Question about Mtd Products Yard Machines 158CC Tiller
Need dia of gear box for 5hp MTD tine tiller 96' 216-410-118
  • 10865 Answers
SOURCE: need manual for mtd 5 horse rear tine tiller model
If you go to Sears.com, then go to parts,then type in the model number, then look to the right and scroll down slow you will see a spot that says get manuals for this model and click on view manuals then any manuals they have you can print them out.
Posted on Feb 27, 2009
SOURCE: I need a manual for my MTD Huskee 5hp rear tine tiller
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Posted on Apr 13, 2009
  • 10 Answers
SOURCE: MTD yard machine model#216-410-000
either your tine shaft is seized to bushings which requires total dissassembly of unit or you have a failure of drive chain or gear i'm currently repairing one with the seized bushings if you are not a technician i would recomend replaceing unit very costly to repair in any case.
Posted on Apr 12, 2010
  • 221 Answers
SOURCE: MTD series 410 rear tine tiller drive wheels slip
I have the same issue with one I am working on. It appears the keys in the drive shaft are not rotating far enough out on the drive gear side to fully engage in the gear. I have studied and studied this and so far I have been unable to determine why. If I find out I will let you know. I am also trying to figure out what is supposed to pull these keys out of the till engagement gear.
Posted on May 14, 2010
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Posted on May 27, 2010
Where to add oil in transmission gear box
If it like my MTD you cannot add fluid to the transmission it is sealed.
May 29, 2014 | Mtd Garden
Mtd turf power tiller
cannot find anything about a 420 tiller... need an actual model number please
Dec 24, 2013 | Garden
Have a MTD Yard Machine rear tine tiller Model 410 and when I went to use it this year when I put it in gear the tines did not move. I called the MTD tech and he said it sounds like its in the...
It is the shift fork in the transmission. Bad part design and if you plan to take it apart, use sandpaper and really clean the wheel axle and tine axle before you take it apart.
Mar 20, 2011 | Mtd Garden
Mar 21, 2010 | Mtd Products Yard Machines 158CC Tiller
Belt seems to be slipping
good evening. I would suggest checking the tine bearings as well alignment. I had (have) a 2003 mtd rear tine which blew the entire bearing box for the second time. The times should have little to no flex when push or pulled. Fortunately, MTD came good for the first rebuild even though my warranty had expired...they covered the parts and labour was all mine. If the tines seem properly working, possibly try out this website to get the 100% correct belt....hope this helps.
http://www.milacalawn.com/parts.asp
Apr 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I need a manual for my MTD Huskee 5hp rear tine tiller. Model # 21A 410 131. Briggs and Stratton motor. 18'' tilling width.
Apr 13, 2009 | Mtd Garden
Need to know the kind of oil or grease that goes in transmission
engine oil is sae 30
the the gear box I think is a 90wt
Mar 10, 2009 | Mtd Garden
Mtd Products  Yard Machines  158CC Tiller Logo
163 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
