Question about ECS C51GM-M Motherboard
Usb plug ins do not work on motherboard, is it better to just replace the motherboard and start over
  • 415 Answers
Unfortunately it's not unusual to get a laptop or mb that has some USB slots that don't work. I'm assuming you've checked to make sure all the power wires are connected? If it's all connected and not working I would exhange the board rather than trying to fix it.
Posted on Mar 23, 2011
I have an acer 7741z-4433. I've fixed it many times. One day the battery just stopped charging. So I tried swapping the ram, replacing the charge plug, replacing the battery, starting up without the usb...
The match is critical. Look for the values such as AMPERAGE in Milliamps and Proper Voltage as specified by the manufacturer. Failuer to make a pure match could burn up the Motherboard.
May 09, 2014 | Computers & Internet
USB 2.0 on Tyan S1845 Trinity 400 Motherboard
look at board near front panel on the sides
Jan 24, 2014 | Tyan Computers & Internet
My computer cannot recognised a usb
A better description of the issue would help a lot, but...
If you've verified the device you are plugging into a usb port works in another computer, then here's some basic things you can try:
- Ensure plug and play service is enabled.
- Remove any usb software listed in add/remove programs or 'programs and features'.
- Ensure the usb ports are enabled in BIOS, obtain motherboard or OEM manual/support for this.
- If it's not working, but did and you upgraded your operating system, obtain your windows updates, if still not working uninstall drivers from device manager, restart your computer.
Oct 22, 2013 | Office Equipment & Supplies
Your new hardware might not work properly error will appears
This error message comes up when you plugged in your USB Flash drive into a lower version of a USB port. Try using another port in your machine, ports that are USB 2.0 compatible and you shouldn't see this error again.
By the way, there are old motherboards which does not have ports for USB 2.0. You might want to check your motherboard user guide and see which ports runs at 2.0. If there is none, I'm afraid that the only way around it is to upgrade into a better motherboard.
Hope this help.
Apr 27, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My laptop Compaq presario f 7oo..firstly cam,wireless, Bluetooth and dvd writer doesn't work at all.i reinstalled the windows vista but it didn't work. i decided to change windows vista to xp...
first take battery and power out
then blow warm air in vents using hair dryer
then put batter only in and turn on
wrap in towel and leave for 45 minutes
open back up and plug power in done!
i was shoked when this worked
Sep 26, 2010 | HP Compaq Presario F500 F700 and G6000...
I replaced my hard drive in my hp pavilion desktop a1520n windows loads and then reads that i will have to register my copy of windows But my keyboard and usb ports dont have power so i cant do a...
A lot depends on where the keyboard and mouse are plugged in. I have seen in the past that the USB in the back works better than the front. Are these the original keyboard and mouse? If not, use the original until after Windows loads the desktop.
Mar 21, 2010 | HP P2360AA Keyboard/Mouse
Why does the keyboard not work when I start up motherboard. all devices and memory are found but then asks to press F1 or DEL but keyboards (usb and ps2) aren't working :( Motherboard is ABIT KN8 Ultra
Hello
Try this.
Unplug usb key board.start pc.plug usb keyboard in.should work.
Try reinstalling usb drivers or chipset drivers for motherboard if above does not work.
Feb 05, 2010 | Abit KN8 Ultra Motherboard
I need to know where to plug the power plugs and usb plugs
Usually it will say on the MB... But which ever two pins, when shorted, turn the PC on is the Power SW but it is better to consult the manual.
Here is your manual:
http://rds.yahoo.com/_ylt=A0geu5BJHUxJrEgAhCFXNyoA;_ylu=X3oDMTByc2FtNTRpBHNlYwNzcgRwb3MDNgRjb2xvA2FjMgR2dGlkAw--/SIG=12f16ibe6/EXP=1229811401/**http%3a//joule.bu.edu/~hazen/LinuxCluster/e1511_p4r800-vm.pdf
Dec 19, 2008 | ASUS P4P800-VM Motherboard
Compaq Armada E500 PC Notebook usb port problem
If the usb connector / port is only damaged it should be a fairly easy task.
Your going to need a few screwdrivers to get the laptop open
and a soldering iron, to remove the port or ports connector(s)
from the motherboard then replace it with a new connector.
if the motherboard is damaged you would most likely have to replace the whole motherboard and that would be way too much money for a few usb ports.
the usb connector only has 4 pins
http://wolfstone.halloweenhost.com/Audio/mpg016_ConnectorUSB.bmp
Mar 30, 2008 | Compaq Armada E500 Notebook
ECS C51GM-M Motherboard Logo
67 people viewed this question
Top ECS Computers & Internet Experts
David
David
mitch_3020
mitch_3020
Steven Wander
Steven Wander
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
