger dashboard sign in
Maybe your device is facing some connectivity issuses with blog server and if that;s the one..... try from another device.
or it can be because you just messesd up with the template and html codes........
And for the record your blog is nice and great .......
Keep up the work.
Aug 24, 2014 | blogspot.com
Cant hear received calls, they can hear me though.
Hello.
what this mean is that your phone hear pics is bad
there are two ways that you can replace your phone hear pics
the first is that you will have get an external type that is hand free and fix it up on your phone with this you will be able hear the net person communication from the other end and you will be hard a well
while the other solution is that you have to replace the hear pics of then phone it self by opening case of the phone and unscrew it and remove the hear pics
and replace it with a better one
you can get the new one from any phone work shop around you or in samsung shop .
Good luck and thank for using fixya.
May 28, 2010 | Samsung SGH-J600 Cellular Phone
When I take a pic, there is a delay in the time
There could be several problems like: 1)the focus 2)Self timer set to 2sec or 10sec 3)very slow shutter speed set
Make it as a 10 or 20 second delay on the self timer .Your problem here could be that the settings are not right. Go to the menus and reset all to original or default. Then set menus the way you like. You may have a slow memory card, try changing to a faster card, and test it.
Thank you!
May 17, 2010 | Nikon COOLPIX S200 Digital Camera
How do I use self timer. I set in on menu and I
In the REC mode, press [MENU]. On the "REC" tab, select "Self-timer" and then press right. Use up/down to select the timer type and press [SET].
May 13, 2010 | Casio Exilim EX-Z1200 Digital Camera
My Tmobile phone is exhibiting audio problems. I can hear people talking when I call but they cannot hear me. What is wrong with the phone?
HELLO.
The problem is from the month pic of your phone,this means that the month pic is bad.
The way out to fix up the phone problem is that you have to take it to good phone work shop for fix up .
Please note, is a thing that you can fix up your self if you have the tools and the material to fix it up.
Good luck and thanks for using fixya.
Mar 17, 2010 | Nokia 6600
Two rings on xbox360 how to fix
over heated just let it cool down also make sure the xbox is in a well vented area
Oct 24, 2009 | Microsoft Xbox 360 Console
Does the samsung s630 camera have a self timer(to take pictures)?
yes it dose you have to press the right arrow > button and on the left side of the sceen it will have a little pic of a clock kind of thing and you can set it for two pics or 1 in 15 sec or a quick self timer pic that will give you 10 secs but you hae to press the button a cuple of times to get diffent timers setting
hope it helps
Jul 17, 2009 | Samsung Digimax S630 Digital Camera
Won't take pictures after batteries died
no u can't do that stupids never take out tha card now u messesd up big time sorry
Nov 12, 2007 | Fuji FinePix E510 Digital Camera
My pic has double vision and contrast wont fix it...........can u please help
sound like a convergence problem.
check out this site.
i did a self focus in the service mode which corrected my problems, but lost the self focus function out of the service mode, so enter at your own risk, i can live with the right picture without the self focus feature,  but am inquiring on forums how to get it back.
May 10, 2007 | Akai PT4799HD Rear Projection Television
RCA R52WH76 Television Logo
272 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
