Question about Brother LS-2125 Mechanical Sewing Machine
The top tread always breaks or slips out of the needle why I'm sewing. It's like the tension is too high, but nothing changes when I adjust the tension.
  • 484 Answers
Did you thread it when the pressure foot was up? It must always be threaded with the pressure foot up as this disengages all the tensions. Also try re-threading as sometimes the thread misses a tension disc. If the bobbin is threaded wrongly it can also cause thread pulling. If the thread is poor quality it may have knots that cause this problem.
I would suggest removing all threads and cleaning between any visible tension discs incase there is a piece of broken thread stuck in there, then re-thread the whole machine with pressure foot up.
Posted on Mar 23, 2011
Thread keeps breaking don' know how to adjusT tension
Since we don't know what machine you have, we're really limited on suggestions. The owner's manual should have instructions for tension setting. If you don't have a manual, search for:
Make Model manual
Assuming it is the top thread that is breaking. Breaking thread usually indicates either the machine is misthreaded or the tension is set too high. However, there are other symptoms that indicate other issues, ie if the thread is shredding or fraying, possibly the incorrect needle is being used or there is a snag/burr somewhere in the thread path. If the machine sews for approximately 2 inches and then breaks, something is catching the thread causing it to stretch until it breaks. Frequently, my thread slips off the thread spool and wraps around the spool pin and breaks.
AVOID old or bargain bin thread.
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point and retest the machine.
Mar 19, 2018 | Sewing Machines
My serger won't make the chain stitch. I have carefully re-threaded it about 5 times, but no change. I haven't changed the needle recently either.
What exactly is happening? Is it breaking thread? Is there any thread that is not feeding? Need more specifics.
Here are general instructions for when issues arise:
Change the needles if they are not new. Make sure they are inserted properly and all the way up in the needle clamp.
RAISE the presser foot, clip all the threads below the thread tree, and remove all threads from the machine by pulling on the thread tails. (Always remove thread by pulling down, never up.)
Rethread from the beginning insuring that each thread is treaded in the correct order (consult the manual). ALWAYS rethread with the presser foot up! (NOTE: on most machines, it is the upper looper first, lower looper second with the thread tail draped OVER the top of the upper looper, then the two needles.) Grasp each thread above and below the tension disk and give it an extra little tug to make sure it is fully seated in the tension disk.
Adjust the tension dials to the midway point.
Then test.
Mar 16, 2016 | Brother 1034D Serger Sewing Machine
How do I determine what tension to use?
Tension setting is trial and error. To learn choose two color threads same weight and manufacture. placing one in bobbin other top tread.
Set the lower tension to light. The lower tension has always been lower than the top.
Depending on needle size and material the upper needs to be set.
Use the images as a guide.
26050009-gmetzlbygkf20izcnwtcwtjv-4-2.png Hope this helps?
Jan 12, 2016 | Sewing Machines
I have an husqvarna Viking mega quilter18x8 with the imperial frame. I am having problems with the tension and the tread keeps breakingms with. The tension and the tread keeps breaking. HELP!!
If the thread breaks at the needle and is feeding smoothly from the spool, you may have the tension too high. It is impossible to say what the setting should be because the knob rotates all the way around several times. Loosen it off until you see needle thread pull to the back of the quilt, then tighten until it just balances the interlocking of the stitch in the fabric. Test with little swirls, that's most likely to pull needle thread to back.Also, check that the needle is properly installed and that the hook to needle timing and clearance are good.Nesting of thread underneath usually happens if the foot lifter is left up or the tread is not fully in the disks of the tension unit.
Oct 25, 2011 | Husqvarna Viking 1
I have a serenade, and problems from the start. It skips stitches, upper thread breaks with all tensions, or just too tight and it doesnt stitch just makes loops and tangles up. A friend of mine has had...
try a new ball poine needle. Sounds like intermittantly not picking up the bottom thread....It doesn't take much to shorten the needle just a hair to cause this, especially with sharps. Try a ball point needle...The last longer and are more durable. I sew everything with a ball point. Top Thread will also break if the top tension is too tight. Remember, when adjusting tensions, baby steps all the way...just a lil' smidgen might be just what you need. Also, always make certain the machine is level so that the settings don't vibrate out of adjustment. Dusty Tread will also brea easy. Keep threads clean and dust free. Good Luck
Sep 01, 2011 | Singer 2250 Tradition
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Sewing Machines
Manual wheel on side of machine won't move needle
hi there;
well try to rotate hand wheel center holder clockwise while hold grift the handwheel not to move to engage the clutch,because ther is clutch that holding the movement of the needle and the bobbins case.if still nothing change at all,open a cover motor assembly chech the belt tension if still engage on pulley,maybe slip pulley is occuring when motor run,if belt is slip to pulley replace belt,but if ok upon clutch adjustment ignore replacement.
regarding bobbin and threading you can watch on youtube.doing this,on internet explorer,type www.youtube.com
then on you tube search type"sewing machine"then click search
ther are high ligthed show for bobbins winding and treading just click it enjoy watching while you learn,have a nice viewing regards
don't forget to rate me,thank's
Apr 09, 2009 | White Sewing 1418 Mechanical Sewing...
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
73 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
